Question about Frigidaire GLEQ2152ES Electric Dryer
Where are the fuses or breakers for the heat elements????????
I took the thing apart,,,Can't find either
    Genius:
  • 1,122 Answers
Take the top off,look to the back of the drum on the left or right side you will see the little main fuse,high temp thermostat and the heating coil terminals,if you have a meter you can check all of them on the ohms setting,let me know-mike
Posted on Feb 15, 2009
Model lec8858eq2 no heat checked all replaced bad heating element everything else has continuity. Only thing I'm stumped is continuity reads 9 on fuse connected right by heating element help!!!!! W
Check your power source. The controls use 120V, but the heater uses 240V. Also, check for loose connections on power source.
(Make sure power is disconnected when checking continuity.)
Feb 19, 2017 | Dryers
Kenmore dryer bought in 2004 stops heating
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Thank You
Nov 01, 2008 | Kenmore 64852 Electric Dryer
I have a whirlpool front loader dryer duet, and I am not getting any heat! My husband and I took it all apart and cleaned everything and checked all the fuses and elemts everything was working just fine,...
make this test and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating Element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. The proper ohm reading can be found in the service manual or sometimes on the tech sheet located somewhere on your dryer (9- 13 ohms is a common reading). Electric heating elements aren't repairable. The heating elements faulty, replace it.
Thermal fuse / Thermal Cut Out / Thermistor
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel or behind the cover .The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing They are also round and made of metal and plastic. The thermistor is located on the blower housing usually. If any of the fuses do not have continuity replace it. Check for continuity if none replace, But before replacing check for obstructions. The fuses are very inexpensive and replace it
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. Check all connections, make sure they are tight. Loose connections can lead to a fire. You may need to replace power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 02, 2013 | Dryers
Problem with hotpoint as66vvxna1 dryer
There are a couple of things that you can check. FIRST go to the electrical box where the circuit breaker or fuse for the dryer is. Sometimes on half of the circuit breaker is tripped allowing the controls of the dryer to work, but not the heating element. Turn off the breaker and turn back on. Or replace the fusees. If this does not work, then you may have a loos wire or a burned out heating element. Sometimes there is a bad high temperature switch. Do the circuit breaker or fuse first. If the washer did not spin out the water well enough, the water can short the element to trip the circuit breaker or blow a fuse.
May 26, 2010 | Hotpoint Ariston AS66VXNA1 Electric Dryer
Dryer runs but does not get hot to dry clothes
Hello there:
There are a couple of things to check if the dryer does not heat properly
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Feb 27, 2010 | Dryers
I ALSO HAVE A PROBLEM WITH THE DRYER NOT HEATING BUT DOES SPIN
Try this, go to your breaker box, find the double breaker that runs the dryer. Filp the breaker off and then back on. Now see if your dryer heats. It sounds like you have dropped one leg of your 220v. From what you have told me, I thing you will find that it will heat.
Aug 15, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
GE Profile Harmony DPGT750EC Electric Dryer not heating up
Check the air flow from the vent-if there is no air or very weak air flow, it is the blower motor. It is not getting up to speed or not spinning at all. Try this:
Press "Home"
Press "Help"
Simultaneously press and hold down BOTH
"My Cycles" and "Back"
After a few seconds the dryer will enter service mode and report any problems.
Pertains to GE Profile HarmonyDPGT750EC/GC
Aug 03, 2009 | GE Profile Harmony DPGT750EC Electric...
No heat in dryer model # 96591420
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 31, 2009 | Kenmore Dryers
Drum Turns, but dryer won't heat up.
If the dryer does not heat at all then is either a problem with the heating elemet , or with the thermal fuse.
See the following suggestions from Repairclinic:
Heating element
Thermal fuse
Wiring
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 04, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Roper Dryer heats for 5 minutes then stops heating but still tumbles. I haven't a manual so there isn't a schematic to work with. Appreciate any suggestions;
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Sep 14, 2008 | Roper REX3614KW Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
109 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
