Question about Dometic Rooftop RV Air Conditioner
Suburban RV Furnace
My furnace will not start with the Dometic remote all other will work air,fan,Temp set,but furnace will not light.In order to get furnace to light I pull the 15amp fuse out of the breaker box and as soon as I put fuse back in the furnace starts up but will not shut off with remote. In order to turn off furnace I have to shut off gas then it will cool off and shut down.How can I fix this? NO wall Thermostat Remote Only. Thanks Glenn
    Top Expert:
  • Dometic Master
  • 8,163 Answers
Make sure fan is set auto its just seeing fan motor now
Posted on Sep 11, 2017
5 Suggested Answers
  • 4 Answers
SOURCE: furnace problem
The problem is most likely in the control module of the roof air unit. Dometic uses the thermostat to activate and deactivate a relay in the control board of the roof ac unit whiich is just visible when you remove your air intake screen. The two blue with white stripe wires are the furnace control wires.
The furnace turns on and off by the opening and closing of relay. Most likely, the furnace control relay is stuck in the on position. On the thermostate, remove the fur wire and see if the furnace quits afrer it cycles down...it does not quit right away. With the termostat out of the loop, if the furnace does not shut down, the problem is in the control box. They are not hard to replace but you must be careful with the live wiire from the 110 ciucuit breaker. If you are not comfortable with the repair, take it to a dealer. The part number is on the assembly box. They need to know if you have the heat srip option or whatever othert options our Roof AC has. If the furnace still runs with the blue/white wires disconnected, the furnace wires are shorted somewhere between the furnace and the AC control unit.
Posted on Dec 10, 2007
motor1258
  • 6674 Answers
SOURCE: duo therm air conditionning/furnace thermostat in RV
Checked all breakers & fuses in panel ?
Posted on Aug 14, 2008
motor1258
  • 6674 Answers
SOURCE: I have a DuoTherm BriskAIr 13.5K BTU. The Dometic
If you look at control box at roof unit, they usually use a separate set of wires for furnace. See what colors they are attached to at harness to thermostat. Some just follow other harness, and come out at thermostat. (bypass control box) Once you've determined which 2 they are, join them together & see if furnace starts, as it should. If it does, thermostat is faulty. If not, pull outside cover off & check voltages at furnace. I'm guessing by furnace model that your unit is approx 30 ft , but if it's a park model, you may have 24 volt system on furnace or 12 volt. Another way of confirming is to go to back of furnace where air intake grille is inside your unit, and locate 2 blue wires going to furnace & remove whatever wires are attached to them & connect them together. Furnace should start up.
Posted on Jul 08, 2009
Testimonial: "thanks for the link. info solved my problem."
motor1258
  • 6674 Answers
SOURCE: My dometic duo-therm thermostat is
I assume it's remote control. (comfort control) Have you tried following procedure for selecting "Mode"?
Posted on Nov 06, 2010
I have a Dometic DuoTherm ac/furnace unit in an rv. The thermostat got knocked off the wall and now the ac nor the furnace will work. Fan works in manual position only. What could be wrong?
When the thermostat was knocked off it may have damaged the wiring. I would start by checking continuity of all wires from thermostat to unit.
Feb 15, 2015 | Dometic Rooftop RV Air Conditioner
RV. when furnace is turned on , fan on rooftop AC unit runs continually
i would say its the relay board or communication cabl between stat and board.
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
Suburban SF30FQ furnace doesn't run. Has power to unit and can hear relay click in unit when call for heat but blower does not run.
Please give make, model, year etc of RV that furnace is in. Thermostat on wall operates heat and cool?
Oct 10, 2013 | Dometic Rooftop RV Air Conditioner
I have a new keystone hideout with dometic single zone lcd thermostat when i put it to furnace the ac fan comes on at same time but when furnace reaches temp. ac fan just keeps blowing cool air?
Obviously wired wrong. I will assume it is still under warranty? If you only recently picked unit up, I would also question the quality of the PDI performed. ( Pre Delivery Inspection) Have you tried to contact dealer you purchased it from?
Oct 14, 2012 | Dometic Rooftop RV Air Conditioner
I have a suburban lp furnace and duotherm air/heat pump roof unit. duothern thermostat. 20 amp breaker kicked ( reset breaker) & furnace quit. NOW furnace fan comes on but does not light, and the front...
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Jan 23, 2010 | Dometic Rooftop RV Air Conditioner
Batterys went dead in remote put in fresh
You have to hit the rest botton on the furnace for the led to pick up the remote always you can go to your rv manu and it will help you out if not you can go to any rv lot and they will show you how to rest your systems
Dec 10, 2009 | Dometic Rooftop RV Air Conditioner
Furnace won't turn on, off, with or without remote
We hotwired the thermostat wires and the furnace started. That told us that the problem was with the thermostat. We took our remote control to another camper like ours and our remote worked their furnace. That told us that the problem was in the ceiling control for the furnace/ac. But the man who owned the other camper told us that he had a problem, too, and was told to unplug all the electric including the battery, wait 2 minutes, and hook up again. This might reprogram the circuitboard, and voila! It worked.
Feb 08, 2009 | Dometic Rooftop RV Air Conditioner
Dur-therm furnace heat controll with Dometic remote
i would suggest that you look at your thermostat,it may be to close to the furnace keeping in mind that all thermostats have a certain tempreture drop (or gain) before restarting john
Dec 28, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
989 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
