Question about Casio CFX-9850G Plus Calculator
Casio fx-9750GA can't find Ran or Int
I cant find the Int or Ran button on my new calculator it is a fx-9750GA
  • Casio Master
  • 7,993 Answers
Turn calculator on. Select [RUN] [EXE].
In run screen press [OPTN] [F6:-->] [F4:NUM] then select the function you want to use. You have ABS, Int, Frac, Rnd, Intg.
Hope it helps.
Posted on Sep 18, 2009
Matrix casio fx9750giihow can I find eigenvalues and eiginvectors for a matrix in my calculator? :)
This calculator cannot find eigenvalues and eigenvectors of matrices for you. The calculator does have many row and column operation that you can use to solve your problem. You need to know the theory of matrices, determinants, and some eigenvalue and eigenvector finding algorithms.
Dec 13, 2013 | Office Equipment & Supplies
Where is the math button on the casio fx-9750G11
It is a calculator and prqactically every button is a MATH button. It depends on what MATH you intend to do. Put the calculator in Run/Mat screen then press the OPTN key. You will see several tabs. Press the function key under a TAB and explore what is offered. Go through all the keys (F6 also) and see what the new tabs do.
In general it is most helpful to read the manual that shipped with the calculator.
Oct 16, 2012 | Casio Calculator Graphing FX 9750GII...
I have a casio fx-9750GA PLUS. how do you do standard deviation with a set of numbers?.
Here are the capabilities of the calculator.
In stat enter the values in List1 and the frequencies in List2
Press the key corresponding to the CALC tab
Press the 1-var tab and you get the results as seen on the screen with title 1-variable.
Other screens show some two-varaible stats or regressions.
Jun 01, 2011 | Casio FX9750GII Graphic Calculator
Degree and radian function Casio fx-9750GA Plus
Press MENU, then select RUN and press EXE.
Press SHIFT MENU to access the SetUp.
Move cursor to highlight Angle.
In the botton of screen you see the Deg TAB. Activate it by pressing F1.
Here is a screen capture.
May 06, 2010 | Casio FX-9750GPlus Calculator
Erasing coordinates in STAT
  1. Open the lists for display (or editing)
  2. Use arrows to highlight the value you want to eliminate.
  3. Press [F6:|=>] to display the rest of the menu TABS.
  4. Press [F3:DEL] to delete the highlighted value, or [F4:DEL-A] to erase all contents of the list where highlight resides.
  5. After you erase an X-value, erase the corresponding Y-value, otherwise you will have a dimension mismatch error.
Nov 10, 2009 | Casio FX-9860G Graphic Calculator
Factorial abbrevation on casio fx-9750GA PLUS can't find it!!!!
There is no direct or shifted keystroke for nCr nPr and ! on casio long ago.
You can access to those function using OPTN button; here is how to do...
press OPTN, F6(>), F3(PROB), F3(nCr)
Jun 13, 2009 | Casio FX-300MS Calculator
Log function on casio fx-9750GA Plus
Look it's simple in the calculator the default base is 10 so when you input log 3 its log 3 base 10 so:
maybe you know in math log x base y = log x / log y . So if you need log 3 base 3 its => log 3 / log 3 (by the way its 1)
Mar 27, 2009 | Casio FX-300MS Calculator
I can't find how to input Int on my calculator
Hi. Many of the fx 9750's functions are hidden; they are accessed via the 6 grey F keys under the display. To use Int, Frac, Abs functions, after you turn on your calculator, in normal mode (menu 1 selection), press [OPTN] [F6] [ F4]
This will give you the number menu, containing Abs, Int, Frac, Rnd and Intg
Int is the F2 key. Press [F2] first, then enter number or variable. Int value will be shown.
Hope this helps.
Mar 11, 2009 | Casio FX-9750GPlus Calculator
Casio CFX-9850G Plus Calculator Logo
837 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
