Question about Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook
Dell 6000 Inspirion wont boot after trying to replace RAM
I bought a new 1g ram stick and when i opened up the dell I noticed there were 2 256 RAM sticks. So i looked online to see if I can just replace one or if i needed to buy an additional one and I found a site that said you can just use the new one with one empty slot or you could add the new one to one old stick. So I tried both ways, neither worked. I put everything back to its original state and now it wont boot at all and have tried taking them out again and replacing them, still nothing. any suggestions?
  • danieltheexp Feb 15, 2009
    i just realized that I was not pushing the stick in all the way. I accidentally pushed it in all the way on attempt 6 and realized what the problem was. Thanks cpenzes
    Genius:
  • Dell Master
  • 1,102 Answers
Use ac power
try the 1 gig in each slot make sure it's secure.
If system still won't boot
then restart and try to get into bios setup
then set to default settings restart
if still not successful then replace the old ram make sure it's secure in the slots and restart
Then i would suggest taking new ram back and if you give them your make and model they can suggest ram for you
Posted on Feb 15, 2009
  • DEKR
    DEKR Feb 15, 2009
    OKAY GLAD I COULD HELP
    a lot of times that all it is just not seating the memory correctly
    anytime
    thanks for the rating
My Dell optiplex Gx240 wont boot after installing new ram . It saids stopped at check point vcls.
The new RAM has a problem. Insert one at a time and power up. You may have a bad RAM stick.
Oct 26, 2012 | Dell OPTIPLEX GX240 P4 1.7GHz 256MB 20GB...
I have a dell dimension 4600. It has original memory cards installed. 2 256 MB for a total of 512 ram. I recently tried to install 1 GB memory card. When I start up computer it beeps several times,...
hello
several beeps in a system is caused by a memory issue -- If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
the specs can be found at this link
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
the system you have is upgradable to 4G of RAM, and this RAM must be installed in equal pairs
so if you have 4 slots to insert memory in (assuming you will retain the 2 256M) , you must install the other slots by 2 512M, 2 1G or 2 2G DIMMs -- make sure you isntall exact same DIMMs, dont mix memory makers or specs, other than what Dell specifies
memory type must be
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
i hope this helps --
Dec 09, 2010 | Dell Dimension 4600 PC Desktop
Unit came with 2 256 mem sticks--bought and installed 2 1GB sticks(pc3200,400mhz,84pin,low density,DDR--unit will not boot
The 2 1Gb RAM are either the wrong type or they are incompatible.
Try to use the same brand and speed as the 256 Mb RAM that was installed in your Dell.
Jul 31, 2010 | Dell Dimension 3000 PC Desktop
I just installed RAM into my dell inspirion 6000 and had the caps lock and mum lock lights flash then the computer shuts off. I read the manual and I did install the RAM properly (removing the battery...
Please provide everything on the sticker of the memory. When you bought the RAM, was it a pair or did you buy individual sticks? Your system can only support a maximum of 2 GB of PC5300 DDR2 RAM, split over two 1 GB sticks of RAM per slot. If you have tried exceeding this, it will not work, and even if it were to, it would eventually cause irreparable damage to your system.
Good Luck,
NOLA Tech
Jan 29, 2010 | Dell Inspiron 6000 Notebook
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
Installed new ram-went from 2 512 sticks to 2 1g sticks, the comp wont boot, only the fans come on, no lights on the power button or signal to the monitor. I put the old ram back in to see if it would...
dose the ram have mem chips on both sides of the ram stick, sometimes this causes the problems, i would sugest that you clear the Cmos, maybe take out the bios batterie and leave it unplugged for couple of hours, plug it back in and see if the old ram works ok, if it dose then maybe try the new ram maybe one stick at first.
good luck.
Apr 02, 2009 | AOpen XC Cube EX661L (95EZ619321) Barebone
Beeps, wont boot up
Most of the time when it beeps, and there is nothing show on the computer screen, it is a RAM problem. A stick of ram may have gone bad. If you have two sticks of ram in the computer, you can try to remove one stick at a time to see which one might have gone bad.
Mar 23, 2009 | Dell Dimension 4700 PC Desktop
Dell 2400 ram upgrade problem
RAM can be finicky so first test all memory slots with a known good stick (your 512MB). Make sure you're starting from a complete power down and you get a POST beep (hopefully your system is set up to beep when it powers on) and everything loads up all the way through to your OS.
Once you do that with all your memory slots test with the new stick by itself in all memory slots. If neither of the memory slots work with the new stick but you verify that it works in another system you should then check your BIOS settings and RAM timings to ensure compatibility with your stick. If you can't find the timing on the RAM stick itself, look up the manufacturer's part number for the information.
Feb 03, 2009 | Dell Dimension 2400 PC Desktop
Error message after installing memory ram upgrade.....
The memory appears to be the right kind.
Try installing just one 1GB module, and run the diagnostics (press F12 at boot time and select diagnostics).
Dec 20, 2008 | Dell Inspiron E1505 Notebook
Blinking Lights, Computer Wont Boot
If it's blinking 9 times then it's likely telling you one or more of the RAM sticks are in need of replacement. To check these, remove the laptops power cord and battery, then locate and remove, the cover for the RAM. Remove one chip at a time and try booting the laptop.
May 25, 2008 | Dell Inspiron 6000 Notebook
Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook Logo
94 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
