Question about Ricoh Aficio 1035 Copier
Error546.Power switch off and on. Help me.
I replaced Thermisters. Though the problem repeats.Please give me a solution.
  • Nagaraj shettar Mar 12, 2009
    Thank you but I am not sure about how to enter Service mode in Savin 3540
    Problem Solver:
  • 13 Answers
Enter service mode yellow key 107 hold stop go to copysp then go to datalog which is 7 and scroll down to 807 and execute
Posted on Mar 09, 2009
  • yellow key then 1 0 7 then hold down stop till the screen changes .. then go to copy sp then scroll down to 7 data log and scroll further down to 897 sc jam reset and execute
Are the lamps ok? are the fuses ok?
You know this code needs resetting in "service mode"? Just enter service mode and turn machine off/on.
Posted on Feb 16, 2009
HOW TO CLEAR AN ERROR [ERROR546]
Hello
Error 546 is a warmup error, when the fuser does not reach fusing temperature within the warmup timer period.
You could attempt to remove the fuser yourself, and clear carbon buildup, or you may have to completely replace the fusing unit.
You can clear the error by going into service mode, and selecting reset.
Aug 07, 2012 | Ricoh Aficio 150 Copier
My Toshiba 452 copier gives the following message when started."Call for Service C 440". about 130172 copies are taken from it and this problem occurs first time.
switch off machine
while holding down 0+8 buttons awitch on when the machine is in test mode key in 400 then start key in 0 and enter switch the machine off and wait awhile switch on if the error returns you must change thermisters and themo fuses
Mar 28, 2011 | Office Equipment & Supplies
I have a GE model ZFSB26DNASS serial #VD419341 that I purchased in 2003. The fresh food side stays at 29 degrees no mater what I set it to and the water line in the bottom is frozen. I unpluged it and...
Your fresh food thermisters(electronic thermostats) have failed allowing the temperature thermostat to run continuously.
The thermisters need replacing.
Jan 29, 2011 | Refrigerators
Im got problem with my copier machine model ricoh 1027,sc code 542..i no problem with fuser temp..after i clear code sc, same problem happen..so am don't no how to solve this problem .please help me to...
If you can tell that the fuser is trying to heat up then you are going to have to replace the thermistors. The thermistors or thermisters are 2 parts in the fuser that "read" the fuser temperature. When 1 or both go bad then the machine can not "see" the heat and thus throws the code. Ricoh's in particular have more issues with the thermisters than other brands. Here is a link to a site that has the thermistors and a picture of what they look like.
Good Luck and Thank You for using Fixya.
WheatlandServices
http://www.precisionroller.com/search.php?q=ricoh+1027+thermistor
Dec 21, 2010 | Ricoh Office Equipment & Supplies
I have had a GE Profile Artica Refer for 6 years and have nothing but problems. After 3 years, we had to have I think the mother board replaced because the refer would not cool....would run at 50 degrees...
The old style ice boxes used a mercury bulb switch that shut power on and off according to the desired temp. Not now brother. We decided that was not good enough so what brainiacs came up with were electronic monitoring. Sound familiar? A group of thermisters are placed around the icebox to monitor ambient temps. 177300d.jpgThese thermisters( thermostat resisters) change in resistance when temperatures change. The fancy control board relies on these suckers to give it good intel when to shut down cooling systems. You should consult your tech sheet to see if the ohms readings on each thermister is within 10% of specs.
Mar 20, 2010 | Refrigerators
Error Code 546 in Savin 3540 copier
enter sp mode with the following combination
yellow key then 1 0 7 and hold down stop till the screen changes go to copy sp then scroll down to 7 datalog and down to 897 sc jam reset and execute the turn off the machine and back on
Dec 27, 2008 | Office Equipment & Supplies
Replacement power cord
Please i am trying to find a replacement power cord for a pt390 i repeat a pt 390..I sure could use some help or give me some alternative solutions!
May 07, 2008 | Aastra Telecom Aastra PT-480E Corded...
Konica 7020 Printer
HI,
you need to reset the fuser latch as it has a fuser error code most likely needs new thermisters,
anyways give this a go, hold down 2 and 5 keys together and power on machine, this will put you into to a service mode call 25 mode, go to dip switch 3 and bit 1 and then next to bit 1 hit the key that says turn off,
turn machine off and back on should clear error code, if it doesnt you need new thermisters, even when you put in new thermisters you still need to clear this error in service mode
Regards
Konica Tech
Feb 15, 2008 | Office Equipment & Supplies
Ricoh Aficio 1035 Copier Logo
171 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
