Question about Thermador DWU244 Dishwasher
Thermador dishwasher DWU244, error code "F" does not run?
Thermador dishwasher not running, shows F in panel. Sounds like motor is running but washer arms are not spraying and water is not moving.
  • lordantioch Mar 30, 2009
    I just got done re-installing mine (got it used) and have the same issue. it hums, but there is no sound of water at all and it displays an F on the info screen
  • 21 Answers
F code is a fill fault problem to much or to little water to determine the problem is to hit cancel drain buttons on the front of the machine and wait for cl on the display turn off machine and wait 30 seconds turn back on and the first thing you will hear is the drain motor turn on for 15 sec then you should hear the water filling into the machine if you dont hear water filing then check to see if the valve under the sink is open to allow water to fill machine
Posted on Jan 05, 2011
  • ms_stolar
    ms_stolar Apr 04, 2013
    My machine does not have those buttons?
  • Aynne Malmborg
    Aynne Malmborg Jun 03, 2015
    Mine neither??? I have F code too
What does the thermador dishwasher dwhd640jfp error code e:21 mean?
E21 Circulating pump blocked.
A blockage between the motor or the pump resulting in insufficient water flow.
Feb 22, 2015 | Thermador Dishwashers
Motor runs but
Do you have a print manual for this unit?
Aug 05, 2008 | Kenmore 18 in. 14432 / 14439 Built-in...
I had the same problem I own a Kenmore Elite dishwasher. Diverter motor needs to be replaced. The diverter motor is connected to a plate that controls the flow of water to each washer arm. When the plate moves it has holes that align to the proper tube that supplies water to a washer arm. When the diverter motor is broken it is unable to rotate and cannot direct flow of water. When this happens water will only be able to come out of one spray arm in my case the back sprayer or turbo wash. The diverter motor is located under the dish washer and the diverter plate is located under the bottom sprayer arm.
Dec 01, 2011 | Kenmore Dishwashers
My mother-in-law called and her dishwasher is making a loud noise when the motor runs. sounds like a bad bearing somewhere? the noise stops when it drains (motor not running?). does that sound like the...
There is only one motor -- it runs a water pump for recirculating the water when it's washing and runs a water pump when it's draining.
It sounds like the spray arm is making the noise -- this is the part thru which the motor / pump forces the water during the wash cycle -- the pumped water causes the arm to rotate -- a warn or loose spray arm or mount is likely the problem.
Or, it could be just some utensil stuck in the bottom of the dishwasher which the spray arm is rubbing.
More info, let me know.
Charlie
Jul 16, 2011 | Kenmore Dishwashers
The upper spray arm doesn't seem to be moving or spraying water properly. It does move freely
Assuming top spray arms are clear of debris It sounds like your pump/motor assembly is bad and needs to be replaced.Thanks
Feb 01, 2011 | Frigidaire 24 in. GSB5712BC Gallery...
Dishwasher arms do not spin
It sounds like your wash motor has failed to run at full speed to pump the water through the spray arms. The computer board will eventually report an "LE" error code for the motor's issue.
Jul 25, 2010 | LG LDF6810ST Stainless Steel Built-in...
My thermador dw44zs dishwasher: drain pump runs continuously when turned on even when the door is open. I can't seem to reset the cycle to allow for water to come into the dishwash
There are a few possibities...
if you remove the lid and take the two t20 screw off the left side panel at the front you could check the pressure chamber and its hose are not blocked. Use the link and go to page 4, part 0426 and 0424. You can also remove 0418 (remove t20 screw via the sump after all filters are removeds) this will expose the pump impellor and you can check for any obstruction. If the d/w is connected via a sealed spigot to the sink, remove the grey hose and unscrew the spigot adaptor from the sink and ensure there are no blockages. There may be water in the base of the d/w (base as below the tank, not under the filter) this will activate the flood safety, so check valve, hoses etc for leaks. You will have to manually clear the water from the base pan to deactivate the safety device. Sit the front of the d/w on a large towel and tip the whole unit forward, the base water will then come out. Whilst you have the side panel off, check that the red rod connected to the pressure chamber is not activating the microswitch.
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=DW44ZS%2f21&ESHOPTYPE=S
I hope this helps, Good Luck.
Jul 13, 2010 | Thermador DWU244 Dishwasher
Does not drain the water
Here is a tip that I wrote that will help you with your problem...
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Apr 23, 2010 | Thermador DWU244 Dishwasher
Why does my new dishwasher (in a new home)smell
You have to leave it open atleast 2 hours after the wash. Atleast the door left half open.
Or the smell must be flowing from your main drain pipe!!
Mar 30, 2010 | Thermador DWU244 Dishwasher
Thermador DWU244 Dishwasher Logo
1,469 people viewed this question
Top Thermador Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
DROPNDEAL
DROPNDEAL
Are you a Thermador Dishwasher Expert? Answer questions, earn points and help others
