Home | Olympus | EVOLT E-510 Body Only Digital Camera | 510 will not take a pic...
Olympus EVOLT E-510 Body Only Digital Camera
Problem for Olympus EVOLT E-510 Body Only Digital Camera
510 will not take a picture with attached flash
By angie_stockl on Feb 15, 2009
My Olympus 510 will not take a photo with the attached flash. I am getting a red blinking flash symbol that (according to the manual) indicates that the flash is charging. I have not seen this before and have been getting the same blinking symbol for the past hour. It will still take photos without the flash. Anybody know how to fix this?
Same Problem
May 12, 2009
-   The attached flash pops up but I get a solid red lighting bolt on the menu screen and the flash will not fire, even in fill flash. Olympus said that it is most likely a broken flash tube. Any one having the same problem? My camera is only 8 month old. I thought the flash tube would last longer than 8 months.-   mikey747
May 02, 2009
-   same exact problem...but happened after dropping the camera! Need a fix!!-   Guest
Apr 29, 2009
-   I had the same problem with the built-in Flash. If it deems that the flashlight is needed, then the shutter can not work!-   yuewang25
Popular Solutions for Olympus EVOLT E-510 Body Only
Questions and Unsolved Problems for Olympus EVOLT E-510 Body Only
Do you recommend Olympus EVOLT E-510 Body Only Digital Camera?
Answer
Answer
I guess the solution to my E510 pop up flash creating a shadow when my 9-18mm lens is on, is to use... (More)
Answer
olympus e-510 software freezes after a few shots and the is locked. needs to shut it off or in some... (More)
Answer
the on off switch doesn't always work. you have to fiddle with it to get it to work. and if you turn... (More)
Answer
same here, with both double zoom kit lenses and 14-54 mk2 lens
Answer
Olympus e510 Appears to be similar to some below. Recently autofocus, and shutter do not clode in... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Olympus EVOLT E-510 Body Only...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
