Question about Dishwashers
The dishwasher made a loude grinding noise when it was almost done and now it will not work...HELP ME PLEASE ANYONE
  • xowendyxo36 Feb 15, 2009
    thank you so much for your help..
  • 338 Answers
I think your motor may be shot now due to something hard getting down into the assembly.. replace the whole sump motor assembly.. it is cheaper than buying a new dishwasher..
Posted on Feb 15, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
Dec 03, 2015 | Washing Machines
Dishwasher is making a loud noise
Sounds like there is something in the filter trap that is right before the mini disposal that is a fan blade, on top of the motor.
Aug 04, 2012 | Frigidaire Professional Series 24 in....
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    The dishwasher is less than 2 months old and has made a loud grinding noise from the start. I believe the noise is coming from the pump or another part from under the unit.
    Hello, Thank You for using FixYa. I will be helping you today.Make sure nothing is up against the motor! Also the drain pump on this unit can be loud.You can try to put something to help support the drain pump if it is vibrating. I would start looking at these things before calling for service.
    Thank You and please rate my answer if it was helpful..
    Jun 15, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
    Loud noise
    Check for bones/glass/ceramic from chipped plates in the food chopper (for lack of a better term). You'll need to disassemble the entire lower arm unit.
    Sep 06, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
    Our dishwasher is making a loud noise during wash cycle.
    if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
    Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
    Dishwasher making loud noise
    Newer washers are designed with a food grinder inside to help grind up large pieces of food. What you are hearing is the grinder doing its job. You do not need to worry about the noise. It should go away after a while as the food particle is ground up.
    Jan 10, 2009 | Amana 24 in. ADB2500AW Built-in Dishwasher
    Maytag dishwasher mdb56000aww
    It seems that your motor on the dishwasher is going out, like mine has just done. My explanation is that it sounds like something is grinding on glass or as if a bunch of mice are making noise. Eventually, the motor will not run any more. What will happen is that the dishwasher will fill up, then make a loud humming noise, while the heating element is making the water near the heating element sizzle. Now what you have is a possible fire hazard which compounds the problem with the dishwasher. Get rid of it, take the loss and live like my grandmother used to, without having a dishwasher. That is the best advice I can give you.
    May 08, 2008 | Maytag 24 in. MDB5600A Jetclean II...
    Loud grinding noise when washer is draining
    something in the impeller housing. not usually serviceable. not sure if that unit has two pumps. you could look underneath the tub and try to determine that, and where the noise is coming from.
    i am confident the issue relates to a pump unit.
    good luck
    Oct 22, 2007 | KitchenAid KUDR01TJ Dishwasher
    Dishwashers Logo
    132 people viewed this question
    Top Dishwashers Experts
