Question about Gigabyte GA-8SIMLH Motherboard
I need a motherbord diagram
The cables of the panel were disconnected by acident. I need a diagram where I can find how connect them again.The modrboard is a Gigabyte
GA-8SIMLH Rev :3.2. Thank you for your help.
manuel
  • Bob
    Bob May 11, 2010
    Google is your friend. Try the gigabyte website
    Problem Solver:
  • 6 Answers
Here a link to download the manual. YQW!
Posted on Feb 15, 2009
Hey there i have a gilera runner 2003 model! my batter has been working fine up until yesterday! i had my bike turned on and then turned it off again and then i turned it back on and i saw no lights then...
acid overflow is caused by overheating, so there is a short someplace,disconnect the battery and neutralize the leaked acid with baking soda dissolved in water and remove the battery. (the short can even be internal, in the battery) Replace the battery with a new one,connecting a voltmeter between the negative terminal and its cable. (An ampmeter of t least 10 amps capacity would be better.) With the key off, the meter should read zero. a reading indicates a short to ground somewhere. Trace all wires, look carefully where wires go through holes or past edges for bare or burned wires. When the meter reads zero, you can turn on the ignition and gingerly touch the negative cable to the negative terminal and watch for a spark, it should be small, assuming the ignition is battery operated, not by magneto. Turn on the lights should cause a slightly larger spark. A big spark and dimming of the lights means there is still a big short you have to find. Otherwise, turn off the key , hook up the negative cable, firmly but easy to disconnect, and try the system.
Jul 25, 2017 | 2005 Gilera Runner VX 125
6 pink lines verticle on 50 inch lg
this problem is related to lcd panel of tv. u need to unplug the tv remove back cover of tv, have a close look at cables connected to lcd panel. disconnect the cables & connect the cables again. if problem not solved, replace the lcd panel.
Aug 25, 2011 | Televison & Video
My car want start battery is fully charged. But the immobilizer light on the instrument panel stays on?
Having a full charged battery won't just solve the promblem. You might want to check with the battery terminal connection on the postive+ and negative-, It might be corroded, grease, or acid build up, so check for thse signs, also it could be that clamps are not fully tighten. You still can get power to the car from the baterry which in this case is leads to the immoblizer lights on the dash boards to stay on, but the terminal are corroded with acid, grease, or just from dirt, and with these element in presence, the battery is not fully ground. The engine needs a specific amount of amplitude from the battery for the engine to crank. A kia sorento v6 engine needs alot of cranking amp. So my solution is, check the battery connection terminal on the battery and the cable (positive and negative connections) de-tach the cable connections, clean the connection cables which are the adapter to the battery, and the battery terminals, with a toothbrush or high grit sandpaper until dirt, acid build up, grease are gone, and reinstall the cables. See if this will help.
Jan 03, 2011 | 2003 Kia Sorento
1994 Toyota 4 runner: I changed battery just fine; but can't get the fastener back in place.
I would make sure the fastener fits your battery and vice versa. Make sure it is not upside down or something like that. Is the replacement battery the same size as the old one? Battery REMOVAL & INSTALLATION NOTE: Refer to Section 1 for details on battery maintenance.
  1. Disconnect the negative battery cable from the terminal, then disconnect the positive cable. Special pliers and pullers are available to remove the clamps. Be careful of the many wires and fittings on and around the positive terminal. NOTE: To avoid sparks, always disconnect the negative cable first and reconnect it last.
  2. Unscrew and remove the battery hold down clamp.
  3. Remove the battery, being careful not to spill any of the acid. NOTE: Spilled acid can be neutralized with a baking soda and water solution. If you somehow get acid into your eyes, flush it out with lots of clean water and get to a doctor as quickly as possible.
  4. Clean the battery posts thoroughly before reinstalling or when installing a new one. A light coating of petroleum jelly or battery terminal spray protectant will help fight corrosion.
  5. Clean the cable clamps using the special tools or a wire brush, both inside and out.
  6. Install the battery, and the hold down clamp. Connect the positive and then the negative cable. Do not hammer them into place. The terminals should be coated with grease to prevent corrosion. CAUTION
    Make absolutely sure that the battery is connected properly before you turn on the ignition switch. Reversed polarity can burn out an alternator in a matter of seconds.
Jul 04, 2010 | 1993 Toyota 4Runner
Monitor will not diplay, like it's in perment sleep mode. I have unpluged it tried new cables, I am out of ideas, HELP!!
When you power up the computer press F8 key then enter in enable vga mode thne go to control panel and display property then change screen resolution to 1024*768 then check.But if you are not able to safe mode and other menu when you press F8 then follow below steps.1 by 1 and check.
First open cpu cabinet then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reattch ATX power connector to motherbord.
Reattch power cable and SATA or ide cable to harddisk.
Clean dust from all parts of motherbord.
Open processor fan and processor.
Then reattach both.
Make sure motherbord is not ground with cabinet.
Remove pci cards from motherbord then check.
Let me know if you need further assistance.Thanks.
Nov 13, 2009 | Dell VOSTRO SLIM TOWER and , MONITOR 19...
I am having the computer with Intel 845GVSR motherboard,P4 Processor,1 gb RAM Configuration. When i switch on the system, three beep sounds come and the system is not booting. But the RAM is in working...
For that first open cpu cabinet then refix RAM memory try it in defferent slot on motherbord.
Pull cmos cell from motherbord for 10 minutes so all settings goes to defaults.
Then open processor fan and processor then refix both.
Clean dust from all parts.
Reconnect ATX power connector to motherbord.
Reconnect power cable and sata or ide cable to harddisk.
If any PCI cards are installed then remove it from pci clot then check.
Make sure your motherbord is not ground with cabinet check in outside of cabinet .
Nov 10, 2009 | Intel D845GVSR Motherboard
Computer suddenly dies intermittently
Hi..
In this case when it is always beeping during the computer is on. You need to check the memory stick if it is not faulty. Remove the memory stick and clean it from dust. Clean also the memory slot and reinsert the memory stick. If the problem still occur try to use the other memory slot.
Regards
PCmania
Aug 28, 2009 | Packard Bell (181368) Motherboard
A diagram to assemble and dis- assemble to replace a new hard drive
http://repair4laptop.org/contrib/gateway_solo_9550/gateway_solo_9550_notebook_disassembly.pdf Will give you the diagram....but it shouldn't be needed. Bottom of laptop, with hinges facing away from you. Lower Right corner there is a 3 and a half inch panel. 2 screws removed, lift panel. There's your hard drive. If it's got screws holding it down...it should...then remove those screws, and gently slide it right until its out of the mount. reverse steps to install new one.
Apr 30, 2009 | Computers & Internet
EliteGroup P4VMM2 Motherboard panel connector diagram
the motherbord has a socket 478. you will need the correct bios version. here's is the link at ecs.com.tw
http://www.ecs.com.tw/ECSWebSite/Downloads/Archive_Download.aspx?CategoryID=1&MenuID=82&LanID=0&ln=1
here you should be able to solve your problem. if your need me again send the version. have a good one and please rate bama46
Apr 13, 2009 | Computers & Internet
USB cable connection to J-542B
if yr motherbord is not working properly so i give u some suggest
u r bught new usb card and plug in yr motherbord pci slot than u r connecting usb cable
Jun 30, 2008 | Intel Motherboard
Gigabyte GA-8SIMLH Motherboard Logo
241 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
