Question about Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive
Toshiba USB Portable External Hard Drive
I connected it, the computer lists it in the device manager, but there is no icon in my computer to access it. Added new 100g usb hard drive to my Tecra M5. it is listed under system in control panel but it does not show up under my computer.
  • Toshiba Master
  • 19,396 Answers
Unplug both devices from power and restart both , see if the disk appear on my computer.
Posted on Feb 15, 2009
  • Toshiba Master
  • 13,433 Answers
Hi
You need to format the drive before usage.
right click my computer select manage.
left side disk management
right side find the drive
right click create partition and format.
Pc d'ont reconize this drive
Primary or external ???.....
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Or even get a usb 3 lead.
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling
http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Sometimes they become faulty due to overstretching age or heavy objects sitting on top of them.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
Windows 7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error.
This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition.
Now I have seen cases where Malware can break the link of a Hard Drive.
So let's try a couple of steps.
Let's go back in to "Disk Management"
Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths"
Now try selecting a new Drive Letter.
This will restore the path if it has been broken.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Sep 08, 2013 | Computers & Internet
My buffalo drivestation external harddrive don't power up?
A USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Sometimes they become faulty due to overstretching age or heavy objects sitting on top of them. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. Windows 7 First, please disconnect all USB devices and then perform the following steps:
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error. This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition. Now I have seen cases where Malware can break the link of a Hard Drive. So let's try a couple of steps. Let's go back in to "Disk Management" Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths" Now try selecting a new Drive Letter. This will restore the path if it has been broken. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
Jan 02, 2013 | Buffalo Technology Buffalo 1TB Drive USB...
Can't get model #usb1tb external HD to power up. Can it be repaired?
Dec 29, 2012 | Verbatim SmartDisk USB1TB 1 Terabyte 1TB...
Driver HX-DU010EC
Windows 7
Hope this helps
Nov 22, 2012 | Samsung G3 Station 1TB USB 2.0 Black...
I cant access my toshiba hard drive USB 2.0 in my laptop.....(cant find the icon for the same in my computer)
check all the leads that attachtoshiba hard drive USB 2.0 they may be faulty or you may have to reinstall usb drivers you do this by control panel,administrive tools,computer management,devive manager possibly a yellow question mark? right click to reinstall drivers
hope this helps
Sep 02, 2010 | Toshiba 120GB USB 2.0 Portable External...
Toshiba 60GB USB 2.0. Portable not recognized in my computer
Check you have the usb 2.0 drivers installed on the computer. You can check this in device manager in the properties of my computer icon. if you havent got USB2 enhanced host controller you havent got the driver.
You can find the Drivers and how to load them at this site:
www.softwarepatch.com/tips/usb2-driver.html
Jan 22, 2010 | Toshiba 120GB USB 2.0 Portable External...
Usb port detected but i cannot access the portable hdd because there is no displayed ickon of hdd in the my computer page
Is this on a Windows system?
If so, try right-clicking the My Computer icon, and in the popup menu select Manage. This will bring up computer management, where you can go to disk management. In disk management check if you see the drive, if it has a partition and drive letter.
See here for more ideas and details.
Oct 08, 2009 | Toshiba 120GB USB 2.0 Portable External...
Toshiba 2.0 external hard drive
mrtunink,
Yellow ! simbol show in the usb devices means your usb driver may be corrupt so OS can't recognised the usb devices, u have to reinstall the driver like that way,
At first right click on my computer icon- then select propertices- then "hardware" - then click on devices manager buttons- then select ur devices and right click on it and click propertices then u finds reinstalls button under its propertices click on it and select install software automatically (recomanded) and click on ok. then windows scarch its driver automatically and install it.
Jul 02, 2008 | Toshiba 120GB USB 2.0 Portable External...
Plug and play? doubtful.
Is the drive partitioned and formatted already?
Does it work on another computer?
Is the drive powered via the usb cable, or does it have an adapter?
Do you have any networked drives on this computer?
When it is connected on your computer,
click Start
right click Computer
click Manage
double click Storage
double click Disk Management
Is it in the list of drives in the lower half of the window?
Mar 14, 2008 | Toshiba 120GB USB 2.0 Portable External...
Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive Logo
87 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
