Question about Poulan Garden
Poulan chain saw won't stay running
Saw will start with choke on bt revs up and dies when taking off choke
  • Anonymous Mar 27, 2014
    Choke wont stay out to start chainsaw
    President:
  • 2,692 Answers
Carburator needs to be removed and cleaned.
Posted on Feb 15, 2009
What are the air and gas settings for a poulan micro XXV chain saw
adjust the L screw in fully till right in,then out 1.5 turns,same with H screw.Then start saw,adjust L screw in or out slowly till you get max revs.You may need to lower idle via idle screw if revs too high.When screw cant acheive better revs,reset idle.Then,rev saw to max revs,adjusting H screw to get max revs,then when max revs acheived,turn screw anti clockwise 1/4 turn out.That gives it enough petrol to cool the tip of the plug
Aug 12, 2014 | Garden
Chainsaw runs then dies
Carburetor needs to be overhauled and replace all fuel lines and fuel filter.
May 06, 2014 | Poulan Pro Chain Saw. 18 in. 42 cc Gas...
Poulan chainsaw, I rebuilt the carb with all new everything. Now it will start with choke all the way out. Idles really high. If I push choke in, it dies instantly. The hi-lo and Idle is off I know for...
get it running on idle,adjust the idle down till it runs hairy,then adjust low speed mixture screw till you get it highest revs,then keep repeating that till you get it idling normal.rev saw up max revs,adjust high speed jet, in or out till you get max revs,then screw out one quater of a turn.That lets enough fuel thru to cool the sparkplug tip..If thats no good,redo the carbi.Check the tiny filter under the needlevalve hole.Check the needlevalve diaphragm height.recheck gaskets are right way round
Nov 03, 2013 | Husqvarna Chain Saw 20" Bar
Poulan 2150 chain saw starts after priming and dies after a few seconds
Take the exhaust off so you can see the side of the piston, if it is scored or damaged it means it has probably been run without oil added to the petrol.
That can cause the problems you are having, if it is throw it away, its not worth repairing
Dec 14, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
Replaced all fuel lines and pickup fuel filter. but won't stay running without choke.
Take the carburetor off and clean it and check and replace any air filters you may have. Can't say that this will fix it ,but it is a starting point for you. Hope it works and good luck.
Dec 01, 2012 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Wild thing chainsaw won't stay running. I replaced all fuel lines, primer bulb, fuel filter, gaskets to the carb. and have cleaned the carb out very well and blew out all passages. I pulled the spark...
On the carburetor got two screws to adjust the carburetor. The first is to adjust the saw when working at high speeds. Another is when running at low revs. It is best to either put back for about 1.5 cycle of the maximum of the end of the rotation of the screws. If then the saw starts, then you can adjust it fine at higher revs (H), then at low (L). Have can be minimum screw that stops the chain.
Sep 01, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
The choke on a Poulan Chain Saw that I just bought will not stay out to start it.
There are two types of choke systems, the basic choke has a ball and spring in the carb body which locks the choke either in or out, the other type is connected to the half throttle position, once pulled out it stays out, however if you lift the throttle trigger it will go back in on its own, queation, are you holding the throttle trigger whilst trying to start it, if so this is why it will not stay out, if this is not the case, pull the choke out with a little more force, it may be just not coming out enought to lock.
Feb 28, 2011 | Poulan Pro Chain Saw 46cc 20"
18"poulan chain saw wont rev up
carbs dirty need cleaning. try adding some stabil you can buy at auto zone with fresh fuel it may clean itself out w/o having to remove the carb.
Sep 14, 2009 | Poulan PP4218AV 18" Chain Saw
Need carb h/l ajustemts and idle controle ajustment
This does take a little time to get it just right. Start at one full turn for the h and l. Work on the high first and after you get the H running work on the Low. They have to work together. So if you get it to idle and run at full throttle but it hesitates when you pull the trigger just adjust the low a little higher.
May 02, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
992 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
