Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Freezer works refrigerator does not
Model 596.51672100 Freezer works fine refrigerator not cooling we adjusted controls and cleaned underneath still not cooling
  • Anonymous May 01, 2009
    I have the same model, this just happened to me 5 days ago... the exact same problem and i have done the exact same things...an article here made some sincehttp://answers.yahoo.com/question/index?...
  • Kenmore Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratorfreezer works refrigerator does not - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
Kenmoore 76523 ss bottom freezer, freezer works, refrigerator does not
This is not my main field of expertise . However, as I see you are not getting more support I can address you to this link. It may help you
goodbye
Feb 22, 2008 | Kenmore 73503 Stainless Steel Bottom...
Can I lean my fridge back to clean coils underneath? I am experiencing fridge not getting cool air . The freezer is fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 14, 2011 | Kenmore Side by Side Refrigerator
Bottom Freezer Refrigerator: Freezer is working, fridge is not
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 01, 2009 | Refrigerators
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
FRIDGE NOT COOLING
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Your damper and controls are on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MFD2560HES&productCategoryId=0161000&brandId=3048&modelName=MAYTAG-REFRIGERATION&diagramPageId=00006&componentDescription=CONTROLS&documentId=M0412077&backToLink=Return%20to%20Sub%20Components%20list
Jul 13, 2009 | Maytag MFD2560HES Bottom Freezer French...
Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be begining of a defrost problem.
Jun 14, 2009 | Magic Chef CTB1821AR Top Freezer...
Freezer and refrigerator are not cooling
We called an appliance repair company and it was the Control Panel that was causing the problem. $317 later it is now working properly.
Dec 03, 2008 | Refrigerators
My freezer dosen't work but the fridge seems to be O.K.or at least cold enough (Model BX2255W Manufacturing# P1196708WW) Ive vacumed underneath and adjusted both the freezer and refer controls. The fans...
Normally it is the temperature of the refrigerator that shows the first sign of a problem because the refrigerator is cooled by air from the freezer. Check the back wall of the freezer for signs of frost. If there is frost on the back wall you have a defrost system problem.
Jun 29, 2008 | Amana Refrigerators
Freezer Working, but Fridge side is not cold.
ou most likely have a defrost problem is there a large build up of frost in the back wall; of the freezer??
Jan 26, 2008 | Frigidaire FRS26KF5C Side by Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
1,005 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
