Question about Intel DG31PR Motherboard
Display not appearing after boot up
Out of range95.1kz/60hz mesasge caption appears after booting up
  • INHS INHS May 11, 2010
    please post your complete problem..
  • Greg Caudle May 11, 2010
    Is this a new install or were any changes made?
  • Intel Master
  • 3,051 Answers
Hi there you are going to have to boot into safe mode and go to your screen display properties a nd change the currrent settings from there like 1024 x 768 or 1280 x 1024 and if you have a default setting for the refresh rate use it ok then just reboot the pc ok
best regards mike
Posted on Feb 16, 2009
How do I know if my boot ste up is correct
If your PC doesn't boot up using the hard drive, you can check that by looking for the F2 or F12 displayed on the screen during boot up. Then start pressing F2 or F12 quickly to get setup.
In setup follow the directions and set your "boot device" to "hard drive"
Hope this is what you needed.
Feb 15, 2012 | Dell Inspiron 531 Athlon 64 X2 4400+...
Out of range message
This is caused by a resolution and/or refresh frequency setting in your computer's display properties that exceeds the values supported by the monitor.
Find out the optimum (native) resolution of your monitor (in case of AMV 17V5 it will be 1280x1024 pixels), and supported refresh frequency (usually 60Hz for LCD monitors), and set your display properties to these values.
Nov 23, 2009 | Amptron AMV 17V5 17" LCD Flat Panel...
IntelD865GBF starts up displays Blue INtel Desktop
remove Bios battery ..and try again ...probably it doesn't see something ...but its a good sign that the Intel blue appears
Nov 08, 2009 | Intel D865GBF Motherboard
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
The motherboard could not display
Please try these......
1. If it happens after appearing the windows logo, Your RAM is working fine. Normally it happens when the HDD fails(Bad Sector or Faulty Head) or the MBR(Master Boot Record) got corrupted.
2.Check whether any noice is coming from HDD on Booting.If YES...then the problem with your HDD
3.Try with a fresh or working HDD
Mar 02, 2009 | Computers & Internet
Immediately upon boot, vertical lines appear on screen. After several minutes the screen turns pick and the windows cursor appears. there is no further change in the display. Mouse appears to work. Not...
My first check would be video drivers if this is a newly built computer. If it is a computer that has been running a while and the problem suddenly appeared I would reseat the RAM and attempt to boot into safe mode, suspecting a virus infection.
Mar 01, 2009 | HP Computers & Internet
My computer is not booting up.
Try this,Start in VGA mode.Once started,update your video drivers and do a virus scan
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Safe Boot options loadTOCNode(2, 'moreinformation');
  • Safe Mode (SAFEBOOT_OPTION=Minimal): This option uses a minimal set of device drivers and services to start Windows.
  • Safe Mode with Networking (SAFEBOOT_OPTION=Network): This option uses a minimal set of device drivers and services to start Windows together with the drivers that you must have to load networking.
  • Safe Mode with Command Prompt (SAFEBOOT_OPTION=Minimal(AlternateShell)): This option is the same as Safe mode, except that Cmd.exe starts instead of Windows Explorer.
  • Enable VGA Mode: This option starts Windows in 640 x 480 mode by using the current video driver (not Vga.sys). This mode is useful if the display is configured for a setting that the monitor cannot display.
Please rate this a fixa
Jan 15, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
On Pwr up logo appears then LCD returns to stanby Black screen
I will assume the monitor is staying on during the boot process all the way until Windows loads.
If that is the case, then...
  • Start the computer
  • wait until the initial bios/logo screens for your motherboard go away.
  • Press F8 to get the Windows recovery boot menu
  • If you see the Windows Logo you would normally see then press rest and try again.
  • In the recovery screen, select SAFE MODE
  • Boot into Windows and uninstall your video card.
  • Reboot the computer the normal way through the start menu.
  • When your PC starts back up it should then reinstall the video card, and set itself automatically back to 60khz as default.
Let me know how you go =)
Jan 20, 2008 | BenQ FP71E 17" LCD Monitor
Intel DG31PR Motherboard Logo
64 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
