Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
51: toshiba wide screen hd tv
Have faint verticle black lines running all the way acroos screen. is there anything i can try myself or do i need a service guy. tried the convergance and unplugged for several hours, no help. thankyou
kerry williamsvertical lines across screen,when i turn it of it is really scrambled till warms up
    Sergeant:
  • 326 Answers
It indicates that the problem is with the main board in display section.it needs to bechecked with a volt meter to check what part is gone faulty on the board.the faulty part needs to be replaced with minor repairs on main board.contacting a local tech to do the repairs is very much advisable.
Posted on Feb 15, 2009
  • 1,183 Answers
HI,
The vertical lines, on the screen are caused by a bad display board. Its seldom caused by wrong settings. I would suggest you to call in a service guy for repairs.
Thanks
proton
    Brigadier General:
  • 8,619 Answers
Hi
Are the lines thin or thick? Since when are you facing this issue ?
Try to change the channels and tune it
  • Rylee Smith
    Rylee Smith Feb 15, 2009
    Also check the connections at the back and see if the signal cables are fine.If you are using HDMI cable then check for any broken or loose connections.
Toshiba Model 51h84
The wavy when cold is a issue with a board in the set--Hyper board--the warmup until it begins to work will gradually get longer and longer.
The blue: look at set on a unused video input--if see faint curved blue lines with some blue visable on the screen the blue screen control needs to be adjusted just slightly down until the blue and curved lines are not seen.
May 15, 2012 | Toshiba 51H84 51" Rear Projection...
My 32 inch samsung lcd tv has got faint black lines running down the screen ,its nearly 4 years old but i expected it to last longer than that,and ive had sky hd box recently would that have anything todo...
Are these lines on both side of the screen or what location are they in? They can be caused by watching 4:3 television with the black bars on both sides. Watching 16:9 full screen HD wont cause issues with that. If only on the sides there is not much you can do except put a pure white screen on the TV and leave that on for at least 6 hours. This will age the panel a little but in theroy wil even the pixel burn you have to make the lines less noticable. Please take a few moments to rate my answer. Thank you
Nov 18, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Thin black verticle lines on screen some disappear when warm toshiba wide screen tv
The post is a bit confusing. However, I have a Toshiba 42rv530u model where vertical lines appeared. Tech came out and ordered a new panel. It sounds like the same situation with you.
Nov 09, 2009 | Emerson Televison & Video
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Faint black lines running vertically
did you try unplugging everything and resetting your cable box. then plugging it back in,
i got some faint boxes yesterday and that did the trick
Jan 02, 2009 | Toshiba 42HL196 42 in. LCD HDTV
Verticle black line
just on a whim I'd say you have vertical output IC circuits in distress.
can you say Warrenty :->
Jun 10, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Problems with my Mitsubishi hd1080
Most likely you are looking at conversion chip problem. The replacement price on these can varry widely. It may be cheeper to look into purchasing a flat panel lcd or plasma tv.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba CZ32V51 32" TV
that indication is that the verticle amplifier is fault,
chec the verticle IC
fusable resistors
capacitors eletrolitic
the problem will be over
May 06, 2008 | Toshiba CZ32V51 32" TV
51 big screen apex tv, convergence or verticle IC?
If the lines are thin and close together running horizontally, it may be the vertical driver, but that usually takes out the resistor and sometimes the diode in the B+ for the vert. Also you must replace the caps that caused the problem in the first place.
Feb 05, 2008 | Apex Digital GB5108 51" Rear Projection...
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
75 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
