Question about Mitsubishi VS-5075 50" Rear Projection Television
I HAVE SOUND BUT NO PICTURE
I HAVE A MITSUBISHI (MODEL VS-5075) THE PICTURE WENT OUT ON IT I HAVE SOUND AND EVERYTHING ELSE ANY IDEAS?
  • ldeekllr Feb 15, 2009
    ITS A REAR PROJECTION
Is it a rear projection tv? plasma? or LCD?
Posted on Feb 15, 2009
  • lexi_kins03 Mar 01, 2009
    Have you attempted to change the bulb in the back of the TV? rear projections need bulbs to give you a picture and the bulbs usually go out after awhile of use.
Pip
ok nimrod they have many types of settings about pip viewer,will you please give the brand and model?
Sep 21, 2007 | Mitsubishi VS-5075 50" Rear Projection...
The horizontal hold
If model number correct (the one posted here) set does not have a horizontal (rolls left to right) or a vertical (rolls top to bottom) control.
Verify model and brand so I may offer some suggestions
Mar 22, 2012 | Mitsubishi VS-5075 50" Rear Projection...
Mitsubishi VS-5075
Your standby power supplies are most likely at fault you should check the low voltage regulators and see if they are functioning they may be defective.
Jun 16, 2008 | Mitsubishi VS-5075 50" Rear Projection...
No picture just sound
Your projection tubes are messed up. It's a very expensive fix, just get a working TV off craigslist with a smashed screen and reuse your screen itself (usually 100-200$) or just toss the TV and upgrade to an LCD
Apr 29, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Mitsubishi YS-5075
yes, this sounds like a fuse blown or open. What model is this a VS or YS?
Mar 10, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Set-up
the set should have it's own tuner hook cable to ant and then select ant from remote input
Dec 06, 2007 | Mitsubishi VS-5075 50" Rear Projection...
Mitsubishi vs 5075
THIS MODEL IS EQUIPPED WITH A KEYBOARD LOCK FEATURE; THIS CAN BE MISTAKEN AS A NO POWER CONDITION. TO UNLOCK THE KEYBOARD PRESS AND HOLD THE "MENU" BUTTON ON THE FRONT PANEL FOR 10 SECONDS
Oct 11, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Pip only on screen
Try hard reset first==Unplug ac cord overnight, then try again.Possible signal board trouble-- Practice visual acuity technique==look for CRT coolant leak on circuit board. Also suspect PIP PCB==can be by-passed by a knowledgible tech.
Sep 26, 2007 | Mitsubishi VS-5075 50" Rear Projection...
Mitsubishi model vs-5043
I just had this same exact problem. I looked for an answer on here and could not find one. So I took the back off, vacuumed and cleaned everything out with the hose on my house vacuum, cleaned the bulbs and wiggled them around some. Voila !!!! lights on and all is working fine and better then ever. I hope this helps someone fix their problem. Just saved me tons of money and a morning of hassle.
Jan 06, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
316 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
