Question about Relic 0504648FA
Relic watchband that isn't the same as instuction book
The Relic watch I game my wife doesn't match the watchband thats in the instruction book. It claims to have "Adjust-A-Link" (instruction book) but I twisted the cover off a link only to find that that it doesn't have a hing on the link.
Under each link there is an arrow that is marked right under the pin. It points out and looks as if the pin is to move in that direction. My small screwdriver moved it a fraction but not much more.
The watch has a blue face, roman numbers (6, 9, 12) the date is displayed at 3. ZR11780 & 250709 are the numbers on the back.
  • 2,334 Answers
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Feb 15, 2009
Do you have a black leather watchstrap in stock 233 LSSN?
No. I do not sell watchbands, and neither does Fixya. However, almost any retailer that sells watches is likely to have watchbands in stock, and may have a close match. A leather shop may be able to make a custom band for you.
Jul 03, 2015 | Skagen Strap Mens Watch 433LSLC
Relic watch zr15478 adjust wristband
I'm having the same problem with this watch, I found this guide but it's for a similar watch and doesn't seem to help. I'm hoping this helps you more than it helped me
Oct 22, 2011 | Relic 0504648FA
Relic model zr66023 165 ft under water watch. how do you light the light to see numbers. 2 buttons on side, buttons on side push in but no light
This particular watch has no light. The two additional buttons are for the chronograph (timer) function. The top is the stop/start button, and the bottom is the reset button. Source: I own this model of watch and have the book on it as well.
Aug 16, 2010 | Relic Watches
Watch band is too large.
mcdevito75 here, You can click on Repair Services at the bottom of the page right here on fixya, once there type in watches.
Jun 20, 2010 | Relic Silvertone Bracelet Watch for Men
How to remove links from relic chronograph steel watchband
Click on my profile, then click on TIPS AND TRICKS. There you will find explanation how to add or remove links. Rate me, plz.
Feb 27, 2010 | Relic Watches
Relic watchband adjustment for model PR 6057
203/#https://home.tomtom.com/shop/latestMapGuarantee: Error from server: Framework Initialization Error /tomtom720 gps
Feb 14, 2009 | Relic 0504648FA
Setting instruction on a Relic New Relic Wet Mens Chronograph Black Watch ZR15458
Go to the home site of the particular brand of watch you own. They should have the instructions for just about every watch configuration they manufacture.
Sep 03, 2008 | Watches
Seiko Watchband to long
Kept looking thru Google and found THIS site that seems to answer the question for MANY styles of METAL watchbands.
http://www.geocities.com/watch_crazy/index.htm
Dec 06, 2007 | Watches
Relic 0504648FA Logo
678 people viewed this question
Top Relic Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Are you a Relic Watch Expert? Answer questions, earn points and help others
