Question about Philips DIRECTV R15
Directv DVR Plus R15 Receiver won't power on
Have had no problems in undisturbed, same set up environment for 1-1/2 years. Won't power on. Tried different outlets, different chords, extensions, etc. Have powered it off for 5 minutes several times as manual suggests. Still won't power on.
Is there some sort of blown in-line fuse with the R15 receiver?
Need a guru.
  • 56 Answers
Sounds like the receiver has gone bad. if you have tried it in numerous rooms/outlets and its not the electrical cord (its plugged in tightly at the back if its detachable) sounds like the receiver needs replaced. if you have the protection plan it MAY be covered under this and MAY be replaced for free. contact directv at 800-531-5000
Posted on Apr 05, 2009
Why does my R15-100 DVR Plus not record 2 programs at same time. What can I do to fix it?
When we had the R15 (we have since upgraded) we could record two channels at once with no trouble. You have to have two satellite connections in the back (since it uses a separate tuner for each channel) and you cannot watch a third channel while recording two others - if you're going to watch, you have to watch one of the two shows you're recording.
May 16, 2014 | Directv Plus DVR DTV Receiver / 100-Hours...
Need to recover data from DirecTV R15 DVR receiver hard drive
First, sorry for the delay in respoding to your post. I did notice that you had a prior question about the Power Supply on an R15 DVR. Does the unit have a manufacture code of 500(found on the right hand front Flip Door of the DVR)? If so, I might be able to help you in repairing the Power Supply. As far as I know, getting your DVR up and running again is the only way to watch your previously recorded programs. As far as retreiving programs from your old Hard Drive via other methods, I probably won't be able to help you there. When I had both of my identical DVR 15 500's apart for a parts swap to diagnos a failed Phototransistor(infra-red sensor for the remote control), I also tried to swap out the Hard Drives. This is what I found: When you swap a Hard Drive into another DVR, it won't play any of the programs previously recorded. However, if you record new programs on the swapped Hard Drive then they will be playable on this current setup. Now, if you swap the Hard Drive back to the original DVR it came out of, the programs will once again be accessible except for any that you might have recorded while the Hard Drive was in the other DVR. So, in conclusion, when programs are recorded on a particular DVR, it is encoded electronically to play back only in that DVR via communication from the Motherboard and the Hard Drive. I know, it sucks, but that is why I was asking if you are pretty sure the Power Supply is at fault. If so, I received info from this forum on how to fix the issue. Also, if the attempt fails, Ebay has some previously owned DVR's for sale and maybe you can get one for spare parts. Remember, the Power Board and Front Display Control Panel are the only interchangeable parts IF you want to view the programs on your DVR's Hard Drive. Let me know what your DVR does when you plug it in. That will go far in further diagnostics of your DVR.
Nov 28, 2011 | Directv Plus DVR DTV Receiver / 100-Hours...
DirecTV receiver R15 won't respond to remote RC23
Well, I took the DVR apart and found the power board completely intact, no bulging capacitors. However, the Mother Board had a 220uf/50volt cap that was bulging, so I replaced it. By the way, 'DigiKey' is the only place to go for electronic parts. They'll hook you up! The DVR still wouldn't respond to the remote. Darn it!
So I took both of my DVR's apart and swapped out the Front Board (the one with the Photoamplifier in it) and the DVR would now respond to the remote. OK, so now what do I do. I still have one DVR with a bad Front Board. I started to look on ebay for an old used R15 500 that I could swap parts from...remember, I own my eqipment and the goal is to preserve what I have recorded on the Hard Drive. R15's were going for around $50 -$80. Then I got to thinking. I still had an old non-DVR Direct TV Receiver in my closet I never planned to use again. My thought was: even though it wasen't the exact model receiver, it did use the same remote, so the frquency that the Photoamplifier worked at should be compatible.
So I took apart this receiver unsoldered the Photoaplifier. I then removed the Photoamplifier from my malfunctioning DVR and installed the part from my unused Receiver and it fixed it. So long story short(too late for that) the Photoamplifier was faulty. I tried doing some cross checking and a company in China called Raytron makes the part. The failed part did not have a part # and Raytron has several different Photoamplifiers that operate at different frequencies. This made it impossible to find the right part without schematics or knowing what the freqency is. So at least we now know what caused the non responce to the remote.
Jan 31, 2010 | Directv RC23 Remote Control
R15 DVR locked in record
2 months ago my R15-500 stopped working. The "Record"(yellow) light was dim on the front of the DVR and a lightly audible clicking noise could be heard from inside the DVR. So I searched the internet and found this FIXYA site. I disassembled the DVR as instructed and removed the power board. Sure enough the Capacitors were bulging on top. I replaced all of the capacitors on the power supply output, I think 6 altogether. I reassembled the unit and it worked great.
Jul 23, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
DVR keeps restarting / rebooting
Jay .. if you still have the receiver. heres what you do. reset the receiver and when the blue screen comes up saying "Hello your directv receiver is starting up" On your remote type in 0 2 4 6 8 .. then it should go to a screen saying "new software found" . Let it download the update.. That should fix the issue .. However if it doesn't then it could be the hard drive. The pcb board on them usually fries.. but that can be ordered too... let me know how this works... you can email me at pimp_on@yahoo.com
May 28, 2009 | Philips DIRECTV R15
Directv dvr will not power on. The record light
Unplug the DVR for about 20 minutes and then plug it back in. If that doesn't work its probably time to contact DTV for a replacement.
Mar 23, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
My Directv DVR receiver will not stay on it is blinking yellow??
Unplug it from the power for about 30 minutes and then try again. If it still doesn't work I would call DirecTV and discuss getting it replaced.
Mar 17, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Directv R15 DVR Boot-up problem
restart the dvr with the satellite cables disconnected. let it load then plug in the cables
Feb 09, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Philips DIRECTV R15 Logo
2,862 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
