Question about D-Link AirPlus Xtreme G DWL-G132 802.11g/b Wireless Adapter
D-Link DWL-G132 ''Limited or no connectivity''
I have a 2wire modem that is connected to my Hp and i use my D-Link wireless adapter to connect my other pc (HP Pavilion a1600n) to the internet, everything was working well until I did a system recovery and then reinstalled the D-Link and get the Limited or no Connectivity message.
  • 3 more comments
  • balllakid2 Feb 15, 2009
    I don't see the settings, what are some of the settings?
    Okay how do i not let windows be the default device for the connection?
    Okay I think the problem has something to do with me not having an ip address.
    I think i have but i just checked the network on this computer and also lacks an ip address.
    Thanks for your help Tbirdfan1, problem solved! This was a complete waste of time I'm sorry. But again thanks.
  • 3,051 Answers
Hi there if you right click on your device than go to properties than look where it says configuer and click on it and look through all of the settings you will see that some of them are disabled and they should be enabled also a big one is the different link speeds and range so try these and see if that helps ok
regards mike
Posted on Feb 15, 2009
  • 6 more comments
  • Michael Thomas
    Michael Thomas Feb 15, 2009
    they should tell you like 801 or 501g or somthing to that effect mine was set to 1124 and it finally started to work also on my other computer i had to go to device manager and uinstall it and reinstall it from there if you dont have the setup disk at least than it will be set to default
  • Michael Thomas
    also make sure that you are not letting windows be the default device for the connection
  • Michael Thomas
    and one more thing if you had a good connection before you can try to move the computer to a nother area to see if you get any signal
  • Michael Thomas
    if you click on your wireless connection and under properties of the device it should be there ok
  • Michael Thomas
    have u tried the ipconfig/renew command that will renew the ip address if there is one available it takes a little time though ok
  • Michael Thomas
    ok so do this on your dlink right click on it and where it says repair click on that and once it does that check to see if it saying aquiring network address
  • Michael Thomas
    so what was the problem somthing simple or what
  • Michael Thomas
    hey if you would can u please give this a rating for me i would really appreciate it
Unable to connect Acer One D250 netbook to 2wire modem. Limited or no connectivity. I can connect through wireless at work and hardwire.Comments: Dec 30, 2009- Netbook sees the network, has excellent...
Replace the Cable and Check.
If the problem still persists then
Give the same network setting to the wireless network adapter as you assigned to your local area connection.
Note: Before doing that remove the IP address of that Local area connection or change it's IP address to some other number.
This will most probably solve your problem.
Otherwise, Used an external USB Wireless Adapter.
Jan 01, 2010 | Acer Aspire One PC Notebook
D-Link DWL-G132 just stopped working today, no flashing lights
You can try first connecting this device on different port and check if it will be working but if still not working, the next thing that you can do is to try this on a different computer and if still not working device is already dead...
Oct 09, 2009 | D-Link AirPlus Xtreme G DWL-G132 802.11g/b...
Is the DWL-520 Wireless Adapter compatible with the 2701 HG modem
The 802.11b and 802.11g Wi-Fi networking standards are generally compatible. An 802.11b router / access point will work with 802.11g network adapters and vice versa.
There is no such conflict reported with the above devices. But as suggestion use an 802.11g wireless card with the Bell as it would give you better performance
Thanks for using Fixya
proton
Jul 27, 2009 | D-Link Air DWL 520 802.11b (DWL-520)...
Can't connect wirelessly, "link light" not blinking
Please check,,Are you able to go online with Modem,If yes Then re-configure your router and restart your comp and check...i hope you can connect to internet..
May 21, 2009 | D-Link DWL-650+ AirPlus Enhanced 2.4GHz...
Found DWL G122 Driver
1.http://www.driverstock.com/download-D-Link-DWL-G122-driver/24-28-11275/index.html
2.http://www.driverstock.com/D-Link-DWL-G132-driver-download/24-28-11276/index.html
you got your driver just download it and installed it
Apr 01, 2009 | D-Link AirPlus G DWL-G122 802.11g/b...
Setup range extender
Access pointe bağlanmak için öncelikle bilgisayara elle ip adresi vermek zorundasınız daha sonra cihazı ethernet yoluyla bağlayarak ayarlayabilirsiniz.Ancak modeme bağlarsanız ip adresini ayarlamak gerekmez.Kolay gelsin.Good By
Jul 18, 2008 | D-Link AirPlus G Wireless Range Extender...
Please help!
complete setup process & user guide
D-Link AirPlus Xtreme G DWL-G132 802.11g/b > User Guide
Jun 03, 2008 | D-Link AirPlus G DWL-G122 802.11g/b...
D-Link AirPlus Xtreme G DWL-G132 802.11g/b Wireless Adapter Logo
303 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
