Question about Bosch Classixx WFL 2066 Front Load Washer
Banging noise on spin cycle
I have a Bosch max classic front loader. It works fine until it goes onto the spin cycle then it makes a really loud banging noise.
    Genius:
  • 1,075 Answers
Most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Posted on Feb 15, 2009
SOURCE:
How come my bosch WA20261AU makes loud vibrating sound and its hot inside?
Hi Yvemarie,
Based on what I searched about the machine that you have where in the beep noise can only be hear at the end of the cycle not during the cycle. And also that noise can lower down and I will provide you steps on how to do that. It seems to me also that there is some kind of an issue on your machine since you said there was steaming and smoking happening, right? If the steps I will provide below works and still doing the same thing I guess you need to have that machine serviced.
    • 1 Press and hold the "Select" button on the electric display until the acoustic signal symbol, which looks like a small speaker-phone, is illuminated on the display.
    • 2 Continue to hold down the "Select" button until the system cycles through "Continuous", "Max" and then "Off" settings.
    • 3 Release the "Select" button when "Off" is highlighted next to the acoustic symbol. The signal noise is now turned off on the washer.
Read more: How to Silence a Bosch Washing Machine ' eHow.comhttp://www.ehow.com/how_7552735_silence-bosch-washing-machine.html#ixzz1fRDAKHrO
Apr 27, 2014 | Bosch Washing Machines
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Kenmore 43142 front loader bangs during spin cycle any ideas on what the problem might be?
always check the load to the drum is not to heavy on one side, this could cause it to bang.
Aug 25, 2012 | Kenmore Washing Machines
Bosch front loader wfl2400 is making loud banging noise when in spin cycle. Sounds like drum has coming of its mounts.
your main bearing is failing. this is a mayor repair issue. you need to call a repair expert. the bearing are molded at factory and require special tools to install. if you try driving them in by hammering you will damage them or wont last 3 to 6 month. depending on how old and how much you paid for the washer you may consider replacing it.
Feb 09, 2011 | Bosch Washing Machines
Bosch Maxx Classic front loader makes a loud banging noise before starting up spin cycle, and lately has displayed the E6 error message. Not sure what is causing this.
an addition.. pulled one apart, pulled drum apart and guess what I found.. the so called "spider"(the thing that attaches spindle that goes into bearing, and other side connects to the steel drum) is made if alloy and TOTALLY corroded by detergent.. Bosch didn't know that detergent is a corrosive substance???? I guess German engineers are .. put your own word.. ;)
Jan 13, 2011 | Washing Machines
Hi, my Bosch maxx 900 front loader washer was in the process of doing a load when a really loud bang happened..now it won't spin..makes all the right noises, but barrel won't move. Took off back panel and...
If you rotate the pulley on the back of the drum does it rotate the drum? i have seen these snap the back of the drum off. also they can have issues with the controller board for the motors which would require a technician to determine.
Oct 24, 2010 | Bosch Washing Machines
Loud banging when spinning
but a small load in . if happen then it sounds as if the bearings have gone at the back of the drum.
May 12, 2009 | Washing Machines
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
1,640 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
