Lennox Furnace I have a lennox furnace the bracket on the blower motor broke. I fixed this but now when it gets ready to turn on the blower it blows a fuse. It was still running just before i fixed the bracket. Motor work just fine it only was making a rubbing sound on the cage. everything spins fine by hand. Please help
  • Ken Bledsoe May 11, 2010
    When you say bracket are you talking about the brackets holding the motor to the squirrel cage? Or the bracket holding the whole assembly to the housing of the furnace?
  • 56 Answers
Make sure to check and see if you do not have any bare wires touch ground or if you have any wires pinched causing a short to ground. Safety first so turn of power before checking. Also check to see if any wires on unit are touching one another. Hope this helps you.
Posted on Feb 16, 2009
Lennox lb50527cc
high limit switch, no proof of flame.
Oct 27, 2013 | Goodman Heating & Cooling
I have an Armstrong SX Ultra 90 propane gas furnace that the fan motor will not shut off ,the thermostat is on auto.
Hit the side of the furnace. Some times there's a sensor inside that gets locked up from a dirty filter.
Oct 19, 2013 | Emerson Lennox Ducane Armstrong Furnace...
Furnace computer won't let furnace light
What is the model number? I have an SLP98 (installed on 11/29/2011).... and if I take the cover off the front of the furnace the panel that has the fancy "Lennox" badge on it) you will see two clear round windows about the size of a half dollar (one high on the furnace box and one lower on the blower box.) If you look downward into the window on the blower box you can see a red LED display that will sometimes flash error codes like E228 (one character at a time). If your model has something like this, let me know. I've done some DIY fixes recently out of necessity....and their easy.....and several technicians confessed they didn't know much, if anything, about the newer high effieciency Lennox gas furnaces.
Mar 01, 2013 | Lennox Heating & Cooling
Lennox Fan will not come on when set to ''auto'' position.
Expensive is relative, service calls are never free. But if you have an idea what the problem is, you are armed against an unethical service company. Now to what you describe, could be a couple things, first let me explain the difference in fan speeds. Furnaces that both heat and cool have multi-speed blower motors. High speed is for cooling and lower speeds are for heating. The fan switch at the T-Stat turns on the high speed fan relay. The lower speed fan is turned on by either a temperature activated switch (silver box mounted on front on furnace above burners) or a time delay relay which is solid state. That being said, your problem could be a defective fan switch or one of your blower motor windings has gone bad. Most motors have 3 or 4 speeds and a technician could just change speeds and all would be good. A fan/limit switch is not so expensive that you would replace the unit. Bottom line, unless your really handy, a heating company is in your future. Good luck and please rate my answer if it was helpful to you.
Dec 31, 2009 | Superior Lennox Blower Thermal Sensor -...
I have a Lennox Pulse furnace. It's making a
The bearings are bad. You need to replace the motor. Motor cost $75 to $125. Labor is on avg. $150 to $400 with an decent A/C Company . You can try to oil it but its not recommend by Lennox. That furnace at the time they build it was top of the line. Good Luck.
Oct 14, 2009 | Heating & Cooling
Heating & Cooling Logo
121 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
