Question about Compaq Computers & Internet
Problem installed linksay
Got disconnected from my conversation with marked
  • Compaq Master
  • 13,433 Answers
Hey,
email premium.support@fixya.com about issues with premium support.
Thanks,
Ekse
Posted on Feb 15, 2009
I put new HID headlight conversion kit in my 97 mark viii.y does my information center still read check headlamps?
computer is programed to monitor headlight circuit for a specific voltage , if that voltage is not being supplied , either over drawing or under drawing the information center message gets triggered. It thinks the bulb is burned out or something is wrong. Apparently the HID's are drawing more juice than the computer is used to seeing ,and it is triggering the message. The manufacturer of the hid kit should have warned you that this can happen,in it's description before you bought the kit.
Aug 04, 2015 | 1997 Lincoln Mark VIII
I want change my linksay routar key
Open the router page to change.
Aug 19, 2014 | Computers & Internet
Air suspension diagrams
If you are having problems with the Air-Ride, for example air pump not working, your best bet is to have a conversion kit installed. Do away with the Air-Ride and install coil springs and shock-absorbers. It is far easier and cheaper.
May 17, 2013 | 1996 Lincoln Mark VIII
Front air suspension not working
Or for under $400 you can buy a coil spring conversion kit from a company like
Arnott. Look for coil spring conversion kit exclusively designed for the Lincoln Mark VIII. The kit converts the entire vehicle to a reliable coil spring/strut suspension system. Also look for a kit the required no special tools and comes with detailed installation instructions.
http://www.arnottindustries.com/part_LINCOLN_yid2_pid7.html
Aug 26, 2012 | 1998 Lincoln Mark VIII
USB2.OUVC Webcam in messenger especially in video conversation (error ox8ac70013)
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jun 12, 2011 | Microsoft LifeCam VX-3000 Web Camera
I HAVE THE GAS REGULATOR AND LINE OUT OF DRYER,DO I DISCONNECT THE GAS LINE AT REGULATOR AND INSTALL THE CONVERSION AT THAT POINT,LOOKS LIKE IT WILL REQUIRE ME TO ALSO INSTALL A NEW LINE TO BACK OF...
No, the conversion requires you to change the orifice and adjust the regulator to LP. The instructions should tell you how to do the conversion.
Good luck
Sep 24, 2010 | LG DLG9588 Dryer
97 mark viii how to change air suspension conversion kit, and will i have trouble with the computer air ride system?
you can buy conversion kits from http://strutmasters.com with all the info and tutorials you will need but it's not an easy job
they will give you instructions to disable the air system
Jul 16, 2009 | 1998 Lincoln Mark VIII
Mark lt starter
disconnect batt,remove the 3 starter mounting bolts and ground cable(should be connected to one of the mounting bolts),disconnect the 2 wires on the starter.install new starter and then reconnect batt.
Nov 02, 2008 | 2007 Lincoln Mark LT 4x2 5.5
Computers & Internet Logo
15 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
