Question about HP DesignJet 1050c InkJet Printer
HP designjet 1055cm service error 0B0006
When i power on the designjet i keep getting the following error: 0B0006. i have recently replaced the electonics module and the trailing cable.
  • 1 more comment
  • plittle81359
    plittle81359 Feb 15, 2009
    I got this message after I replaced the electronics module, and at the time I noticed that one of the connections of the cable was broken, so I replaced the cable. After putting the printer back together I got the same error.
  • plittle81359
    is the main logic board part of the electronics module?
  • plittle81359
    plittle81359 Feb 16, 2009
    do you have a picture of the main board on the electronics module and which connection should be correctly plugged in? Also for the connections on the trailing cable, is the white bar on each cable plugged in - is it plugged in so it shows up as in working?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Based on service information, the Service Code 0B0006 indicates:
  • Trailing Cable has been incorrectly connected; or
  • fuse in the Electronics Module has been burned out.
Corrective action involves:
  • Turn the Printer OFF a
  • disconnect the trailing cable
  • Check that the ends of the Trailing Cable are flat and are not damaged or bent
  • Reconnect the Trailing Cable correctly, making sure it is pushed in firmly.
  • Do the resistance test.
  • Power ON the Printer and check if the Error Code disappears.
  • If the Error Code continues, replace the Main Logic Board.
Should all things check out, pls follow the procedures for a more detailed diagnosis as outlined in the Service Manual. This due to the possibility that the hard disk may also need checking/replacing.
Good luck and thank you for using FixYa.
Posted on Feb 15, 2009
  • Louie  Role
    Louie Role Feb 16, 2009
    Hi again,
    Appreciate the rating. The main PCB (printed circuit board) is the Electronics Module as shown below.
    To my knowledge there is no 'main logic board'. However, as shown below, there are:
    • DRAM DIMM (memory modules, item 3, blue in color);
    • Flash DIMM (programmable memory module, item 4, green in color);
    • EIO card (Input/Output interface card, item 5, yellow in color); and
    • Hard Drive (storage, item 6, pink in color).
    Were you able to download the Service Manual?
  • Louie  Role
    Instructions:
    Illustrations:
Error code :0a00100000001 what is this
Hello. The error 0A0010 indicates an air pressure system failure. The APS is located under the ink supply station on the left side of the plotter. The assembly can be ordered from: C6072 60387 Designjet 1050C 1055CM APS Air Pressure System
The service manual with replacement instructions can be downloaded from: HP Designjet 1050C 1055CM repair parts and accessories
Aug 13, 2015 | HP DesignJet 5500PS InkJet Printer
System error 0B000D 00000005
Hi, I believe this error occurs when there is no 24 volt supply to the PCB. Go back and check you have plugged all the connectors back in correctly.
Thanks
Sep 29, 2014 | HP DesignJet 1050c plus InkJet Printer
Hp designjet 5500 error code 0b0006
Hello. This error code indicates that the 5VDC and ground are shorted together by the trailing cable. Replace the trailing cable.
HP Designjet 5000 5500 parts
May 21, 2014 | HP DesignJet 1050c plus InkJet Printer
What is system error 0B0006 on Hp design Jet plotter? I have replaced the power cable but no luck
The Trailing Cable has been incorrectly connected OR the fuse in the Electronics Module has been burned.
Corrective Action: Turn the Printer OFF and disconnect the trailing cable. Check that the ends of the Trailing Cable are flat and are not damaged or bent. Reconnect the Trailing Cable correctly, making sure it is pushed in firmly. Do the resistance test. Power ON the Printer and check if the Error Code disappears. If the Error Code continues, replace the Main Logic Board
Note: The logic board is a direct replacement for the Designjet 1050C Plus and 1055CM Plus. If the plotter you are repairing is the Designjet 1050C (not Plus) you will also need to replace the memory and the firmware.
If you are repairing a Designjet 1055CM (not Plus) you will have to replace the Hard Disk Drive also. The firmware is identical for the 1050C Plus and 1055CM Plus
Note: The aerosol fan is not used in the Designjet 1050C Plus or 1055CM Plus. Coil the cable out of the way or completely remove the fan.
WARNING TAKE CARE WHEN CONNECTING THE TRAILING CABLE TO THE ELECTRONICS MODULE OR CARRIAGE. INCORRECT INSTALLATION WILL BURN THE FUSE IN THE ELECTRONICS MODULE, CAUSING THE COMPLETE FAILURE AND REPLACEMENT OF THE LOGIC BOARD. 100 OHMS OR HIGHER MUST BE SEEN AT THE TEST POINTS. CONSULT THE SERVICE MANUAL FOR CORRECT PROCEDURE.
Continuable and Non-Continuable Error Codes
Some of the Error Codes are continuable, which means you can press Enter on the front-panel and continue working with the Printer. Non-Continuable Error Codes do not allow you to continue working with the Printer, in this case power the Printer OFF and ON again and see if the System Error disappears. If the Error Code reappears, then the Printer requires service in order to resolve the problem.
System error codes are hexa-decimal based numbers generally caused by internal system errors. Only try one recommended action at a time and check if the error code has disappeared.
thanks and regards
kindly rate this solution
Feb 12, 2011 | HP DesignJet 1050c InkJet Printer
I keep getting System Error 0A0000 00000002
The error indicates low air pressure to the ink supply station. There is either a leak or the Air Pressure System (APS) is bad. Check for ink inside the rear door to the Ink Supply Station (ISS) and at the print head locations at the carriage.
If there is ink leaking at the ISS, replace the ink cartridge that is leaking. If there is a leak at the print head, replace the ink tube system. If there are no leaks, replace the APS. See the following link for parts: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Apr 14, 2010 | HP DesignJet 1050c InkJet Printer
HP DesignJet 1055cm Plus system error: 04C300 001F0000.
Its either the EIO card, make sure its seated properly, or the hard disk drive has failed in your plotter. Try running the plotter with out the hard disk drive, it is static sensitive, so make sure your grounded before removing it.
Mar 19, 2010 | HP DesignJet 1050c plus InkJet Printer
I have an error code of 0b0006 030f044c and Dont know what to do. please help.
Hi here is HP'S explanation for System Error 0B0006
The Trailing cable has been incorrectly connected. Recommended action Turn the printer off (using the power switch at the back of the printer), wait 15 seconds and turn the printer on. If the error continues, call HP for technical support to troubleshoot the problem. Thank you for using Fixya.com document.tlSearch.tx.value=unescape("")
Feb 09, 2010 | HP DesignJet 5000ps InkJet Printer
Error code 04C300 001E0000
This is an IO error. If there is a Hard Disk installed, remove it - the printer will run fine without it. If that does not solve the problem, remove the JetDirect card and run the test print. If the test print works, replace the JetDirect card. Parts available at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Nov 19, 2009 | HP DesignJet 1050c plus InkJet Printer
HP Designjet 4000ps printhead error
Plz Sir
Stape :: 1
Your Printer Cover Open Few Minitus
Stape :: 2
Plz Chek Your Printer Property .... And Delete Your Own Page
Stape :: 3 Plz Check Printer Property And Port Tab Chenge Selected Port
Enjoy
Aug 17, 2009 | HP DesignJet 1055cm InkJet Printer
The HP Designjet 1055cm has 4 ink cartridges, 4 printheads and 4 printhead cleaners. My question is: Will the plotter still work properly if I just install the black ink cartridge along with the printhead...
I doubt it. When the printer powers up, it checks to make sure that all modules are in place and functional. If one is missing, you'll get an error message.
Dec 10, 2008 | HP DesignJet 1055cm InkJet Printer
HP DesignJet 1050c InkJet Printer Logo
1,324 people viewed this question
Seeker5211
Seeker5211
