Question about Pentax Optio E30 Digital Camera
Camera locked Hi my camera shows a key lock in the upper right side of all of my pictures. how can I remove it? Thanks for your suggestions.
    Problem Solver:
  • 5 Answers
Go to:
Page 104! Step 6 . It is a protect icon
Good Luck
Posted on Feb 15, 2009
When i try to take a picture it says card locked
Hi Tony,
Turn the camera off and remove the SD card.Some of the SD cards do have a small slide lock on the side.Slide it to open and then re-insert into the camera.Turn the camera on and try to take a picture now.
Hope this helps.Thanks!
Dec 16, 2011 | Samsung Cameras
My camera is blocked: it says WRIITE PROTECT
Remove the memory card and you will find a switch on the left side of the card. It must be locked, so slide or push the lock on other side to open it and then insert the card back to the Camera.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jun 25, 2011 | GE Cameras
Hello!Yesterday i was taking picture of nature with my Olympus camera,after that i transfered them onto my computer using usb cable.Today i can't take any picture because it says on screen...
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards. If youare getting a memory card locked message then check this out.
How to UnlockSD Card heatman101
May 24, 2011 | Olympus FE-20 Digital Camera
Sterring lock left key in.turned whell broke off part of do i remove lock
Right out of the book but earlier model. It should be the same.
Removal of the fork lock:
1. Loosen upper triple clamp pinch bolts, Remove upper triple clamp and handlebars.
2. Loosen fork stem bolt, Let fork stem drop down approx. 5 in.
On the left side of the steering stem there is a "half-moon" indentation that has been machined into the steering stem for the lock. Let the steering stem drop until this indentation is in full view.
3. Look on the underside of the lock on the right side of the frame and there is a lead plug driven into a hole. In this hole is a set screw that holds the lock into the frame. The book says to use a scribe to get the plug out with.
4. Unscrew the set screw.
5. Insert the key in the lock and turn partially.
6. Wiggle lock and pull until enough of the lock comes out to get a grip with pliers or other suitable tool.
7. Rotate steering stem slightly, while pulling on the lock until the lock is removed.
Nov 28, 2010 | 2003 Harley Davidson FLSTF Fat boy
Camera: HP Photosmart R725. Can't format SD card; says its locked when its not.
dear sir,
even after removing the lock(by pushing the push button at the upper side of the card which allows the card to lock and unlock)and when you are trying to format it,it shows formatting cannot be done right??????????////
all right,just take the card and put in a card reader and try formatting,hope this helps...even after trying in crd reader if ur card cannot be formatted,then the card is being corrupted..........its advisable to go for sandick or transcend memory cards which have a longer life and some important pictures or joyfull moments being picturised if missing,it hurtsa lot,because i also faced this problem........
thank you...take care
Oct 08, 2010 | HP Photosmart R725 Digital Camera
How to remove and install ignition switch
remove the steering coloum trim. Turn the key to run position, Press locking button on back of steering coloum housing assembly, Remove lock cylinder, Disconnect the ground strap from lock preload spring ( if equiped ) . Make sure key is still in run position when you reinstall.
If the key is non functional and you cannot turn to run then you will need the tool in this picture197ca25.gif
Aug 12, 2010 | 1997 Chevrolet Cavalier
When I press certain keys like P I get 6
This is yoru number lock function
look along the "F" key row for the NumLk or picture of the number 1 in a square. then hold down the Fn key on the lower left of the board. press the "F" key that corresponds to it and this will disable it.
Feb 18, 2010 | Acer NSK8458AN Keyboard
The camera file is locked
not sure what you are asking? but most cameras have a little key picture on settings or pback of camera, if you want to protect photos from accidental erasure you push that button and it locks the file, when you view photo on camera it will show a little key in upper right corner of the picture. just a shot
Dec 28, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Memory card problem
Hi and welcome to FixYa.
I'm not sure about your particular instance, but this can happen if you change up cameras or use a card reader.
As for being unable read the memory card, sometimes the card can be switched off by accident. Turn off the camera and remove the card. Look at the side of the card and there will be a little switch. One end says locked (or shows a little picture of a locked lock) and the other end says unlocked (or, shows a little picture of an unlocked lock). Just move the switch to unlocked.
Try that, and let me know with a comment if that doesn't work, othewise, thanks for coming to FixYa!
Mar 02, 2009 | Kodak EasyShare One Digital Camera
Asus a6 laptop keyboard problem
your number lock is on. Since there is not enough room on a laptop for the right hand number pad you find on many desktop keyboards, they incorporate it into the text keyboard. Generally there is a key in the upper right side to toggle the number lock, also if you enter the bios mode and check that number lock is not enabled on boot.
Feb 03, 2008 | ASUS A6U Notebook
Pentax Optio E30 Digital Camera Logo
169 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
