Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Dubbed DVDs will not play
I dubbed home video from VCR to DVD on a Magnavox dual player and can be then viewed nn TV through the Magnavox. However, these DVDs can not be viewed on other DVD stand-alone players. Please help. Thanks.
  • debbie_20_00 Feb 15, 2009
    I have the same issue and have finalized the dvd. Any other suggestions?
  • samirtank Feb 22, 2009
    I recorded a DVD using Magnavox DVD recorder, however I am not able to play the DVD in other players. I tried to finalize but it does not seem to be working.
  • 8,596 Answers
You have to use the Magnavox dual to finalize the discs, and then they should be able to play on other players. I don't have a manual for that exact recorder, but in general you would go to the Settings Menu of the DVD player --> go to Disc Edit --> and then select Finalize - the exact pathway might be a bit different on that particular recorder. Once you have finalized one of your discs, try it on another DVD player and see if it works. Good luck!
-Tha Mp3 Doctor
Posted on Feb 15, 2009
I just bought a magnavox DV225MG9 A player . The salesman said it could copy vhs tapes to dvd. how do I do this with this machine?
If this is the correct model number, magnavox DV225MG9, above, this unit is only a DVD player not a DVD recorder. It won't dub DVDs to VHS either.
I wish that I could be more help.
Jun 30, 2010 | GoVideo Go Video DVD/VCR Combo
I lost the manual to the magnavox dvd/vcr dual player so i dont know how to set it up. so i can watch dvds and vcr tapes.
The easiest way to hook up the combo is to use the cable in and out to tv connectors located in the rear. for this connection you will hgave to set the TV to Channel 3 or 4. You can usually download an owners manual from, you will need a model number.
Mar 19, 2010 | Philips Magnavox DVD/VCR Dual Player
Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
Oct 24, 2009 | Televison & Video
How do you fix a dvd player to record
A DVD player cannot be fixed to record unless it is a DVD recorder. If your problem relates to recording DVDs on your VCR dual player i.e you want to record DVDs on to a Video cassette please do clarify the information and we will be happy to assist.
Thanks for using FixYa.
Sep 26, 2009 | Philips Magnavox DVD/VCR Dual Player
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Have an old tv with no A/V jacks - connect to VCR??
go to walmart ang get an rf converter, you plug your dvd into the converter, then run a coax cable from your converter to your tv, put your tv either on channel 3 or 4 and presto. they only cost a few bucks. this is a high dollar one, they got em cheaper at walmart. dont forget to rate. :)
Jun 23, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD does not play on other players or computer
Hi and welcome to FixYa,
Your description indicates that the last step in the DVD recording has not been performed on these discs that were recorded on the Magnavox. This would be "finalize" or instruct the Magnavox that no other files would be written/recorded on the current disc. Thereafter, the Magnavox would complete the DVD disc making it playable in any other player. Normally, finalization would take a bit of time to complete.
Pls post back how things turned up. Good luck and thank you for using FixYa.
Feb 02, 2009 | Philips Magnavox DVD/VCR Dual Player
I Have been trying to dubb VHS tapes to DVD''s. They record alright, but then when I go to play them on another DVD player they won't do I get them to finalize? I have went through the menu and...
--- for some reason this unit does not finalize automatcally.
--- the instructions for finallizing are on page 52 of the owners manual.
--- they are as follows:
1) Press Setup
2) Scroll down, select "Disc Edit", press "OK"
3) Scroll down, select "Finalize", press "OK"
4) Select "Yes", press "OK"
Finalizing will start.
--- have done this operation several times, works Ok.
Jan 05, 2009 | Philips Magnavox DVD/VCR Dual Player
I want to copy my VHS tape to a DVD
you should just have to hit the dubbing button on the front of the unit. Make sure you hit stop on both the vhs and the dvd sides. I found that in certain conditions it won't dub.
Jan 01, 2009 | Philips Magnavox DVD/VCR Dual Player
Viewing a recorded DVD+R on PC
I am assuming you have an actual dvd drive of some sort installed in your computer. The problem you may be having is a missing codec. This problem can be solved by downloading a VLC player which has most needed codecs pre installed. This program is freeware and can be easily found online. I hope this helps. Good Luck!
Jan 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
265 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
