Home | Nikon | COOLPIX S10 Digital Camera | Lens error on nikon s10
Nikon COOLPIX S10 Digital Camera
Problem for Nikon COOLPIX S10 Digital Camera
By kjm5857vmcgo on Feb 15, 2009
I just turned it on and it showed me that message i dont know what to do , plssss helpppp.
kari
I have this same problem,how can I fixit?
KevMcgon
Solution #1
posted on Feb 15, 2009
Not Rated)
nematics
Rank: Wiz
Rating: 73%, 273 votes
may the problem with the lens internal part
Comments:
Feb 15, 2009
- Having a "Lens error " message display on the camera's LCD display indicates a problem with the camera lens mechanism. This situation generally requires that the camera be sent to a Nikon Service Department for repair. Before doing this however, be sure to check these situations below:
  1. One possible reason for this error is if the camera is switched on and the lens unit is prevented from extending. The camera will struggle for a second to extend the lens, then report the problem. Inspect the lens for any obvious obstruction, then turn the camera off, then on again. Usually, simply switching the camera Off then On again is enough to correct this problem.
  2. Remove and recharge and/or replace the battery. If the error does not clear up right away, leave the battery out of the camera overnight, and try again the next day.
Solution #2
Not Rated)
marked
Rank: Guru
Rating: 86%, 901 votes
You can follow this tips from Nikon web site
Popular Solutions for Nikon COOLPIX S10 Digital
Questions and Unsolved Problems for Nikon COOLPIX S10 Digital
Do you recommend Nikon COOLPIX S10 Digital Camera?
Answer
Answer
how to do turn automatic flash off and back on
Answer
I bought a new lcd screen and i have the camera apart but I'm not sure how to install.
Answer
Nikon coolpix s10 when you turn camera on it read lens error
Answer
the camera itself has a broken line going across the window but does not effect pictures.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nikon COOLPIX S10 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 610
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
