Question about Kenmore 46462 Front Load Washer
Kenmore washer won't spin out water, lights blinking
I have a Kenmore HE2 Model #110.4646,4647. The washer will run correctly (as I know it) until it is to spin. The washer will not spin on high, as the clothes are still soaking wet when load is done. We have done a pump test and seems to be pumping out water just fine. We have also cleaned the pump "screen". I have no LED screen just a dial, when the washer is done all of the lights around the dial will blink but the Add Garment light remains lit. PLEASE HELP!
  • 15,935 Answers
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Kenmore HE2 problem
Blocked filter/pump probably,,,won't spin unless water been emptied out
Jun 17, 2013 | Kenmore HE2 Plus Front Load Washer
Kenmore HE Washer Model 11046472501 - add a garment light stays on with the door lock light on at the same time. We have unplugged the machine and ran the drain and spin mode, but he washer won't
Not sure if these will help or not:
http://www.youtube.com/results?search_query=Kenmore+HE+Washer+diagnostics&oq=Kenmore+HE+Washer+diagnostics&gs_l=youtube.12...4054.11443.0.13769.12.12.0.0.0.0.236.2449.1j0j11.12.0...0.0...1ac.1.93rgz26enSw
Jan 26, 2013 | Kenmore Ap4327152 Motor Control Board for...
Kenmore HE2 Won't Turn On
1) test the power cord for open 2) test the outlet box, see for blown fuse or c.breaker put some desk lamp and see if work 3) test inside of the control board if there fuse blown or c.breaker tripped 4( test the lid switch is closed, can be faulty or open replace 5) test the input voltage 115 if there are the control board faulty.
Jul 18, 2012 | Kenmore HE2 Plus Front Load Washer
Lights blink on settings around the knob won't run from there
Your door switch is not working, the machine thinks that the door is still open.
Mar 11, 2012 | Kenmore HE2 Plus Front Load Washer
I have a model #110.47561601, Kenmore HE2t Front load washer Type 832. I am getting a code of F-24, when I try to start the cylce. What is the problem that prompts a F-24?
Hello
F-24 is a water temp snsor error.Try running the machine in spin and drain.Once empty unplug machine for 3 min.Then try load of wash again.This time use cold water until error clears.
Aug 27, 2011 | Kenmore HE2 Plus Front Load Washer
The washer power is on, everything seems to work but the water won't come on at all, then all the lights start flashing.
If i got you Correct - Water is not entering the Washer? Am i Correct?
OK,
Few more Details :-
1. Make and Model of the washer?
2. How old the unit is?
3. Any Smell, Noise or Error Message?
4. Any Sequence of Blinks?
Thanks!!
Jan 10, 2010 | Kenmore HE2 Plus Front Load Washer
Code error problem
THIS IS TEMPORARY FIX, NOT A TOTAL SOLUTION. jUST TO GET WATER TO DRAIN AND RESET WASHER. , WITH WASHER POWERED OFF, PUSH AND HOLD START BUTTON FOR 4 SECONDS, RELEASE FOR 4, PUSH FOR 4 RELEASE FOR 4 UNTIL THE FRONT ALL LIGHTS UP AND DISPLAYS 88. sOON YOU WILL SEE YOUR CODES FLASHING, PRESS START BUTTON AS MANY TIMES NEEDED TIL NO MORE CODES FLASHING. tHEN WASHER WILL GO INTO DIAGNOSTIC TEST. aFTER THAT I DO NOT KNOW, BUT YOU CAN WASH 1 LOAD OF CLOTHES AND THEN PERFORM DIAGNOSTIC TEST AGAIN. THAT IS WHAT I AM DOING JUST TO HAVE A WORKING WASHER TOO MUCH TO FIX FROM WHAT I AM READING, SO GOING TO BU A NEW ONE ANYTHING BUT KENMORE. gOOD LUCK, HOPE THIS HELPS FOR IMMEDIATE RESCUE.
Jul 24, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 front load washer. All cycle lights flashing plus spin and clothes clean lights on.
I'm sure this is probably too late, but hopefully it will help some else. I just had the same problem. First, unplug the power. Then take the lower front panel off and grabbed a bucket. Place the bucket under the large "plug" on your right. This is the drain. Slowly unscrew the drain plug, Hold your nose as it will probably smell. Allow the water and such to drain into the bucket. When you see the blob of wet lint drop into the bucket you will know why the machine refused to work. Make sure you clean the drain plug and screw it back in tightly. Put the lower panel back on and reconnect the power. I hope this resolves your issue.
Apr 26, 2009 | Kenmore Washing Machines
Kenmore HE2 flashing lights
did the technician point out wat needs to be repaired
Aug 24, 2008 | Kenmore 46462 Front Load Washer
Kenmore 46462 Front Load Washer Logo
782 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
