This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor
I moved and am reconnecting the unit. The Rear speakers are not working in any mode. I reset unit to...
(More)
I moved and am reconnecting the unit. The Rear speakers are not working in any mode. I reset unit to factory specs per the Sony manual instructions... to no avail. I do not have anything connected to the surround inputs. Although I have the Sat/TV, DVD and Video 1 inputs connected. Prior to moving, I discovered the right rear channel not functioning (I noticed the right rear speaker problem after a Direct TV installation tech switched out my Direct TVR. I assumed that it was a loose wire) now it seems neither of the two rear channels are working.I disconnected and reconnected the speaker wires. I ran the onboard "tone" check and the three front speakers function and supply the 'white noise' indication. The rears are silent when the display indicated that they were being tested. Are the rear speakers fuse protected? Anyone with an idea of what might be going on??
Sony STR-DE845 1)Rear channel speakers no longer function. Unit makes random clicking sound from...
(More)
Sony STR-DE845 1)Rear channel speakers no longer function. Unit makes random clicking sound from relay 2)Display intermitantly works
Plug it in and demo starts, never stops and power switch will not stop it Switch opens &...
(More)
Plug it in and demo starts, never stops and power switch will not stop it Switch opens & closes normally.
