Question about Whirlpool ED5SHAXM Side by Side Refrigerator
Water on floor and under the frigerTOR
Mod ed5shaxml11 water coming out from under the front,,,help
    President:
  • 842 Answers
Presuming that this is a self defrosting unit, the probability is that the condensation water from the fridge section is not being disposed of as it should. Most fridges have a little hole in the back rear of the refrigeration compartment. When the unit defrosts, the water runs down the back inside, into a little gully and through the hole. At the back of the fridge (Yep, you're gonna have to drag it out and look at the back) a pipe leads down from the hole to a little tray over the compressor pump. The compressor gets hot when it is running and the water in the tray simply evaporates from the tray because it is over a heat source. My guess would be that the pipe has moved and the water is no longer dripping into the tray, or something has dislodged the tray so water is leaking from it because it's not flat, or something fell in the tray, and took up some room, so it gets more water than it can take before it all evaporates. The water then runs across the floor and out the front of the fridge
Take a look arouns the back and see what is going on there, the solution should, I hope, be fairly clear.
Posted on Feb 15, 2009
I am experiencing water in the floor in front only, where could it be coming from?
Is this water or engine coolant? If it's water then the Air conditioning condensate drain may be plugged. Water can also enter if the body sealant has dried out where the firewall meets the body at the A post. If it's engine coolant then the heater core is leaking into the air box.
Sep 26, 2014 | 2004 Nissan Murano
Leaking clothes washer, water run out the bottom when started & floods the floor
CHECK YOUR DOOR GASKET / BOOT THAT IS MOUNTED IN FRONT OF WASHER DRUM. THE GASKET / BOOT MAY HAVE CRACKS, HOLES OR HAS COME LOOSE SOME HOW, ALSO MIGHT WANT TO CHECK ALL HOSE CONNECTIONS INSIDE AND OUTSIDE THE WASHER
Feb 09, 2013 | Maytag Washing Machines
Severe water leak on front passenger floor
look where the wiper are there is a black plastic cover under the wipers ilook under that cover there is one small hole on each side of the front fenders to drain water. those holes may be clogged and the water is run in and down side the heater box next to the blower motor
Nov 21, 2012 | 2006 Saturn ION
I have water in rear passinger foot well can you help
Sounds like someone left the door half opened or the window down just a little or your back window seal is leaking.
Jan 21, 2011 | 2003 Volkswagen Passat
Water in front passenger floor
there is a hose connected to the AC evaporator that goes through the floor ,this hose has come off the evaporator & needs to be put back on, there are also hoses connected to the heater radiator under the dash, make sure it only water & not coolant that is leaking......hope this helps........cheers
Jul 17, 2010 | 1994 Jeep Grand Cherokee
2002 Honda Accord Wet Floor
most common problem is the a/c condensor tube is clogged and is under the car and needs to be cleared with compressed air. also the sunroof track has 4 drain tubes and the right front may be clogged or leaking. you can check that by pouring a cup of water down the right front drain tube in the sunroof track and see if water comes out by the right front wheel
Oct 31, 2009 | 2002 Honda Accord
Water on floor under front of fridge
CHECK AT THE BACK OF YOUR FRIDGE IF THE DRAIN PIPE IS STILL ON THE COMPRESSOR. ON TOP OF THE COMPRESSOR THERE IS A BUCKET WHERE THE WATER FROM THE DRAIN PIPE RUNS IN. THE HEAT OF THE COMPRESSOR CAUSES THE WATER TO EVAPORATE.
Sep 07, 2009 | Refrigerators
Whirlpool ED5SHAXM Side by Side Refrigerator Logo
134 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
