Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire gltf2940 will not pump water into the machine.
The water will not pump into the washer, then it will not spin and makes a strange buzzing noise as if it is trying to work. We tried replacing the door latch, but that does not seem to be helping. Does anyone know what is going on with this thing?
  • 6,784 Answers
Hi there, here's a few check points that should help you fix this issue with the water.
• Water supply is not adequate in area. Check another faucet in the house. Wait
until water supply and pressure increase.
• Water supply faucets are not completely open. Fully open hot and cold faucets.
• Water is being used elsewhere in the house. Water pressure must be at least 30
psi (260 kPa). Avoid running water elsewhere while washer is filling.
• Water inlet hoses are kinked. Straighten hoses.
Next, here are some tips fixing the spinning issue as well.
• Washer door is not completely closed. Close door completely.
• Dispenser drawer is not completely closed. Close dispenser drawer.
• Load is too small. Add 1 or 2 similar items to help balance the load.
Thx for using fix ya.
Posted on Feb 15, 2009
  • Frigidaire Master
  • 3,051 Answers
Hi there your machine it will not spin because there is no water in the unit so that is telling you that the float switch is working but the problem appears to be in the water fill solinoid valve that is located inside the back of the unit if you can contact your local apliance dealer you should be able to get the part that u need ok and also you may want to see if there is still a warranty on the unit that would help a lot
best regards mike
The tub will not spin out the water. it makes a loud buzzing sound. Does not work in the spin cycle.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 05, 2011 | Frigidaire ATF6000ES Front Load Washer
E20 error code on gltf2940
The problem is with the pump, or drain hoses.
This caused because there are some things like coins dust blocking the water path.Clean the pump and drain pipe ,this will solve the problem
Thank You
Sep 13, 2010 | Frigidaire GLTF2940E Front Load Washer
Frigidaire Affinity Glacier Stackable upright washer. Washer will not agitate and makes a buzzing sound from the pump that extracts water from the drum. Water collects and remains in bottom of washer.
heatman101
Aug 29, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Buzzing - will not spin or drain water
This noise is probably the pump trying to start but will most likely be obstructed.Drain the machine manually by lowering the drain hose into a bucket or bowl and then remove blockage.
Nov 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer making buzzing sound during spin cycle,then stopped during wash still has water in tge clothes,buttons light up as if going to work but nothing happens jusy buzzing noise
If I understand correctly, the washer made a sound in the spin cycle but didn't actually spin the clothes dry?
If so you may have something in the pump that is not allowing it to pump out. Disassemble the pump and make sure it is clear of any debris.
Jul 21, 2008 | Frigidaire Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
213 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
