Question about Jenn-Air JCD2295K Stainless Steel Side by Side Refrigerator
Jenn-Air not Cooling...
I have a Jenn-Air JSD2789GES that made a some noises, like gergling type, a few times. Today it seems to not be cooling. Lower shelves are cooler but upper items seems almost room temp. I have turned the freezer temp up and turned up the refrig. to coldest to see what I will get from that. The unit is 5 years old and have not had problems to date. Do you know what may be wrong? It seems as though others have had the same problem from what I have read. Please advise, I would greatly appreciated it.
    Problem Solver:
  • 13 Answers
Sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
Posted on Jun 03, 2010
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
First the refrigerator portion lost cooling but the freezer was fine over time the freezer esentially turned into a refrigerator. It is no longer making ice or keeping things frozen, but is about as cool...
the evaporator coil is frozen over and cant release cold air due to this,defrost the unit remove rear panel inside freezer and troubleshoot the defrost heater and thermostat and also make sure the fan near this coil is running, on the evaporator coil as,you cant blow cold air thru a coil covered by ice
Jul 02, 2011 | Jenn-Air JSD2789GES Side by Side...
Water not draining to pan when defrosts draining into freezer causing ice build up at bottom of freezer
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 15, 2011 | Jenn-Air JSD2789GES Side by Side...
The inside of the freezer is collection frost/ice
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 25, 2010 | Jenn-Air JSD2789GES Side by Side...
Fridge not cooling
We will need to see if yours has the defrost timer or the adaptive defrost. Let me know if your model is the JSD2789GES. I have the manual we can work with. ..Sea Breeze
Jun 19, 2009 | Jenn-Air JSD2789GES Side by Side...
Jenn Air Freezer Works, Refrigerator Does Not Cool
check the damper which provides air flow to the fresh food side
Jun 07, 2009 | Jenn-Air JSD2789GES Side by Side...
Jenn Air side by side is not cooling
Check the compressor and see if it is running. If not it is the run\ start relay.
Apr 06, 2009 | Jenn-Air JSD2789GES Side by Side...
FRidge and Freezer not cooling
I had the same promblem on my Jenn-Air. I replaced the relay on the compressor and fixed the problem.
Jan 06, 2009 | Jenn-Air JSD2789GES Side by Side...
Regrigerator stopped, now freezer too.
It is due to the defrost timer is not working. Once it is replaced, you should be good for another year. The information is given by the repairman. I have this replaced two days ago. The MayTag part number is: 61005988.
Aug 07, 2008 | Jenn-Air JSD2789GES Side by Side...
Jenn-Air JCD2295K Stainless Steel Side by Side Refrigerator Logo
152 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
