Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
My Compressor wont restart.
I may have used a faulty extension cord. How do I fix my Compressor. When I plug it up the motor doesn't start up.
  • dflo64 Apr 09, 2009
    I've got a craftsman 3 gallon 1.5 hp electric compressor. Worked fine up to 40-60 psi, while using it . it started buzzing as if it was trying to cycle. I released the air pressure and turned it on again. It will not run to build pressure it just makes a buzzing sound. I also checked the sight glass for oil, it looks like it maybe low. Could this be the problem?
    Problem Solver:
  • 11 Answers
Start capacitor is probably fried
Posted on Mar 25, 2009
Ridgid air compressor OF45150A wont start, it just hums
Requires 120VAC to start - will not start with an extension cord unless heavy duty cord is used due to voltage drop and high starting current demand of compressor motor.
Jan 02, 2018 | Ridgid Air Tools & Compressors
Compressor hums when trying to restart after tank is full
It may need more power to it available at start up. try plugging it directly on the wall without extension cord. check the amps of the motor and use a circuit capable of delivering the power to the compressor motor
Mar 14, 2015 | Air Tools & Compressors
How do i fix my dewalt 55155 air compressor
It is a 15 amps motor and will need 6 times (90) that amount of amps to start up. Plugging it into a 15 amps circuit may work but a 20 amps circuit is more apropiate. Kitchen circuits are 20 amp circuits.
You can try plugging the compressor directly into the wall and see if it refills with air without trippiing the circuit breaker. Using an extension cord should be done with a #12 or #10 wire gage type, smaller type will cause a power loss in the cord and will cause the compressor motor to trip the circuit breaker.
Power formula is I square R, or the amps multiplied by itself and by the resistance of the wire. E.G. 90x90x4 = 3200 watts. This is at start up. To find the voltage drop divide the watts by current, 3200/90 = .... get the point? Keep voltage drops to a minimum, use heavy wire gage extension cords.
Mar 11, 2015 | Dewalt Air Tools & Compressors
My pancake will try to kick on when the pressure drops, however it will not catch and start. It is like a car that will just not turn over when trying to start. Any thoughts?
sounds like it needs a new start capacitor for the motor and never use a extension cord plug it directly into the outlet and use longer air hose.using extension cords for a air compressor is bad for the motor
Jun 19, 2011 | Stanley FactoryReconditioned Bostitch...
My compressor quit working when i flip the on switch it does nothing any ideas what is wrong???
If the tank is full (pressurized): Nothing will happen when the switch is turned on. Bleed some air from the tank to see if the motor turns on when the pressure drops.
If the tank is empty or low on pressure: First check the circuit breaker to the outlet the compressor is plugged into. Next, somewhere on the compressor, usually on the motor, there is a circuit breaker. They are usually a small round white or black button that if tripped will stick out about 1/4 inch or more. Push that back in and check to see if your motor runs. The usual reason for these circuit breakers to pop is because the compressor is being run on an extension cord. Rule of thumb for compressors: run longer air lines, NEVER use extension cords. If it is absolutely necessary to run an extension cord it should be 10-guage and no longer than 25 feet.
Jan 31, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
I have a CH WL611701AJ compressor. The motor starts and runs for approx 15-20 seconds before blowing breaker. I have replaced both capacitors, still blows breaker. Removed piston to allow motor to...
This may seem a bit simplistic but how are you hooked up to the outlet? Are you using an extension cord or is the compressor plugged in only using the supplied power cord?
If you are using an extension cord then you are going to pop the breaker every time you use it. Infact the manual states
"Never use an extension cord with this product. Use additional air hose instead of an extension cord to avoid power loss and
permanent motor damage. Use of an extension cord voids the warranty."
Air compressors don't like extension cords.
It simply draws to much for an extension cord to handle.
Depending on whether or not your warranty is out there is a simple solution. Find the biggest gauge extension cord you can
If your not using an extension cord and it's ran in the past where it's plugged in now then check the circuit because there must be new draw on the breaker
You said the breaker is 20amp. correct? The compressor should be run on a breaker dedicated to the compressor only.
Even though you should use a longer hose instead of a longer power cord you can get away with it. But forget about wire gauge size you need to think wire diameter. The extension cord I made for my compressor is approximately 3/4" thick. That is the only way I was able to use an extension cord on mine. A good place to get that size cable is a boat supply store. The cable used for shore power on boats works.
Hope this helps but if not please let me know and I'll try and help anyway I can to solve your problem.
Nov 15, 2009 | Campbell Hausfeld 28 - Gallon Air...
Motor tried to start but couldn't, was using long
I'm assuming that your on/off is a lever or switch built into the pressure switch. If so, the pressure switch sounds like the problem.
Nov 14, 2009 | Air Tools & Compressors
I have a craftsman air compressor (small) with 2 wheels on end, my probelm is when i plug it up it buzzes only, will not start motor, what could be problem
unplug it and see if you can turn the motor pulley by hand, it should turn freely. If it does, check to see if the motor runs with the belt off. If the motor runs by itself then either the belt was too tight or the compressor is seized.
Aug 12, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My compessor wont start.
ALWAYS USE LARGE GAUGE CORDS FOR COMPRESSORS. LOOK FOR RESET BUTTONS OR THERMAL OVERLOAD BUTTON ON MOTOR. DID IT TRIP BREAKER OR GFI OUTLET?
Feb 15, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
189 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
