Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
WD400 will not boot up
This drive made unusual clicking sounds and went out. Can I remove the cover of hard drive and replace the moving parts or motor or whatever the hells in there?
    Scholar:
  • 54 Answers
The elemets hard drives are not user serviceable and thus, you may void the warranty in doing so. Have a look on their website for the data lifeguard diagnostic software and check for possible errors. he sound you may be hearing is the heads inside the drive. If you are still under warranty, you can have your drive replaced. Make sure you have your data backed up.
Posted on Mar 01, 2009
How do you take a hard drive out of a computer?
turn the computer off at the wall and disconnect the cable
open up the cabinet
pull the connections off the hard drive
remove the screws holding the hard drive in place and remove
if it is an old disc type hard drive and it is faulty, replace it with a solid state hard drive ( no moving parts)
because the hard drive contains the operating system, the fitment of a new hard drive will require you to get into the bios boot tab and change first boot from hard drive to first boot cd that has an operating system cd installed
to get to the bios immediately after pressing the on button, hold down the delete button until the bios screen appears
Apr 27, 2017 | Hard Computers & Internet
How to remove beep sound after the system sound?
the beeps ate called post
Then what happens does it restart ? or just wont boot up ?
A bit more information please.
Not sure what you mean by 'when the hard drive beeps
does the hard drive start when you turn the laptop on
(at which point a do the beeps occur a single beep isn't unusual) and it stops when you turn the hard drive off - a beep then would be unusual.
I suspect you don't mean that, & if the laptop is working fine otherwise then I wouldn't worry about it or do you mean something else completely?
make sure the ram modules have secure seatings also check all power and data leads attached from motherboard to hard drive the same will apply for your graphics card
hope this helps
Oct 10, 2012 | Computers & Internet
HP Mini 1000 VT won't turn on, lights flash when plugged in
This is a common issue when the unit has been dropped or jarred really hard. The click is more than likely the hard drive trying to read the disk but can not access information.
With that in mind, try this: Remove all USB, SD, or any cards and attachment from you computer. If you have one at hand, connect an external monitor to the pc. Power on. If you get an image on the external monitor, restart pc and press F8, select "Enabel-low-resolution video" and move forward. If you get a picture after this, your video drivers need updating. BUT......
The clicking sound is a major concern because usually the hard drive is the only hardware part that have moving parts. (other than the optical drive or if you have a solid state hard drive.) If you have a dard drive the same size or close with an operating system on it, replace your hard drive with the GOOD drive and retry. If it boots, you need to replace the hard drive. (and hopefully you have a backup of your data)
Worst case, you may need an authorized HP agent to service your pc.
Good Luck
C2Soluitons
Feb 14, 2012 | HP Mini 1000 VT series PC Notebook
Hi. I have a Dell XPS 600 system. My problem is that, when I turn on the computer, it goes to the Dell logo screen, and then it tells me, "boot safe mode," "boot with command prompt," "boot with last known...
probably have to replace the hard drive as the first boot instruction ( boot from hard drive) is not executable , so the bios is looking for alternative sources to boot from as per the priorities set in the boot sequence
of the hard drive is dead - replace it with an sshd unit rather than a disc hd because in the sshd there are no moving parts to cause the problem and they are quicker to boot up
May 06, 2017 | Dell XPS 600 PC Desktop
Replacing hard drive, just want to know if a WD400...
If you want to replace your hard drive, use WD3200BEVE. Its a 320GIG hard drive and it works perfectly. I installed one in my compaq presario v2403nr.
May 20, 2010 | HP Compaq Presario V2000 Notebook
Vista OS computer does not see WD400 connected externally via USB to IDE cable.
Purchased a USB to IDE cable. Looked like it was communicating with the hard drive (WD400) my computer did not see the drive. (Vista OS).
Western Digital customer service recommended that I change the jumper pin to position #4 on the hard drive and install inside the computer as a an additional slave drive.
Worked perfectly.
Oct 08, 2009 | Western Digital Caviar 40 GB Hard Drive
Emachine T1840 the hard drive WD400 40GB problem Ask me to Format
try this software it is free to try and then if you see it recovered your data you can buy it in order to actually save it off...
http://www.runtime.org/gdbnt.zip
Hope this helps
Jul 10, 2009 | Computers & Internet
Computer doen't recognize Maxtor n256 have to boot by CD
  1. Log on as administrator or as a member of the Administrators group.
  2. Click Start, click Run, type compmgmt.msc, and then click OK.
  3. In the console tree, click Disk Management. The Disk Management window appears.
  4. you should see the maxor disk (unallowcated)
  5. right click & format it
Apr 04, 2009 | Maxtor Hard Drive
Dell 8250 Hard drive 0 not found after move from US to UK
IT sounds like the hard drive went bad, especially with the clicking noise. If you want to keep the system, you will need to buy a new drive (relatively cheap) from tigerdirect or newegg and istall it. NOt sure if dell still send out recovery cds with their systems but if you have one just insert the cd after you install the new drive and follow the prompts. If you do not have one contact dell support and they should beable to send you one
Jan 21, 2009 | Computers & Internet
Western Digital unusual click
Hello Echo007
I read through all your accounts and following is my conclusion.
I think you have a flakey drive and that eventually the "clicking", or worse, will return. A clicking sound eminating from a hard disk drive bodes ill wind - it is not normal. Even if it does turn out that the bearings needed a break in period, that is, at the very least, bad design as it puts your valuable data at risk during this period.
It's true, WD will require a hard failure of the drive b4 you can get them to replace it. Unfortunately, failures often begin w/ intermittent problems. And intermittent problems w/ computer-related equipment (any electronic equipment, in fact) are the hardest to pin down.
It could be a heat related problem where, once the drive reaches a certain temperature the problem goes away. That's still indicative of some component inside the hard drive that is borderline functioning or a circuit, device or component that is fractured in some way and closed when there is sufficient heat for the metal parts involved to expand enough to complete the circuit or make the contact.
Here's what I recommend:
1st and *MOST* importantly: Set up a redundant backup system for all of your valuable data. Never ever put all your apples in one basket when it comes to hard drives or any dynamic media like a hard drive. Hard drives are made up of both electronic and moving parts - both of which are subseptible to inevitable failure. Unless you're burning your data on a regular basis to DVDs or backing up to tape or some other permanent storage type, then you must employ redundancy in order to protect your valuable data. (Backup to two or more locations.)
2nd: Backup all of your data off of the hard disk drive you're having trouble w/ (and onto one on which you've never experienced problems). Then, run hard disk drive "burn in" diagnostics on it - intensely exercising it over a long period of time (at *least* 24 hours - more if possible - or until a hard failure of the hard disk drive is induced). This will require exclusive access to the computer the burn in is being run on. (You won't be able to use the computer for anything else during this period.)
Include in the hard disk drive "burn in" write and read and seek excercises. The idea is to make the drive break. It will eventually. We just want to make it happen now while it's in warranty. You won't be violating any warranty, etc. by doing this. The drive *should* be able to w/stand any intense burn in routines you can throw at it.
If it still won't fail, I still wouldn't trust it. I'd use it for temporary storage but not for any critical or permanent storage.
You can download Bart's Disktool 1.2 HERE. You can also download Ultimate Boot CD (UBCD4Win) for Windows from HERE, and Ultimate Boot CD (UBCD) from HERE. Each include hard disk drive diagnostics.
If you'd like assistance w/ any of these processes, tests, creating the boot discs, etc. just us know. We'll be happy to help.
Thank you
BJ @:)
Apr 18, 2008 | Western Digital Caviar (wd800lb) 80 GB...
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
263 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
