Question about Jazz DV165-BOX Digital Camera
DIGITRON 69-4008-8 camcorder/ camera. Can't recharge the battery
After the battery power ran-out first time, it took all overnight to get full recharged. But it got empty in the middle of recording, and I lost the recorded part. I bluged-it-in for more than a day but noway to get any power in. I bought a new battery ($ 50 can-from The Sorce shop). same thing happen again. (the camira was on spicial at canadianTire shop, I lost the recipt since ben bought last year.)
5 Suggested Answers
  • 5 Answers
SOURCE: lost power adapter (Jass DV-179)
I actually have a spare from a camera that I had to return because of battery issues and thinking it was something wrong with the camera itself, but here's my e-mail if you would pay for shipping it to you, I just realized that I have two power adapters for the camera. portly_317@hotmail.com is my e-mail, so e-mail me and we can work something out.
Posted on Jan 20, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Recharging Battery
Check to make sure that the battery is seated properly and check the battery posts for wear and tear or corrosion.
Posted on Jun 30, 2008
SOURCE: My Jazz Dv179 Digital Camcorder Won't recharge
The battery in the camera is likely not a rechargable one. Check the print on the battery. Mine was not so I assume your is not as well. The maker of the camera was pretty cheap not supplying a rechargable battery, for the price they ask for the camera.
Posted on Jan 05, 2009
  • 3 Answers
SOURCE: jazz camera
maybe you sd card is locked try UN-locking it :D
Posted on Aug 17, 2009
I have received as a gift a Canon FS300 Digital Video Camcorder . The first time I used it, I followed instruction on how to charge the battery with CA-570 Compact Power Adapter which was included. It wok...
Hi!
Almost sure there is nothing wrong with your battery, charger and camcorder.
The battery loose power even when doing nothing, especially when it is a NiMH type.
Please charge the battery for a couple of hours and try again to start the camcorder.
Aug 09, 2011 | Canon VIXIA FS300 Flash Media Camcorder
Canon ZR90 Mini DV Digital Camcorder no power even when plugged in charger no red light tryed 2 batterys
Batteries may need to be recharged or replaced if the error persists after battery recharge or replacement the unit may require a service evaluation. If the batteries currently in the device and it is not working properly, remove the batteries and wait for 30 seconds and re-insert the batteries. In doing so if your camera has a back-up or date and time battery, remove this battery as well. Removal of the back-up battery will cause a full reset of the camera and will clear any settings, including date and time.
Mar 13, 2011 | Canon ZR90 Mini DV Digital Camcorder
SIR/MAM. WHEN EVER I USE MY CAMCORDER GR-DVX9
There is often a small battery inside the unit or accessed from outside that holds the memory that the device was last set. Yours is defaulting to maximum zoom. And in fact it does.
Built-in Clock's Rechargeable Lithium Battery
To store the date/time in memory, the clock's rechargeable
lithium battery is integrated in the camcorder. While the
camcorder is connected to an AC outlet using the AC
Power Adapter/Charger, or while the battery pack attached
to the camcorder continues to supply power, the clock's
rechargeable lithium battery is always charged. However,
if the camcorder is not used for approx. 3 months, the
clock's lithium battery will become discharged and the
date/time stored in memory will be lost. When this occurs,
first connect the camcorder to an AC outlet using the AC
Power Adapter/Charger for over 24 hours to charge the
clock's rechargeable lithium battery. Then perform the
date/time setting before using the camcorder.
Note that the camcorder can be used without setting the
date/time.
Your manual in English. You can use a smartphone with Google translate and the camera feature to read what is shown on the camera in Japanese and change the operating language to English.
http://www.videocamera-manual.com/manuals/jvc/JVC_GR-DVX9_MiniDV.pdf
Nov 03, 2017 | JVC GR-DVX9 Mini DV Digital Camcorder
Dec 29, 2008 | Jazz DV-179 Digital Camera
Rechargeable batterie won't work in my Camera.
Not sure what camera you have, but some cameras require a very steady power supply voltage. Also not sure how old your rechargeable batteries are either, but batteries (alkaline and rechargeable decay over time. With the rechargeable ones, the more you use it, the less it can charge to full capacity over time. For example, if your rechargeable battery is supposed to charge up to 1.5V, over a period of a year with constant recharges, you can test with a volt meter and see that it never really goes back up to 1.5V, but more like 1.48V, 1.45V or maybe even 1.4V.
Depending on the camera or other item you use rechargeable batteries on, it can adapt to low voltages with special circuitry inside (but only to a certain limit, when a battery is old, it is old).
You can try buying a new set of rechargeable batteries and use it few times and see if this fixes the issue. If not, your camera may be faulty and just draining the battery (not too likely, but it happens).
Check out this site for some useful info.
http://www.steves-digicams.com/nimh_batteries.html
Apr 30, 2008 | Canon PowerShot S5 IS Digital Camera
My camera will not stay on
Hi Sarah,
I had the same problem. What I did was to remove then reinsert the battery and turn the camcorder on. I let the battery run down (discharge) completely, then plugged it in to the charger overnight. Doing a little more research on this camcorder, I found that if it hasn't discharged completely when you recharge then the battery holds less charge each time until finally you get next to no battery use. Discharging completely may be an option. Hope it works!
Oct 31, 2007 | Aiptek MPVR Digital Camera
Can't charge the battery
# New batteries need to be drained by using the camcorder until the viewfinder indicates the battery is empty. Follow these steps: Once the battery has been drained, you may use the charger to recharge the battery. # Consult your manual for the amount of time the battery requires on the charger to get a full charge. # A full charge will be delivered by the charger. # Some camcorders have a Refresh feature, which will automatically drain the initial charge on the battery. This allows the battery to fully recharge.
Sep 06, 2005 | RCA CC-432 Camcorder
Battery
When batteries are low and they are not used for a period of time, they can build up enough voltage to give a full battery indication. The batteries only had enough power to shoot one image. The batteries are exhausted and need to be replaced or recharged.
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Jazz DV165-BOX Digital Camera Logo
321 people viewed this question
Top Jazz Cameras Experts
pontelemon
pontelemon
Computer Links
Are you a Jazz Camera Expert? Answer questions, earn points and help others
