Question about LG Heat cool Window Air Conditioner
Lg heat runs all the time
Hi, My heat runs all the time and dose not shut off.It blows cool air out for a while and then heat and then air is this normal operation of this unit or is there a way I can get it to shut off when it reaches a desired tempature.Thanks Chuck
  • 359 Answers
It sounds like you have the fan turned on. If you go to the stat, you should see an auto button, or switch for the fan. If you just switch it to auto, the fan will stop, and only start when the unit calls for it, hope that helps
Posted on Feb 15, 2009
LG LW2416HR window AC / heat unit problem. Compressor will not shut off or cycle. It runs all of the time. Please see below for details.
Has to be a stuck relay or contactor. I'm sure it's a relay on a circuit board so likely the whole board will need replaced. Never opened one up and don't see a wire diagram. But, if you need heating, unhook the compressor. Obviously wrap any bare wires, obviously cooling works but will have to turn off breaker to shut down. Temporary fixes obviously but will get you by. Best wishes!
Aug 15, 2017 | LG Heating & Cooling
Only blows cold air from from one side
The vacuum that runs the doors open and shut is went south try a new heating and cooling dash unit
Jan 20, 2016 | 2006 Honda Accord
We have 2.0 HP inverter wall mounted LG aircon, when we turn on the ac, the indoor unit only is running and shut down after 3 mins. What is the solution?
Hi Marie, does the green indicator light on the front panel flash after it shuts down? If it does...count how many times it flashes this will refer to a fault code diagnostic.
Keith.
Jan 02, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
Why did my ac quiet blowng heat
Check the controls, this unit most likely a reverse cycle air conditioner. It can be set to cooling or to heating. The conpressor is reversed to heat or running normally to cool.
If it is not then the compressor is not working and it is just blowing room temperature air.
Apr 03, 2012 | LG Heat cool Window Air Conditioner
It blows cold air for 5 min. and the it blows cool air for 15 min. the room warms up . Why does it stops blowing cold air continuasly???? The thermostat was disconectet on purpose so it coul clow cold air...
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
May 22, 2010 | LG Heat cool Window Air Conditioner
TEDX640PQ1 dryer, timer no longer times and heat does not come on. dryer will spin and blow cool air forever
HI. The timer is the principal initiator off all functions. If the timer module dose not time, or rotate properly, this will signal that the timer mechanism has failed. The timer will need to be replaced in this case. The motor is damaged.
Once the timer is replaced, the heat will return as well.
Oct 23, 2009 | Dryers
Split not cooling and not working on heat
make sure outdoor unit is running if it is may have low freon if not check power at outside unit
Aug 25, 2009 | LG LS092CE Split System Air Conditioner
LG Heat cool Window Air Conditioner Logo
155 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
