Question about Toshiba Televison & Video
Black screen on lcd tv
My lcd tv has a black screen, but everything else seems to work fine. it just happened overnight, wasnt hit or damaged in any way. is it repairable by me or just by a professional? or should i just toss it away and buy a new one?
  • 37" lcd tv toshiba no problems untill now all of a sudden
  • its just started going blank .There was no damage to it
  • no hits or shaking. The screen goes out but everything
  • else is fine. can you please help us , should we repair it,
  • have someone else do it,or chuck it and buy a new one.
Shuttle83
  • 1139 Answers
SOURCE: Water Damaged lcd tv?
Hello lilcrozzyjc,
I got bad news, your son may have damaged the LCD itself since any water damage would have dried up over the three week period. To replace the LCD screen may cost the same as a new set. What I would suggest is that you take the Tv to a qualified Tv shop and have them check it. Be prepared to hear a high cost for repairs, due to the fact that the LCD (Liquid Crystal Display) screen might be damaged. I know this is not what you want to hear, but have the shop try to locate the cause of the problem and they might be able to suggest another recourse, such as by chance if the LCD screen actually is not dried out and the water is cauing a problem. In any event you will have to take the TV to a qualified TV shop.
I hope this helps,
Thank you
Shuttle83
Posted on Mar 24, 2008
jdbouncer
  • 72 Answers
SOURCE: lcd screen damaged by kid hitting on screen by buttter knife
The front main screen polarizer is damaged. Only two options are available for it. 1. Order a replacement panel, which will cost more that what u probably bought the tv for. 2. Buy a new TV.
Posted on Apr 30, 2008
SOURCE: CRACK LCD TV SCREEN
what you think a 40" lcd samsung screen or pannel cost to replace, mine just broke by my daughter.
Posted on Jul 02, 2008
1Guru
  • 61 Answers
SOURCE: Cracked LCD Screen on Sharp Aquos LC37D43U 37-Inch 720p LCD HDTV
Most LCD's just went down in price by around 2-400 dollars. I would suggest buying a new one. The cracked screen might mean that the liquid will ooze out and get worse and worse as it ages. However, it may only have a crack and not get any worse than it is now. If you can live with it and it doesn't get worse, you can view it that way for another 10 years and be fine.
The fact that the LCDs are cheaper now and you only have a 37 inch, you might consider getting a larger one that you have had your eye on for a long time. (Note: even though I am a firm believer in LCD's over Plasma, plasmas are a few hundered dollars cheaper and if you know your children are prone to breaking things... it might be the way to go.)
Replacing the screen is possible, but more costly than the new T.V.
Posted on Dec 12, 2008
bob_computer
  • 3153 Answers
SOURCE: Airsoft gun hit Sony Bravia LCD screen, can this be repaired??
Yes but not cheaply
Posted on Aug 10, 2009
2/3 of display is black
Strange could be video card issue or broken screen. try connecting it to TV or another monitor see if the picture is clear than video card is fine and display is damaged
Mar 02, 2011 | HP Mini 1000 Netbook
When Window Media Center start up, i get post, then XP Splash Screen, the mouse appears with a black screen. I started recovery to recover to factory default, it seemed to work fine for a week or so, then...
You have PC problem nto monitor problem since you can see the mouse.
Try booting in safe mode (hit F8) while booting up then go to system restore and set it back to the date you remember before the problem started.
Did you installed any new software or updates before this problem started?
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Nov 10, 2010 | Gateway 19" Flat Panel LCD Monitor
Damaged Insignia NS-L32Q-10A Screen
The damage actually occurred on the LCD (liquid crystal display) itself, not on the screen. Therefore, when the tv is switched off, no damage is visible. What happens is that when it is turned on, the liquid crystals "leak" because the display is broken. This is why you can see lines and a small dent. Depending on the tv, replacement LCD panels may be sold separately, though chances are that it would cost less to simply buy a new tv. Thanks for your post, and I wish you the best of luck! Sincerely, Der Strom
Apr 26, 2010 | Insignia IS-LCDTV32 32 in. Television
Screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
May 05, 2009 | Polaroid TLA-01511C 15 in. LCD Television
SAMSUNG 46 LCD 1080p series 5 - LE46A557P2FXXU - black screen
the x or y board may be bad in the set. i would say it is the main board.
Aug 11, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Lcd screen damaged by kid hitting on screen by buttter knife
Apr 04, 2008 | Philips 42MF531D 42 in. LCD Television
Panasonic Projection HDTV Made 9/2003
Your lamp has most likely blown out. that is what happened to mine and once I replaced the bulb it worked just fine. this is one of the cheaper stores to find a replacement bulb, www.bluestar-online.com
Aug 29, 2007 | Panasonic PT-40LC12 40 in. LCD Television
Televison & Video Logo
245 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
