Question about HP Compaq d530 PC Desktop
Motherboard p4sd rev 1.09 sp#323091-001 missing security cable.
This mb has a 19 pin security connection and a hood lock jumper pins,problem is i don't have anything that connects to it,so it runs for 3 sec then shuts off.
It was given to me without the case so i'd like to install it in another.
Is there jumper settings that would allow the motherboard to operate.
  • Anonymous Mar 27, 2009
    exact same
    Novelist:
  • 152 Answers
I mistakenly jumpered the boot block pins on my Asus P4SD motherboard, while it was unplugged. What effect will this have, and how can I fix it.
did you hear a pooof? if it was plugged in but turned off you are probably ok, the ground connection is a good thing. if you heard something that is bad. there is no way to tell until you finish the build.
Jul 27, 2014 | Computers & Internet
My system is power on but it will not display anything on monitor
you can troubleshoot this problem very easily
  • confirm you connected all your cables including to monitor and 4pin power for graphics to MB
  • confirm your RAM is good, if you have two RAM, use single RAM for checking, replace with new
  • Clear BIOS by reconnecting Bios Jumper, if your jumper has 3 pins remove Jumper and connect with other two pins
  • If you have graphics card, check it, if you have doubt about this, use motherboard graphics, or replace with a working one,
  • if still not working after replacing new RAM and Graphics card, replace your processor, it will surely work if your motherboard has no problem
Thank you
Please rate me if is succeeded..
Sep 03, 2011 | Intel DG31PR Motherboard
I Need the jumper settings for the fic k8mc51g motherboard from a emachines desktop computer. Putting the motherboard in a custom case.
There is a 4-Pin Speaker connector that is not used by Gateway on the motherboard (right beside) the CMOS jumper settings (Pins).
The clear CMOS settings jumper block is right beside the speaker pins. You can use this jumper block to clear the CMOS RAM, which is powered by the onboard real-time clock button cell battery.
Pin 3 is indicated by the markings on the board.
Settings: Pins 1 and 2 covered = Normal Operation Pins 2 and 3 covered = Clear CMOS enabled.crazyeyes746.jpg
Jun 26, 2011 | Computers & Internet
Dear Sir, my mother board d101 has been damaged can i use of p4sd m/b insted of that while i want all rest parts remain using i dont want change ram,SMPS, Proccesser etc.
fbhushan, the Intel D101GGC motherboard (Grand Country) supports;
1) Intel Pentium 4, Intel Celeron D, and Intel Pentium D processors that fit in an
> LGA 775 processor socket.
http://en.wikipedia.org/wiki/LGA_775
The Processor has the socket holes, and the processor socket (LGA 775) has the pins.
775 socket holes, and 775 pins.
The Front Side Bus (FSB) can be either 533MegaHertz, or 800MHz.
2) Supports DDR Sdram ram memory at either 333MegaHertz or 400MHz.
(PC2700 and PC3200, respectively)
Will support Up To 2GB of ram memory.
Has two ram memory slots. The maximum amount for EACH slot is 1GB
3) The SMPS used for it has,
A) One 24-pin ATX main power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
B) One 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The Intel D101GGC motherboard has Four SATA headers (Connectors) on it, so I'm going to assume you are using a SATA harddrive.
This would mean the SMPS you are using should have at least one SATA power cable.
It should also have an assortment of 4-pin standard Peripheral power cables.
(Misnomered as 'Molex')
The Asus P4SD (Motherboard chipset Intel 865PE) supports;
1) Intel Pentium 4 and Intel Celeron processors that fit in a > Socket 478 processor socket
http://en.wikipedia.org/wiki/Socket_478
The Processor has the pins, and the processor socket has the socket holes.
478 pins, and 478 socket holes.
Your Processor will NOT work.
The Ram Memory WILL work.
The SMPS MAY work.
I state MAY because the Asus P4SD motherboard uses a 20-pin ATX main power cable.
If the last four pins of the 24-pin ATX main power cable that you have on your SMPS right now, Do Not remove, you can Carefully cut them off. Wrap them up, and out of the way.
If you need guidance on this I can help instruct you.
You need an IDE (PATA) harddrive, or a SATA adapter card to use a SATA harddrive.
So there you have it sir.
Regards,
joecoolvette
Nov 22, 2010 | Intel D101GGC Motherboard
I need a schematic (pin-out)of the MX4-ge motherboard
You can download the manual for you're AOpen MX4GE motherboard from the link provided below; ftp://ftp.aopen.com/pub/manual/mb/mx4ge/mx4ge-ol-e.pdf
You'll need Adobe reader installed to view the *.pdf file above.
Download Adobe @ http://www.adobe.com/products/reader/
Open manual to page 33. Here you'll see the layout for the front panel motherboard pins. The view towards the left shows where to connect the jumpers coming from the case to the motherboard. The view on the right shows where each positive wire and negative wire connects. The common colored wire for each jumper will be used as negative. Except for the internal speaker 4-pin jumper. Normally positive wire is red in color and ground is black in color and connects to pins 16 and 19 only. Pin 1 is shown. Pin 2 is to the right of pin 1. Pin three is below pin 1 ECT.
Cheers'
Mike
Mar 03, 2010 | GE AOpen AX4GE-N (NMBA0102) Motherboard
Not deteck hdd & cdrom
Power down you're system and remove the power cable from the PS.
Open you're case. First clear the cmos jumper. See bottom of page 14 in manual. The GA-8VM533M-RZ motherboard was made Jan-1-2004. It is very likely that the cmos battery needs to be replaced. Average life span is 5 years or less. Pull the cmos battery and check its voltage with a voltmeter, it should read no less than 2.7volts DC.
I'm guessing it’s the bios that’s not seeing the CD-ROM drive and the hdd? Suggest you check both the data cables and their power cables.
Since the GA-8VM533M-RZ motherboard only supports ATA IDE hdd's, check the drives jumper. (It should be jumpered as a Master) and so should the jumper on the back of the cd-rom drive. See the link provided; http://www.easeus.com/resource/install-ide-hard-drive.htm
The link above helps but you're hdd may be different. See the sticker on
you're hdd for the correct jumper setting.
If you are using a single data cable to connect both cd-rom and hdd to the motherboard don't. Use an 80-pin data cable for the hard disk drive. You can use a 40-pin data cable for the cd-rom but if you have a spare
80-pin data cable connect the cd-rom drive to it.
Connect the hdd to IDE1 and connect the cd-rom to IDE2. See motherboard layout in the manual page 5. Need the manual? Download it from Gigabyte; http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1766
To view the manual you will need to download and install Adobe reader;
Re-connect the power cable to the PS. You can leave the case opened for now. Power on the system and press the Delete key every 2 seconds until the bios menu opens. (Make sure the time and date are set current). See page 19. Than turn to page 23. Make the settings as follows;
First Boot Device [Floppy] - (if one is connected)
Second Boot Device [CD-ROM
Third Boot device [HHD-0]
Password Check [Not needed]
CPU Hyper-Threading [Enabled]
Check all settings while in the bios, save and exit. The system will auto re-boot. If after replacing the bios battery (If needed), and the bios still
does not see either drive than the problem is either the bios or the motherboard's controller. The bios can be flashed but the MB controller can not be repaired.
Cheers'
Mike
Feb 15, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
How should i plug the system panel connector correctly
Open your manual to page 1-30. Follow the illustration shown. "F_Panel". What is missing from the manual is the wire colors coming from your case. These colors do vary from case to case. If your lucky the case's wires to the MB will include a two pin jumper and they will be marked as such. (HD_LED, RESET, ECT). Most Asus MB's provide you with a F_Panel stand off. Like the picture provided;
If you notice in the pic above you'll find a solid white wire color. This wire is to be connected to the - negative side of the F_Panel MB or jumper block. Other wire colors such as solid blue, light blue, light green and red are commonly connected as positive +. The four pin internal speaker uses black as its - negative and usually red for positive.
Link to Asus for your board;
http://www.asus.com/product.aspx?P_ID=k3h0ZFVu9Lo1dUvk&content=download
Hope you find this helpful!
Mike
Nov 17, 2009 | ASUS P5PE-VM Motherboard
P4SD-BO-R bios updates / manual
You will NOT get around the password. None of the tricks work. BUT, there is a very easy solution for bypassing the Password on this %$$##@@!! MB. There is a small green jumper near the CMOS battery. It covers 2 pins. Remove that jumper. You're Bios is now no longer password protected and you can do that micro update stuff. OK, so I solved your problem. Now someone else's turn to solve mine. I cannot get the audio to work on this delightful MB. Downloaded the new drivers, etc. Anyone out there solved this one? Running XP.
Thanks,
Gregg
Jul 09, 2009 | Computers & Internet
Model name BLUFORD. E139765 motherboard. I need J16 pin layout for the power switch, reset switch, etc. Dell is not very helpful with this paticular board for some reason. Thank You for any info. DW
This is what I found after extensive searching,
......................O
.PWR LED- O O
.HDD LED- O O HDD LED+
.................... O O
.................... O O PWR LED+
...PWR SW O O PWR SW
.CON CNT O O CON CNT
Looks pretty lame, huh? I found this on Dell's Community Forum.
I gather, this motherboard was used in the Dell Dimension 2350.
http://support.dell.com/support/edocs/systems/dim2350/techov.htm#1101565
Looking, at what Dell has for the layout of the Dimension 2350 motherboard, there are 20 pins in the J16 header, just like he has crudely shown above. I don't see one missing in the corner, though. Of course, the link above is a crude example from Dell.
This person stated it was for the J24 header on the motherboard. Also stated that it was the Front Panel I/O header. (At least that's what was stated) I believe he was confused with the Control Panel header J24. Hopefully it is for the J16 Front Panel I/O header, as it has the Power On switch, HDD activity LED, Power LED, and so on.
Indications are that the O's represent the pins. There was a statement of taking -> Note, that there is a missing pin in the upper corner, and this orients the connector view, Orients, how you are looking at the connector. Only you will know for sure. I don't have this motherboard in front of me. Dell ISN'T giving ANY info out.
This person had the Bluford E139765 motherboard, in a Dell Dimension 2350.
The statement was also made, that there is a Brown jumper wire that connects the two CON CNT pins together, but didn't know if this jumper is required, as this person is putting this motherboard, into an aftermarket computer case. (?)
Solution?
What I would do.
I would have the power supply plugged in. I would use an LED lamp, with two wire leads attached to it. Leads of about two inches long, or more. (Borrow one out of the Front Panel, or from another parts computer?)
Twist the ends of the lead wires tightly. I would then touch the leads to two pins. Should they be power Out pins, (HDD activity lamp pins. Power LED pins, and so on), the light will light up, and not short out the two pins touched.
(If the LED light doesn't light up, no biggie. It just means the wires need to be reversed. Bear this in mind, when you go to hook the LED's up)
When the two pins for the Power On is found, the computer will turn on.
Judging by the crude diagram the missing pin is on the upper right.
Only you will know for sure, as the J16 header should have a flat place in one corner, where a pin would go. NO pin.
If so, this is what I see.
Processor to the left, PCI slots to the right, J16 header on the right, above the PCI slots. The header goes along the edge of the motherboard, lengthwise.
I'll number the pins like this.
Starting at the Top Left, and going down the Left side.
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19.
Starting at the Top Right, and going down the Right side.
NO pin, (Would have been Pin 2),
Pins 4, 6, 8, 10, 12, 14, 16, 18, and 20
Pins 3 and 4 are for the Power LED. (Confusion here)
Pins 5 and 6 are for the harddrive activity LED. PIn 6 is for the + wire/
NO connection to Pins 7, 8, 9, and 10
Pins 11 and 12 are for the Power LED.
(Which ones to use? Pins 11 and 12, or Pins 3 and 4? I leave it up to you to test as the computer is on, and see)
NO connection to Pins 13 and 14
Pins 15 and 16 are for the Power On switch.
NO connection to Pins 17 and 18.
Pins 19 and 20 are for that jumper wire he mentioned. I would try it without it. If the computer doesn't come on, or something doesn't work, like the harddrive for example, I would unplug the computer from power, then attach this jumper. Plug in, and see if everything works.
Apr 19, 2009 | Computers & Internet
POWER SWITCH
Hi sivaprasanna,
Do you still have your manual? If so turn to page 72 for location.
For a close look at the motherboard front panel led to MB pins look at these two pics.
Location of front panel connections;
Item " A " is the front panel MB pins.
Pic two is the layout for each front panel connection;
The power on jumper uses pins 7 & 8.
Pin 7 is positive & pin 8 is negative.
Good luck sivaprasanna!
Mike
Nov 09, 2008 | Intel D850MV Motherboard
HP Compaq d530 PC Desktop Logo
4,043 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
