Question about RCA L42WD250 42 in. LCD HDTV
Have no video everything else works properly.
42 inch LCD RCA with built in DVD player. TV was shut off normally and left for 2 weeks but on return hve no picture so can,t open the menu to check for possible problem.
  • 8 more comments
  • dhodge Feb 15, 2009
    as I indicated everything is working normal just have no video therefore can't access the menu. So I don't feel a lack of power is relevant. Nor is there blinking led's.
    the last advise didn't produce results
    The disconnect didn't do the trick. I also have tried a CD in the built in DVD player but still no luck.
    The power indicater light is on and everything works except there isn't any vidio feed.
    You mention I have a bad inverter and ask if it is working properly.Please explain how do I go about answering your question? Would you think this is a warrantable item, expensive and require to be repaired in an outside repair shop?
  • dhodge Feb 16, 2009
    I use a power bar for my computer and TV with surge protection. The computer is fine so assume the power spike is not valid. Any other theories?
    no, I'm no further ahead than when I started the dialogue. I guess I expected you to tell me to try different things and if no improvement to be told take it to the repair shop but not all the different scenerios possible.
    Thanks anyway
    Sergeant:
  • 250 Answers
As many a times it happens due to dust collected on the internal circuit or if tv reaches to stand by mode due to not used for particular time.for this you have to open the tv,then remove all the cables which are removable from the boards of the tv interrnally and reconnect then again as proper they were actually.also clean all the dust collected internally on the curcuit boards.with a air blower and dry tissue.and check out.it should work.other wise its a short circuit internally on the board that has to be checked with a multimeter and the faulty components should be replaced to make it proper.
Posted on Feb 16, 2009
  • 15,935 Answers
Your power supply is bad (or possibly the on switch).
In either case, warranty should cover it.
If no warranty, a service call is in order, as there are potential deadly voltages stored inside capacitors. Without the proper discharge, you could be seriously injured.
This is not an end-user fix.
Please seek professional repairs.
Thanks for using FixYa - a FixYa rating is appreciated!!
    Genius:
  • 2,920 Answers
It sounds like the lamp burned out on he sey it can happen anytime and there are alot of complaints about it,, please feel free to call someone in to verify my diagnosis
  • 163 Answers
Hi!!you have a problem with the video circuit board,
  • 350 Answers
Dear dhodge, 2-15-2009 3:26pm EST (USA)
RE: RCA L42WD250 HDTV LCD
I hope you didn't have a bad power surge while you were away!
RCA Support & Contact @ http://tv.rca.com/en-us/ContactUs.html
You may just need an software upgrade but I'd call or contact RCA 1st as they seem to have a great support site.
Read the upgrade info @ http://tv.rca.com/RCATV/RL/upgrade/14%20&%20250%20Series%20Software%20Upgrade.pdf
Hope this is Helpful!
jack
Posted on Feb 15, 2009
  • 167 Answers
Hi, try unpluging it for an hour or so.then plug it back it. this may reset the unit-and hopefuly it will return to normal operation. also it is possible it took a surge,and messed it up i hope this helps you,all the best! glen
  • glenn hoffman
    glenn hoffman Feb 19, 2009
    if you have warranty go for it! glen.
    President:
  • 2,110 Answers
Try unplugging it for 30 mins. If it still has the problem, it may have when into protection mode.
When this happens, a part in the TV when bad. The protection mode keeps the TV from staying on to prevent further damage.
At this point, I would use the warranty on the TV.
  • 6,784 Answers
Ok, the only problem that i can think of that may have caused this disruption is an electronic pulse produced by extreme weather. when the tv was left for 2 weeks plugged in, it may have received an electronic pulse. this can occur during a winter storm that produces ice build up on line outside the house or, an electrical lighting storm. these phenomenons can affect transformers on the light poles outside your house that will send pulses threw the plugs and into the tv set, frying the main board and producing these very results you are experiencing.
    Master:
  • 848 Answers
Hi
you have a bad inverter ..........it tends to be problem of backlight issue.....is it working properly.......
  • 4,806 Answers
Just out of interest, do you know if there is any power getting to the TV at all? like a power indicator light?
    Sergeant:
  • 326 Answers
Remove all the wiring connections and also unplug the unit from main power outlet for near to 1 hour.then just connect everything as usual and in proper sockets.the wires/cables should be connected firm/tight in the sockets.adjust the settings after u connect the wires.and check out it will get reset and start working as normal.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Normally, there should be a standby LED that is flashing to indicate that the TV is in protective mode, power is still coming in but just it won't power up. If there is no such blinking LED light, then it could mean that:
  • the breakers for the outlet where the unit is plugged has tripped; and/or
  • internal fuse of the TV has blown.
Try to unplug for a couple of minutes, plug the TV into another outlet.
Should there be LED lit, post back which, what color and the sequence of the flashing. Additionally if there is a clicking sound hear from the rear of the unit.
You might also comment if you are considering a DIY (do-it-yourself) repair which would mean familiarity with electronic components & circuitry, use of a DVM and a soldering iron as well as access to a Service Manual or at the very least a schematic diagram with voltage readings.
Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Feb 15, 2009
    Appreciate the postback. Two most common possibilities then:
    • video interface/main-display board;
    • CCF (cold cathode florescent) lamps and/or inverter circuitry
    A test:
    • power on the unit and select a channel with the audio coming in;
    • with a flashlight shine a light close to the screen and towards the area where the volume level is normally displayed;
    • the flashlight has to be at an angle not directly pointed towards the screen;
    • press the volume up/down on the remote;
    • determine if there would be some semblance of the volume level albeit dark;
    • if yes, then it would be the CCF lamps (least likely) or the inverters (most likely);
    • if none, then it would be the video interface/main-display board;
    • of course all other boards/components could not be ruled out such as the power supply (it has multiple outputs), inverter/lamp controller, A/V board and others.
    If at this point that it would not be the CCF lamps or the inverters, you might be better off getting hold of a copy of the service manual or at the very least a schematic diagram with voltage readings. Referencing either would give you a go/no-go while measuring voltages at specific test points.
    Cheers.
  • RCA Master
  • 19,396 Answers
That sounds like a bad power supply, try a different outlet.
  • Ginko
    Ginko Feb 15, 2009
    Try a different outlet, if the TV does not start at all then it is a bad power supply, probably a storm while the TV was off.
    The part must be tested and replaced
    You find replacement here.
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
What are the classification of simple machune
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
GoodLuck
Feb 02, 2011 | Sanyo 42 in. LCD TV
HOW TO SET UP SONY DVD PLAYER WITH HITACHI 42 LCD TV
Connect yellow video output on DVD player to yellow video input on TV using RCA cable. Connect white audio output on DVD player to white audio input on TV next to yellow. Connect red audio output on DVD (next to white) to red audio input on TV using RCA cable. Select on the TV using remote, the proper input for DVD player connection.
Aug 08, 2010 | Sony Televison & Video
How to connect dvp 3356 t0 samsung 29 inch tv with crt tube.
Please check the connection. If you are connecting the 3 RCA cables to DVD component input/output, you need another pair of RCA cables to connect to audio out (FL&FR rear of DVD player) and Audio in (L&R) in your TV set. Else connect 3 RCA cable in 1-Video out & 2 Audio out of DVD player and 1-Video in & 2 Audio-in of TV.
Dec 15, 2009 | Philips Televison & Video
I do not know how to connect my DVD to my 42 in
Tries use a RCA cable plug 2 connections ports holes red,white audio out input connected ur DVD player,connnect the other side the RCA to TV audio in input.Use a S-Video cable for video connection to get video.If u have the new version of a DVD player just use a HDMI cable plug one end to the DVD player the other to the TV.
Dec 15, 2009 | Vizio L32 32 in. LCD HDTV
I have a 42 inch Insignia plasma tv. I only hook
If you have the audio cables hook up correctly to where the video cable from DVD is connected to, it should be RED and WHITE wires for audio. Then go to on screen audio setup menu to see if the speakers is turn off in the menu. Also try hooking up the powered PC speakers to the AUDIO LINE out RCA jacks to see if you get the sound OK there.
Nov 03, 2009 | Insignia 15 in. Flat Panel LCD HDTV
No picture with VIDEO INPUT, only AUDIO INPUT works
Hi ,disconnect the cable and leave the three RCA cables in.Switch off TV and DVD player ,then switch on tv and dvd player next .If you see the dvd picture and have sound then i think the cable box is overriding the rca channel.I normaly use a scart connection for the dvd to cable box then another scart from cable to tv.Hope this helps..
Feb 06, 2009 | Toshiba 37AV500U 37 in. LCD TV
No signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
Feb 03, 2009 | Proscan 32LA25Q 32 in. LCD TV
Ii own a minteck lcd dvd combo
I have a Mintek lcd/dvd combo which when turned on , comes on with picture and sound but the picture goes off in about one second. I removed the back and can see that the back lighting is going off. I measured some voltages at a terminal strip that i believe provider the back lighting for the set. The results seemed to be normal to me. Can you suggest where I should look further.
Nov 24, 2007 | Philips 42PF7220A 42 in. Plasma Television
Problem with RCA P42WED33 picture
If you have the tv on cinerama mode, it is black. If you use the scroll on picture mode it works
Jul 13, 2007 | RCA P42WHD33 42 in. Plasma HDTV
RCA L42WD250 42 in. LCD HDTV Logo
43 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
