Question about Dynex DX-E401 Router
Help, Can't connect to IP adress
The IP adress is
Try or
Posted on Feb 15, 2009
2 Suggested Answers
  • 22 Answers
SOURCE: set up router/modem as instructed
Problem can't be solved as described, a fixer would need more details.
What kind of modem/router is it?
What instructions are you working from so far (you say, "as instructed" so I take it you're looking at a Quick Start Guide of some sort?)
How are you connected to it?
What http address are you going to (E.g. some routers use, others or various alternatives)
What happens when you enter that address on a browser?
Have you set your computer's address to a nearby address so it can talk to the route?
If I had one guess with not enough information, I'd say you need to set your PC to an address one different from the target you're going to.
Posted on Jan 10, 2011
To have an IP address, your TV must be connected to a home network or the internet...Is your TV a internet-enabled TV?Then there are three ways..
a) On the TV, go to network settings
b) From your router, check the DHCP table of the clients, if your TV is connected to your network, its IP should be listed.
c) Visit and get the IP.
Mar 01, 2014 |
Trying to connect Apexis camera to internet
Hello you can download a manual here if you don`t have it:
Here is a orange live box fault finder:
The IP camera must probably have a static ip adress in order to work.
When the ip adress is dynamic the software can`t find the camera everytime you turn on your pc.
You can buy a switch to connect between your pc and the modem
and connect the camera to the switch.
But you have to install the software again.
Good luck
Dec 14, 2012 | Apexis APM-J802-WS Wireless Wired Pan Tilt...
Can not find ip address on richo 1035. I tried to connect my richo 1035 with computers through internet. I did all to change ports on printer properties section. I am putting ip address of my service...
Connect the machine to a router or a switch with a network cable.
In used mode, under network settings - set the machine to DHCP, so it will get an IP adress from the switch/router.
Print out a network status page, and see if you've got an IP adress.
In the command window on your PC type: ipconfig/all and see the IP adress of your computer. Compare it to the adress the machine got from the router/switch and see if they are almost identical apart from the last digits.
Install the driver, and install the printer using device name, and you should be good to go. Or you can set the IP you got from the switch/router as a static adress, and install the copier using the IP adress.
Jun 27, 2017 | Ricoh Aficio 1035 Copier
Hi ..I can't connect to my yahoo messnger..And it says here's the problem..hope u can help me.. Checking virtual IP servers... [VIP Raw] Resolving host name [PASSED] [VIP Raw]...
can you get an internet connection?
click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in
check your firewall settings make sure yahoo is allowed
click start type in cmd press enter
you should have a black screen you are in dos mode
type in ipconfig
you should see all of your connection details
type in your default gateway adress into your browser (search engine)
hope this helps you
Oct 18, 2011 | Yahoo Messenger
HP 1312 printer running wirelessly from a laptop (Windows 7). Has always worked fine. Turned printer off when we were on vacation; now printer is "offline." Have reinstalled printer driver and...
The problem you described can have multiple causes.
But one is more common:
Every device on your home network (wired or wireless) has its own IP adress. Usualy this IP adress is given automatically by the DHCP server contained in your wireless router. When a device is turned off for some time, it can receive when turned on again another IP adress than before.
So, if your printer has no static IP adress (entered by yourself during printer setup), it is very likely that it has now other IP than the address known by your computer. The computer sends the print jobs to the old adress and of course, nothing is printed.
Please check in your printers proprieties the adress of the TCPIP port assigned tom it, and also check on your router's management site what clients are connected to it.
The network communication between the computer and the printer can be checked by issuing a PING command from a command prompt.
e.g ping 192.168.1.***
the numbers are one example of an IP adress.
Please let me know if it helped, if you need more help ask again, I'll be glad to help you to get the problem solved.
Aug 21, 2011 | Office Equipment & Supplies
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Can you tell me what an ip addresse is im trying to connect to xbox live and it keeps asking for ip addresse
Every device connected to the public internet is assigned a unique number known as an internet protocol (IP) address. IP addresses consist of four numbers separated by periods(also called a 'dotted-quad') and look something like
since these numbers are usually assigned to internet service providers with region based blocks, an IP address can often be used to identify the region or country from which a computer is connecting to the internet. an IP adress can sometimes be used to show the users general location because the numbers may be tedious to deal with, an IP adress may also be assigned to a host name, which is sometimes easier to remember hostnames may be looked up to find IP adresses,and vice-versa. at one time ISPs issued one IP adress to each user. These are called static IP addresses. beacuse there is a limited number of IP adresses and with increased usage of the internet ISPs now issue IP adresses in a dynamic fashion out of a pool of IP addresses (using DHCP). these are referred to as dynamic IP addresses. This also limits the ability of the user to host websites mail servers, ftp servers, etc. in addition to users connecting to the internet with virtual hosting,a single machine can act like multiple machines (with multiple domain names and IP addresses).
Jan 30, 2010 | Microsoft Xbox 360 Elite Console
Wep address
Your wep adress? You mean your IP adress? Go to and that number is your IP adress. Enter that manually, and your XBox should be connected.
Jul 03, 2008 | Microsoft Wireless Network Adapter Xbox...
Since you have one computer connected, try to go to linksys website. I think it is a problem with your IP adresses. If you connected your laptop and it is using the IP adress of one of the two computers, and you turn on one of your desktop, Maybe, there is one IP adress reserved and there is a conflict.
Only an hypothese...
May 21, 2008 | Computers & Internet
Computers & Internet Logo
70 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
