Question about Kirby Generation 3 Bagged Upright Vacuum
Kirby Generation 3 Pictorial or wiring diagram
I am needing to replace the main power swith on my Generation 3 due to it breaking but I want to make sure I get the wires back on correctly, so if someone has a picture and or a wiring diagram for this unit it would be greatly appreciated.Thanks, Jeff
  • Anonymous Mar 22, 2009
    can anyone tell me how to tell how you put a kirby sweeper cord back together
  • Kirby Expert
  • 324 Answers
Go HERE. This should be more than enough info.
Posted on May 30, 2009
My kirby g4 motor runs backwards and so the power drive when pushed forward wants to go backwards. I need the wiring diagram so I can get it wired correctly.
The wires to the switch, coming from the carbon brushes, have been reversed. The carbon brush closest to the switch goes on the lower switch terminal.
Dec 24, 2010 | Kirby Generation 3 Bagged Upright Vacuum
How To Replace a Belt on a Kirby Generation G3-Sentria Vacuum Cleaner
Below we explain how you can replace a vacuum cleaner belt on the Kirby Generation upright vacuum cleaner. All you will need to perform this repair is a new Kirby Generation Upright Belt, and some time. No tools are needed to perform this repair. This repair is the same for all Kirby Generation models including: G3, G4, G5, G6, Ultimate G, Kirby Diamond Edition, and the Kirby Sentria. The repair procedures have to be followed exactly in order for the vacuum to work properly. This should be done at least once a year even if the belt doesn't break, because these belts will stretch out over that year time period and will not work as well as a new belt would.
I hope that you find this video helpful. If you do, please be sure to rate this Tip as helpful by clicking the Thumbs Up Icon in the top right hand corner of the Tip.
Feel free to send me an email anytime if you have any questions on the repair of the Kirby, or any vacuum cleaner.
Video Repair on how to Change a Belt on a Kirby Generation Vacuum Cleaner;
Thank you so much,
Chris Jones
on Mar 19, 2010 | Kirby Ultimate G Bagged Upright Vacuum
I need to replace power supply. where the cord
Greetings from,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Chris Jones
Mar 07, 2010 | Kirby Generation 3 Bagged Upright Vacuum
My Generation 3 Kirby Vacuum is giving off a burnt rubber smell when I vacuum. I have tried to raise the height of the head but it still happens. Can you tell me what could be causing rubber to burn? ...
The belt driving the brush roller in the power head is slipping. It is really just a big thick rubber band. Where it wears out it slips and burns due to friction.
Look at the bottom of the power head. There is a cover plate held with 2 to 4 screws. Remove the plate and you will see the roller and drive belt. Slip the roller out and remove the belt.
Go to your local vacuum dealer and get a replacement.
Installation is the reverse of removal.
Mar 06, 2010 | Kirby Generation 3 Bagged Upright Vacuum
My kirby generation 3 wont come on
Make sure cord is not damaged. Check to see nothing is blocking hose or carpet nozzle(where beater brush is or brush roll). Plug unit in to a receptacle that you know has power going to it. (Lamp you know works when plugged into same. Using hose on front, make sure bag bottom completely attached to exhaust, the hose has a little arm like thing that will depress the safety switch on the front of the unit, and turn on using foot switch at the back of the unit. If these do not work, it could be one of two safety switches, dirt may have fouled or switch may need to be replaced. Authorized Kirby Dealer in your area: Replacement parts, Kirby Distributor, call: 1-800-437-7170 United States and Canada
Nov 01, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Vacuum won't switch on;got it apart;cord ok;need wiring diagram
Its a great idea to write on paper how its connected . So it helps with dis assembly & reassembly . I tried a Internet search . Looks like it'd cost money for a service manual. Though. I found a Kirby Spares Website that could help. Although it doesnt have Document downloads with repair help. There are spares & there is a telephone number for an engineer available during office hours. That you could ask for repair help. With wiring connections for your Kirby G3.
The Engineers Telephone Number is 0845 388 9301
I repaired my Parents Kirby Heritage some while ago. With a new set of Brushes. Bulb Repair.
They are a Great Machine. Bit Expensive. Though Tough & Well Made !
May 24, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Generation 3 no power...
I don't believe there are any service manuals online, as Kirby has service centers around the country. There are 3 things in the power string--on/off foot switch, the power cord, and the power assembly that the cord plugs into underneath the bag in the main part of the body. One of the problems the G3 had was where the cord plugged into the body--the assembly was a very thin plastic piece supporting the 2-prong electrical connection. This plastic piece was known for breaking, and was actually recalled back in the 90's. You can take the cord connection off and look to see if that piece is broken, then you'll have to take it in, or buy a "switch" as it's called on ebay or somewhere and replace.
Dec 29, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Power problem
Hi, Try logging your post on the Kirby Trading Forum at - you'll be sure to get a reply. John
Aug 03, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Generation 3 Bagged Upright Vacuum Logo
2,510 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
