Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Kenmore oven doesn't keep heat
Our Kenmore oven is only 5 years old but it doesn't keep the temp. Sometimes it gets to the set temp then goes way down. Other times it never gets to the set temp. It does both of these even though ''heat'' is showing on the display. And other times it's fine. Sears came out but it was working so he didn't do any kind of diagnostic testing. However, a few hours later, it wasn't working again. What could be wrong?
    Sergeant:
    Champion:
  • 338 Answers
Im going to assume it is gas.. you may have a bad ignitor.. it is not gettin hot enough all the time to ignite the gas.. eventually it will not lite it at all..
Posted on Feb 15, 2009
On a Kenmore gas oven the flame goes on and off and doesn't keep a constant temperature.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 19, 2011 | Kenmore Ovens
Erratic oven temperature
The ignitor is probably weak and not relighting when it needs to. Replace the ignitor.
Sep 05, 2009 | Ovens
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
Oven makes poofing sound when in use
hi. thanks for the question .Yes the igniter is at fault here. replace it. thanks the appliance doc
Oct 02, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore wall oven model 911.4088816
www.kenmore.com/shc/s/s_10154_12604_Kenmore_Cooktops%2C+Ranges+%26+Ovens_Wall+Ovens
Try to identify which oven you have and try to get a manual from the same source
Feb 03, 2008 | Ovens
Oven Temp
After it drops temperature, how do you get it back to the desired degrees? It sounds like the thermostat isn't keeping up.
Nov 15, 2007 | Whirlpool RBS245PDS Electric Single Oven
Zanussi zbf 760 (9 yrs old now)
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances How to Video Tutorials on Domestic Appliances
Sep 24, 2007 | Zanussi ZBF360 Electric Single Oven
Oven light always on, no heat
probably the clock not set properly - you have the oven on automatic. switch off at mains, wait 5 mins and set the clock according to the manual. if the over-temp stat has operated, the oven goes dead
May 05, 2007 | Smeg S351X/5 Electric Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
166 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
