Question about Syntax SV266AD Motherboard
How do I access the bios on my Syntax SV266AD motherboard
My screen is moving too fast for me to see the option keys to hit to enter my bios. Does anyone know what the keys to press are? Thanks.
  • neilevan814 May 11, 2010
    Thank you, this is ringing a bell, I believe I have to hit f2. I'll check back with you . Thanks a lot.
  • 102 Answers
Usually with AWARD bios you press DEL key at boot.
Some companies change this to F2.
Try these first if neither works repost here and well work some more.
Posted on Feb 15, 2009
    President:
  • 2,110 Answers
Press F2 OR Del or Esc Key while booting ...
How to enter bios
Hit the delete key during boot-up to access BIOS
Feb 03, 2014 | OEM Production 2550L2D-MxPC Black Mini /...
How to use a usb keyboard
as a P/S2 keyboard.plug it in the USB contact in the back.in any USB port.
Apr 08, 2013 | Dell Inspiron One 2305 Desktop Computer...
Keyboad failure on dell gx520 boot
Usb or Ps2 keyboard ?
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Enter bios restart your computer you will see a certain to press to enter set up usually the Delete or the F2 key this will vary depending on you computer and bios. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Enable PS2 & USB in BIOS You can enable PS2 and USB settings in BIOS by entering the BIOS setup screen when the computer boots. You will need to changes to the appropriate settings in this screen. The exact procedures vary by system, but there are a few common methods that may work if the motherboard manual is not available for guidance. The general procedure is the same for any modern computer system, but the menu arrangement and keystrokes to enter the setup program can vary greatly from one machine to the next. Power on or restart the computer and watch the initial boot screen to find the keystroke required to enter BIOS setup. This is often shown at the bottom of the screen. Typical keystrokes include pressing the "F1," "F2," "F9," "F10" or "Del" key. Press this key when the prompt appears on the screen. You can find the proper key in the computer's motherboard manual or on the website of the motherboard or computer manufacturer. Enter the BIOS setup screen and look for the "Advanced" or "Onboard Device Configuration" menu. Use the arrows to select your choice and press "Enter." Change the settings for the PS2 port by moving the menu choice to the "PS2" setting. Press "Enter" to bring up a smaller menu with the options to enable or disable the PS2 ports. Select "Enabled." You can also use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the PS2 port. Change the settings for the USB port by moving the menu choice to the "USB" setting. Press "Enter" to bring up a smaller menu with options to enable or disable the USB ports. Select "Enabled." Alternatively, use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the USB port. Save the settings and exit by pressing "F10" or using the "Esc" key to back out of the current menu. Choose to save and exit from the main menu if needed. Follow any additional instructions on the screen to save or navigate the menus. Hope this helps.
Dec 13, 2012 | Dell OptiPlex GX520 PC Desktop
Pasword bios extensa 4420
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt
Then type at the C:\> prompt: type
DEBUG
and hit Enter. You'll see a dash (-) at the DEBUG prompt. Now type:
o 70 2e
which will show as -o 70 2e at the DEBUG prompt. Hit Enter. Then type:
o 71 ff
and hit Enter. Finally type:
Q
and hit Enter one last time to quit DEBUG back to the C:\> prompt.
Now you're ready to reboot your PC, and press the appropriate key or key
combo (look it up in your motherboard manual if you don't know it) to access
your BIOS Setup.
Youll notice the password is gone.
If this fails try typing
At command prompt type debug
you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password - works 9.9 times out of ten
If this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
http://www.tech-faq.com/reset-bios-password.html
At some stage you might need to press Ctrl+Enter rather than just Enter if on a Dell Latitude E5410
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Please see the enclosed read me if you would like to run it from Windows.
Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
Hope this helps.
Nov 21, 2012 | Acer Extensa 4420 (484U101011) Motherboard
How do I access the BIOS setting on this SYNTAX motherboar, not sure of the menu BUT when the system is comming up it does not state what to press to start BIOS sert up.... I tried F2,, ESC, F10, F8 and...
Try DEL.
Try F1.
With the computer turned-off, hold-down the SPACE BAR.
Turn the computer on, until you get "keyboard error, press <blah> to enter BIOS-setup". Press the <blah> key.
Jul 18, 2010 | Syntax S746FX Motherboard
I need a wiring diagram for the syntax sv266ad motherboard
You wont find one.
The only way you could get one is if the manufacturer of the board would release it to you, and they never do...its proprietary information.
What do you need to know about the board that your looking for a wiring diagram. And just to mention there is no wiring diagram persay.....its a routing diagram, as there are no wires.
Dec 11, 2009 | Syntax SV266AD Motherboard
Drivers for Syntax SV266AD Motherboard
I stumbled across a site awhile ago with all of the syntax mobo stuff. It's not active anymore, but the archived version seems to be pretty complete.
http://web.archive.org/web/20061105180703/http://64.168.125.230/support/SyntaxDownloads/
Aug 18, 2008 | Syntax SV266AD Motherboard
Looking for manual
Here is the link for the user manual. I don't think this file can open with office 2007 though. maybe 2003. http://64.168.125.230/support/Syntax/Motherboard/SV266AD/manual/
May 20, 2007 | Syntax SV266AD Motherboard
BIOS in BAD Shape
First thing the problem only with O.S(as per your statement - proper shutdown and restart). Your O S afftected by virus. you must format the full harddisk(all partions) and reinstall your O S. BIOS File always having the .ROM extention file, not BIN file. Pls reset the BIOS using the clear cmos jumper or removing the CMOS battery from motherboard.*****severe virus attack. Dont try to backup****
Feb 23, 2007 | Syntax SV266AD Motherboard
Syntax SV266AD Motherboard Logo
265 people viewed this question
Top Syntax Computers & Internet Experts
Roy May
Gbenga
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
