Question about Makita LS1013FL 15 Amp 10 Inch Dual Bevel Compound Sliding Miter Saw With Laser And Fluorescent Light
Makita LS1013FL manual missing
I need a manual for a Makita LS1013FL miter saw. Can anyone help?
  • ddwoodwork Feb 16, 2009
    There is no manual there.
  • ddwoodwork Feb 17, 2009
    Following your lead, and seeing the manuals for other products, I found the manual on Makita's Canadian site. Curious that it would be there and not on the USA site, oh well.
Http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/LS1013 then download manual
Posted on Sep 11, 2009
  • 2,176 Answers
Yes go to Makitausa.com and type in your model number and you can download an owners manual for the tool. Let me know if you need any more help
Posted on Feb 15, 2009
  • David Ford
    David Ford Feb 16, 2009
    I sincerely apologize, every other manual that I have needed is there. But to redeem myself they have a toll free number for tech support that I have used and they are great it is 1-8004625482 and ask them to fax or mail you a copy and if you still can't get it let me know, the rep will be in my shop next week.
How do I view the owners manual on line for a Makita LS1013 sliding miter saw
I have attached a link with the parts breakdown and the owners manual both in PDF format.
The parts breakdown should help you, if not let me know and I'll try to talk you through it.
Makita Products Tool Support
Mar 11, 2015 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
We need an op-erating manual for Makita miter saw, Model LS1013. Where can we find it?
Cut and paste the following link into your browser search bar, and you will be taken to the page that you need to get started:
http://www.makita.com/en-us/Modules/Search/Default.aspx?Param=ls1013
Then click on the appropriate full model number and you will next see links for the parts breakdown and manual for your saw.
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Good luck, and please provide feedback if this helps!
Dec 29, 2011 | Makita LS1013FL 10" Slide/Compound Miter...
I have an issue with a Makita Miter Saw "LS1013FL". I have read all of the previous solutions and had already done the tasks. Problem still persists, table dragging metal to metal-nothing...
they are aware of it. I have made mention numerous times to them. Did you try removing the table from the base and cleaning both surfaces with sandpaper and lubing before reassembling? I have used that method for years and it works for me. I have repaired tools for over 28 years and worked for Makita in the past and this was about the only way to help. Let me know if you need more detailed instructions.
May 08, 2011 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
How do i replace the light on my makita ls1013fl, specifically the wiring
The light should have its own harness that plugs into a connector. I have the breakdown with the breakdown and wiring diagram if you want a copy just email me at phoenix.repair@hotmail.com or go to phoenixrepair.org. Hope this helps you.
Rob
Oct 14, 2010 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
My 10 inch mikita slide saw just quit working. I tested the trigger switch and it seems to be fine but the saw motor won't run. Does anyone have any ideas?
Try another tool in the same power outlet. It may have popped a breaker. Make sure the blade turns freely. Does the motor have brushes that should be looked at? Hope this helps!
Apr 16, 2010 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
I need a repair manual to show assembly of the power switch
Not sure about the repair manual.. here is a link to the schematics I used:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/LS1013FL
For better view use the PDF version.
Jan 08, 2010 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Makita ls1013fl I need instructions on how to install
I installed it by looking at the parts pictures in the manual and experimenting. Thanks for the try at helping me.
Joe
Dec 14, 2008 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Makita LS1013 miter saw motor runs very slowly
Could be a bearing problem. If the bearings are dry and seizing up they will hinder the motor speed. Alternatively, if they are worn and allowing lateral movement in the motor the armature will rub against the field windings when it all magnatizes (sp?). I would investigate bearings before electrics. Hope this helps, good luck.
Nov 24, 2008 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Makita LS1013FL 15 Amp 10 Inch Dual Bevel Compound Sliding Miter Saw With Laser And Fluorescent Light Logo
1,407 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
