Question about Dometic WA3210 Compact Refrigerator
Dometic rm4223 wont run at all
The refrigerator is a 3-way unit. I have power to the plug, but I plugged the unit in and turned just the electrical switch on only and left it on for 12 hours, the backside/smokestack never even got warm nor did the inside get cool. Then I tried running it on gas and the unit would not light. Does anyone have any ides? Thanks
  • gokartracer2 Feb 15, 2009
    not the answer i was looking for but thanks
    Sniper:
  • 68 Answers
Make sure you have 12 volt DC power to circuit board. If you do you need a circuit board.
Posted on Mar 19, 2009
Dometic rm4223 model does not run on 12v when traveling
You could contact me and I'll buy your old broken fridge, or you could buy my brand new rm4223 that is missing parts (but the cooling unit and cabinet are brand new, never used.
Sep 08, 2013 | Dometic WA3210 Compact Refrigerator
Dometic Refrigerator 2301
if battery ok check convertor or voltage to unit if under 10 volts wont work
May 14, 2013 | Dometic Refrigerators
My dometic refrigerator unit is not cooling properly on gas or electric. The freezer gets cool but the fridge stays warm. What could cause this?
my domestic refrg will not work on electric but will lite on gas. freezer will get cold on gas but bottom will not cool.you can plug refrg in and it will kick the gas off. you unplug refrg on gas will lite.that part of the power board seems to be working.
Apr 17, 2011 | Dometic RM2652 Refrigerator
Our Dometic RM2193 cools on gas but does not work on electric
It could be as simple as a blown fuse at the fridge. Also check to make sure you have turned on the electric switch that allows the fridge to run on AC. Note, you can only operate the fridge on EITHER gas OR electric, but not both sources at the same time, thus, you have to turn off the gas switch before you can run on electric.
When this unit is running on electricity, it has to have the thermostat set for it to run.
Here's a link to the Dometic manual for your model.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Just follow the steps for running on electric and you should be OK.
Hope this helps.
Jul 30, 2009 | Dometic RM2193 Compact Refrigerator With...
Dometic rm4223 has leaked coolant. The refrigerator was running but not cooling as we smelled ammonia
You need a new cooling unit. That ammonia smell means that your heating unit is shot, needs to be replaced, and there are a coupla ways to go here.
1) Order up a rebuilt (or new) online, and replace it yourself. (Handyman skill level:fair.) $500.
2) Go to an RV repair shop and have that done $700.00 - $100.00
3) Buy a new fridge. $1000.00 ++
Jul 11, 2009 | Dometic WA3210 Compact Refrigerator
My dometic 2611 dosent want to operate correctly. Check light consistantly comes on. I'mm connected to ac power all of the time. AC sometimes works for a day or so then it might switch to gas for no...
If your unit is automatically switching from AC to gas for no reason, then you either have a problem with the power supply or the lower control board. On the outside of the fridge, there is a black box located in the lower left corner, this box is the control unit. The control unit senses the incoming power source and automatically switches it to LP if no AC power is available.
Turn the refrigerator on and set it to auto. Let it run until you notice that it switches to gas. Immediately go outside and check for incoming 120VAC power at that lower board. If you have power there, then you have a bad board. If you do not have power, then you have a power supply problem. Check the electrical plug and outlet in the fridge compartment and also make sure that your GFCI's throughout the coach are ok.
Hope this helps,
Jeff
Jul 06, 2009 | Dometic RM2652 Refrigerator
Dometic NDR 1292 does not cool
Check to see if your boiler tube is hot. If it is , your cooling unit is shot. Do not plug your circuit board into 110 volt power that will destroy it. To test your heating elements you need to do an ohms reading on the elements. But I can tell you from experience if your boiler tube/ this is the 3-4" diameter sheet metal tube going up the back of the refer/ is hot the cooling unit is no good. If you would like to discuss your diagnostics give me a call.
Jerry
rvtech@myway.com
734 777 6432
www.coachtech.info
Mar 13, 2009 | Dometic NDR 1292 Refrigerator
Unit will not turn onto AC
Heating element is burned out
Oct 20, 2008 | Dometic NDR 1292 Refrigerator
Dometic WA3210 Compact Refrigerator Logo
428 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
