Question about Samsung Computers & Internet
Samsun15'' monitor (2003 model) crt monitor appearing fully green
The monitior is fully green how to resolve it
  • kamalbritto Feb 15, 2009
    i dont no correctly
  • 3 Answers
Sounds like the red guns aren't firing. Check the pins on the VGA cable to make sure that none are bent. Also plug in a different video card (or plug the monitor in to a different computer). If the monitor is fine, then you need to replace the video card.
If they aren't, you're looking at a fairly expensive repair.
Posted on Feb 15, 2009
Hello sir my samsung lcd monitor model no 740N . in dis monitor right side display two verticle lines green n light pink but hoe to i resolved dis problem please give me suggestion
You cant resolve it tiny resistors in the screen have failed and that is why the lines have appeared, it is a case of live with it or buy a new monitor
Feb 24, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Hpm-705 crt monitor fault?
my monitor model is HPm705 CRT as and when i use the system the monitor screen gets switched off and on every 2mins... pls consider the issue and tell the solution for it... to get resolve......
Sep 05, 2009 | HP Computers & Internet
My viewsonic monitor is not working
Considering the price of monitors versus the cost of repair. It would cost less to replace the monitor.
Mar 12, 2009 | MPC Computers Viewsonic E771 17 in.CRT...
LG Monitor Display Problem
1. Mostly Loose contacts in video section that means CRT Neck board dry points checke it.
2.Pl check VGA Cable RGB signal pins 123 to ground 75 Ohms (on OK condition).
3.check 5v supply
4.check SDL and SCL signals.
Oct 05, 2008 | LG Studioworks 563N 15" CRT Monitor
Screen only stays on for 2 seconds at a time
just an update...I have fitted a new cable (pc to monitor) and it has been on for 2hrs now so fingers crossed!
Aug 19, 2008 | Philips 19 in. CRT Monitor
Sony CPD E500 - Power On from cold problem
as u told ur monitor is excellent only... it is in good condition no problem will be there ... may be there is problem with the operating system just try reinstalling it... ur problem will be solved...
Feb 05, 2008 | Sony CPD E500 (White) 21" CRT Monitor
Samsung color monitor
This problem may arise from monitor as well as from cpu.
First of all check it by unplugging the VGA monitor cable.
This will display the "Check Signal Cable" depending on the model of the monitor. But a message will appear rolling on the screen, if it is not a very old monitor.
If the message is appearing OK and green light is continuously on, that means ur monitor is working fine.
The problem may be with VGA cable or with the booting of CPU and probably the RAM. Recommended solution is to reconnect the RAM and then try, if u think u can do. Otherwise call a hardware engineer.
If there is no message and still the light is turning green and yellow. That means the problem is definintely in the monitor.
Thankyou,
Your well wisher
Nov 27, 2007 | SAMTRON 55V 15" CRT Monitor
Green color dot appears when moniotor switched off
I would first verify your system power settings (in Windows XP go to control panel, power options, then verify that nothing is set that could activate your monitor to a standby mode) - other versions of windows have something very similar. If all of these settings are correct, then unless the monitor is not working as required when switched on, i would recommend just leaving it be, possibly just take the time to unplug the monitor power lead instead of just switching it off. If however you feel you must fix this problem, try: http://www.lenovo.com/planetwide/select/selector.html for this model of monitor you will need the serial or FRU number in order to define the exact model.
Feb 23, 2007 | IBM E74 17" CRT Monitor
No Green
Check the crt board and follow the green signal path, could have a shorted transistor or a resistor out of tolerance on that line, check all the components on that line
Nov 01, 2006 | LaCie Electron 19" CRT Monitor
Blank monitior
There is probably some electronic malfunctions inside your monitor. Since I will not be able to actually check your monitor, the best solution for this is bring your monitor to a qualified TV/CRT technician in your area for proper diagnosis. He's the right expert and the second opinion to that kind of problem. Problems regarding inside the monitor are usually not fix-it-yourself kind of thing for non-expert like you compared to software problem, which can be mostly fix by yourself guided by an expert.
Sep 12, 2006 | HP Pavilion MX70 17" CRT Monitor
Computers & Internet Logo
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
