Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
No sound My television works fine in every way, shape, and form, however there is absolutely no sound. It went out very abruptly and there is no hissing, popping, or buzzing. I'm still able to get sound through my auxilliary speakers, but the television speakers aren't working at all. My basement recently flooded and with that went the manual. I tried emailing customer support from Hitachi (thrice), and haven't received a response. Any help/tips/guidance would be appreciated...
    Top Expert:
  • Hitachi Master
  • 74,871 Answers
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts.
Posted on Jun 06, 2017
SOURCE: Hitachi 53SDX01B Rear Projection Television - No Picture
i have a 50" r.p. Hitachi, kinda had the same problem, it would go off at different times and i't hit on the back and get it to come back on,but after awlhile i'd have to hit it more and harder to get it back on till it quit, the menu would come on and would show the video 1 ,3 and that in the corner.After paying $75 for a guy to say it wasn't worth fixing i tried myself. Not knowing what i was doing, i checked all wire plug connections. Found 2 that wasn't seated good replugged them and still didn't work then tried the bulbs, just kinda jiggled all 3 one didn't feel the same so just tapped on it alittle and it popped, i guess back into place, anyway turned on the tv and it worked. Had moved it recentlly so i don't know if that is what moved the bulb. Hope this helps, also mine is a '94 model.
Posted on Apr 04, 2008
  • 298 Answers
SOURCE: Screen broke on my Hitachi 61SDX01B, need replacement
Here's a link to order the original Hitachi screen assembly for this model (61SDX01B) from a major parts distributor:
Hitachi 61SDX01B Replacement Part Screen Assembly
Posted on Mar 19, 2009
Shuttle83
  • 1139 Answers
SOURCE: tv with no pic no sound on and off work
Hello mackenzie212, The loud pop you heard was most likely a capacitor exploding. I beleve the capacitor is also located in the power supply section of your TV. If you take the back off of the set you will see what can be described as a exploded, or bloated can. This component can be replaced, but I advise you to have it done by a qualified TV technician. This is due to the fact that their may be other unknown factors as to why the capacitor exploded, and a qualified TV technician can determine these causes past the obvious changing of the defective component. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 14, 2009
SOURCE: Hitachi Rear Projection TV - C4678FS - No Sound
i am having the same problem with my hitachi.. if you find anything out plz let me kno
Posted on May 10, 2010
ladywinn
  • 5138 Answers
SOURCE: Hitachi 50DX01B 50 in. Rear Projection Television
Bad convergence ICs STK392-110s replace both of them use 150s.
Mats electronics 1-800-628-1118
Posted on Jun 26, 2010
Shrunken picture
HI!
can you take a picture to your tv to see exactly what happen to your vertical problem!? then you can post here thanks!
Nov 02, 2007 | Proscan PS56670 56" Rear Projection...
What caused audio and video to stop abruptly?
Sounds like the tuner section may have gone....you willl probably need a repair person to take a look at it
Jul 19, 2015 | Televison & Video
The sound is terrible on our video downloads from the Kodak Zi6 but absolutely fine when shown on our TV.
You mean the sound form the speaker on the Zi6 is distorted?
You can have that repaired under your warranty, but if it sounds fine on the TV all indicates that the recording function works fine.
Often the sound from a small handheld device isn't as fine as from a larger speaker system, it will never sound as goood as from a dif. device than the camera even after a repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Oct 29, 2009 | Kodak Zi6 Flash Media Camcorder
Abrupt loss of picture during DIRECTV-source
Ur main video backllight board it dying,must be replaced.
Oct 14, 2009 | Fujitsu Plasmavision PDS-4209 42 in....
VS-50803 50" Mitsubishi No picture problem
Sounds like your picture tube has went out,, or maybe something simple,, to fix,, i would at least let a tv shop check it out ,, worth a chance ,, nothin 2 loose,, good luck
Oct 05, 2008 | Mitsubishi VS-50803 50" Rear Projection...
No video
I had the same problem too. It called the Y-main Board. It cost $145 if you order directly from Norcent itself. I hope that help.
Nov 04, 2007 | Norcent Technologies PT4231 42 in....
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
103 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
