Question about Intel DG31PR Motherboard
System error not decting the hard disk drive
Mine is old computer with windows 3.11 and 100MHz processor it does not boot at times if boots does not detect the hard disk system error appears what to do .......
  • Dick
    Dick May 11, 2010
    Windows 3.11 does not support modern hardware. Unless it has ever booted with that hard drive you will probably never get it to work.
    President:
  • 2,692 Answers
Try to reinstall the windows but most likly the hard drive died. You can download, free Hard driver diagnostic software to confirm the hard driver failer. Example link below from Seagate:
http://www.seagate.com/www/en-us/support/downloads/
Posted on Feb 15, 2009
Windows XP sp3 not booting Error system halted
Is your First Boot Device in BIOS is Set to Hard Drive? IF not then Just Change it Hard Drive.
Aug 11, 2012 | Intel Computers & Internet
Booting issue with intel D865GSA
First remove the hard disk and see whether you have boot error if you have boot error insert the os cd in to drive and boot from the cd if it works fine you have a problem with the hard disk to clear the hard disk problem use a desktop computer and insert the hard disk as slave in the desk top and boot the desktop with the original drive then right click my computer click mange then disk management and find the laptop hard disk the delete all the part ion in the laptop disk then switch off the desk top and insert the hard disk in the laptop and reload the OS
Feb 14, 2012 | Intel D865GSA (BOXD865GSAL) Motherboard
I am getting a disk 1/0 error and am not confident at all with computers. How can I fix this so my son can use the computer? My PC is about 6 years old and I only ever used it 9-10 times
A..Access the BIOS setup by pressing the key designated for your BIOS at Startup? It can be Del/F1/F2 or whatever and will be shown on Boot Screen before Windows is loaded.
B. Do you have a Win98 Boot Diskette proven to work well in a PC?
If so:
1.With the Win98 Boot Diskette in the Floppy Drive, Restart the PC.
2. Press the BIOS key [Eg:Del] enter BIOS setup
Check for correct YYYY/MM/DD and Time for your Time Zone and proceed to take a good look at the entries of your IDE devices and Floppy Drive with special attention to your Hard Drive(s) in IDE section. If they are all properly identified and normal, you can EXIT the BIOS. [ It does not mattere "Save changes" or "don't save changes" as you have not made any changes.]
3. Wait for Boot Disk to be accessed and Windows Startup Menu to appear with the Options:
1.Start Computer with CD-ROM support.
2.Start Computer without CD-ROM support
3. Help File
4. Select the option,1.Start Computer with CD-ROM support. and ENTER
5. Watch the screen for CD-ROM driver installed successfully" and "Diagnostic Tools " installed and CD-ROM drive letter designation and finally appearance of A:\Prompt
6. At, A:\ Prompt type FDISK and press ENTER.
7. Accespt Y at the bottom of "Large Disk Support" message.
8. At FDISK menu select #4. Display...."
9. Check if the HDD is shown as C: A FAT32 and size.
I am suspecting a problem somewhere here; so if you don't have an Active C: drive press ESC >ESC and remove boot Disk CTRL +ALT+ DELETE to reboot and post back
If you have an Active C: drive, press ESC >ESC to A:\Prompt and type in C: and then at C:\> prompt, type DIR and [ENTER] look for Windows Directories. Here is another Problem area. If you cannot Find any Dir or get an Error, make sure your typing and spacing are OK [ No space after Drive letter for the Command] and if so, ALT+CTRL+DEL or Power Off.
If the problem is same do next .
Alternative Start Mode
1. Re-boot PC, as it starts tap F8 several times until the windows boot window appears.
2. Scroll to "Start with last known good configuration.)
3. Press "Enter"
Or
2. Scroll to "Safe Mode" (With networking, if you want to access the internet)
3. Press "Enter"
System Restore
1. Go "Start"
2. "All programs"
3. "Accessories"
4. "System tools"
5. "System Restore"
6. ensure "Restore to an earlier time" is checked and click "Next"
7. Select an earlier date when your PC worked well. (Must be a highlighted date)
8. Click "Next"
9. Allow system restore and reboot
NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
Computer is booting from a non-bootable source.
Computer hard disk drive is not properly setup in BIOS.
Corrupt NTLDR and/or NTDETECT.COM file.
Misconfiguration with the boot.ini file.
Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
New hard disk drive being added.
Corrupt boot sector / master boot record.
Seriously corrupted version of Windows 2000 or Windows XP.
Loose or Faulty IDE/EIDE hard disk drive cable.
Solutions:
CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Verify that your computer hard disk drive is properly setup in the BIOS / CMOS setup. Improper settings can cause this error. Additional information on how to enter the BIOS / CMOS setup can be found in document CH000192.
Windows 2000 users
Windows XP users
Windows 2000 users
If your computer is using Microsoft Windows 2000 and you are encountering the NTLDR error. Create the below boot.ini file on the floppy diskette drive.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINNT
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect
Copy the NTLDR and NTDETECT.COM files from another computer using the same operating system. Both of these files are located in the root directory of the primary hard disk drive. For example, C:\NTLDR and C:\NTDETECT.COM should be the locations of these files on many computers.
Please keep in mind that these files are hidden system files, if you need additional help with viewing hidden files in Windows please see document CH000516.
Once these files have been copied to a floppy diskette reboot the computer and copy the NTLDR and NTDETECT.COM files to the root directory of the primary hard disk drive. Below is an example of what commonly should be performed from the A:\> drive.
copy ntldr c:
copy ntdetect.com c:
After the above two files have been copied, remove the floppy diskette and reboot the computer.
Windows XP users
Insert the Windows XP bootable CD into the computer.
When prompted to press any key to boot from the CD, press any key.
Once in the Windows XP setup menu press the "R" key to repair Windows.
Log into your Windows installation by pressing the "1" key and pressing enter.
You will then be prompted for your administrator password, enter that password.
Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Edit the boot.ini on the root directory of the hard disk drive and verify that it is pointing to the correct location of your Windows operating system and that the partitions are properly defined. Additional information about the boot.ini can be found on document CH000492.
If you are getting this error message while you are attempting to upgrade to Windows 2000 or Windows XP from Windows 95, Windows 98, or Windows ME running FAT32 please try the below recommendations.
Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
At the A:\> prompt type:
sys c:
After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
If you are attempting to add a new hard disk drive to the computer make sure that drive is a blank drive. Adding a new hard disk drive to a computer that already has Windows installed on it may cause the NTLDR error to occur.
If you are unsure if the new drive is blank or not try booting from a bootable diskette and format the new hard disk drive.
It's possible your computer's hard disk drive may have a corrupt boot sector and/or master boot record. These can be repaired through the Microsoft Windows Recovery console by running the fixboot and fixmbr commands.
Additional information and help in getting into the Microsoft Windows Recovery console can be found on document CH000627.
If you have tried each of the above recommendations that apply to your situation and you continue to experience this issue it is possible you may have a seriously corrupted version of Microsoft Windows. Therefore we would recommend you reinstall Microsoft Windows 2000 and Windows XP.
If you are encountering this issue during your setup you may wish to completely erase your computer hard disk drive and all of its existing data and then install Microsoft Windows 2000 / Windows XP. Additional information about erasing the computer and starting over can be found on document CH000186.
This issue has been known to be caused by a loose or fault IDE/EIDE cable. If the above recommendation does not resolve your issue and your computer hard disk drive is using an IDE or EIDE interface. Verify the computer hard disk drive cable is firmly connected by disconnected and reconnecting the cable.
If the issue continues it is also a possibility that the computer has a faulty cable, try replacing the hard disk drive cable with another cable and/or a new cable.
Hope this helps ,
Jan 26, 2011 | Gigabyte GA-8SRX Motherboard
I turn on my hp pavilion zd7020us the hp page boots up then goes to safe mode or normal mode page then goes to a very quick blue screen and turns off and starts the whole process over again any ideas
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jun 18, 2010 | Computers & Internet
Boot disk error insert system disk and and press enter.
it is a hard disk error. most likely your hard disk is defective since is it not registering well. please try to use 80-pin interface cable to correct the problem or change your Hard Disk
Sep 21, 2009 | ASUS P4S533-MX Motherboard
Computer will not boot from hdd. Needs system disk.
The problem wasn't your hard drive, it was your operating system. You need someone who is savvy with computers to use a boot disk and get into your computer to find the problem.
Sorry,
matt
Sep 15, 2009 | Computers & Internet
Sometimes it boots to my SATA hard drive, sometimes it doesnt
Dear friend you i think you have to operating system in to hard drive.. Please... format the IDE hard drive... if IDE hard drive is Primary hard drive then go to the BIOS, In BIOS go Boot Sequence you may see there Hard disk Priority option.. Let set Sata hard drive as first one.. Then your computer Boot from sata Harddrive... thanks...
Please do this first.. Set sata as first hard Drive from BIOS Hard disk Priority Option.. then Format IDE Hard drive..
Thanks Sumon.. i think it will solve your problem..
Mar 27, 2009 | Computers & Internet
Hi all was ok in till i removed my hard drie affter i shut down the system and turn it off i removedthe hard drive now system will not boot back up it will power on but wont boot up ive unpluged everything...
hi im josh in cebu phils.may i help you? friend try to do this things. first i suggest to change new ide or sata cable.if still persist.try the following:
Boot order: Traditionally, a computer is set to boot first from the floppy drive, and then from the main hard drive (Drive C). This means that the computer will check the floppy drive first for boot files. If there is no disk in the floppy drive, the computer will then go to the hard drive to look for boot files. That is why if you leave a non-bootable floppy disk in the drive and try to boot up, you'll get an error message such as "NTLDR is missing. Press any key to restart." or "Non-system disk or disk error." This can be changed to pretty much any order, including CD and DVD drives. It is useful when installing Windows on a new or just-formatted computer to set the computer to boot first from a CD-ROM drive, and then insert the Windows installation CD-ROM into that drive. This saves you from having to use boot floppies that might or might not come with the Windows CD-ROM. Good luck.
Mar 05, 2009 | EliteGroup MB ECS A770M-A 770 SB600 AM2+...
Consistent hard Drive BOOT ERROR after an upgrade to MSNV-939 motherboard
You can run a disk manager for your drive however, I'll bet you will find its windows boot.ini. It may read just fine for a dual boot system but think about this. Windows can get confused real quick. I'm talking about the regestry. Take the time and do a fresh install of your Linuex and than re-install windows "clean install". I'll bet everything works out just fine. When 1 changes MB's there is a whole list of new drivers PCI devices loading into windows. Your system will run better with one copy of drivers for your new board and windows will not carry a list of old drivers and PCI devices of your old board.
Oct 17, 2007 | Mach Speed (MSNV-939) Motherboard
Consustently get "DISK BOOT FAILURE _ INSERT SYSTEM DISK AND PRESS ENTER" message
use xp sp2 bbootable disk and simply run a repair installation it should heal your system
Intel DG31PR Motherboard Logo
96 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
