Question about Califone International 1030AV Turntable
Adjust pitch on a Califone turntable.
I've just got hold of a Califone 1450K record player (not very common here in Australia!). It sounds great, especially with 45s, which was what I wanted it for. But it runs a bit fast. It's not one of the pitch-adjustable models, but I figure if I could just get the bloody platter off there might be something under there I could tweak. So first of all, how do I remove the platter - it won't budge - and secondly, is there a way to fine tune the playing speed on these models? Cheers, Ben.
  • benl465 Feb 15, 2009
    Well that wasn't quite the sort of advice I had in mind... sorry to hear that Fuckedbyfixy. I just stumbled on this site looking for info on Califones. This seemed like a great resource and I hope you all can sort it out. Anyway, for what it's worth - I got the platter off eventually, and I can see how it works now, but nothing that looks that it might adjust the idler speed. Anyone (other than Fuckedby)?
  • rokarolla Sep 05, 2013
    PS: Gods help you if you have a 1455K. This thing has a weird electro magnetic pitch control in the form of an extended motor shaft with a 2 inch metal disk attached to it under the motor, with a metal fork that goes over and under the metallic disk. This disk creates electromagnetic drag when the forks are over the disk. the forks are connected to the pitch control on the phono deck. If your platter has an unwanted vibration and it transmits through the whole body of your Califone 1455K, the fault is an off balance disk. You must use your mini hex driver and rebalance this disk until you get it right. When you get it right it will have no vibration.
    Problem Solver:
  • 15 Answers
This one is actually fastened from underneath (inside). You need to open the player up and you will see the usual C shaped fastener on a cleat near the motor assembly. Most old direct drive record players have a C pin around the spindle that you can unfasten (pry with a twist) with a screwdriver. Irealize you figured this out yourself, but I'll take the guess work out for someone else... yeah..l you gotta take it apart!
Posted on Jul 19, 2013
    I'd like to continue my comment above by saying if the record player is from the 1970's it's TIME to take the motor apart, clean the old lube, replace the old lube. I use a drop of Singer sewing machine oil. Some may use a different product.
lesliemurphy
  • 69 Answers
SOURCE: need to replace a turntable belt on a zenith
Try this company? email them at this link but remove the <remove> from the address?
service<remove>@turntableneedles.com
Posted on Oct 20, 2009
Grubhead
  • 5259 Answers
SOURCE: How do I remove the turntable platter on a Ferguson 3047?
Try looking at the spindle where the record hole goes. You might have to lift the mat somehow. There might a C Ring holding it.
Posted on Oct 23, 2009
djproaudio
  • 515 Answers
SOURCE: Califone 1450K
Ya, this is a tough one. If it was on it's side, and not handle properly, something may have come loose and caused some damage inside. If you have absolutely no power, then more than likely the power transformer fried. Not much else in these things that could have caused such an issue. At this point, you have to decide whether it's worth getting repaired, or buying a working used one. They go on ebay for about $30-50, which is much cheaper than getting it repaired. Transformers for these units run around $20-30, then you have to tack on labor, which will be in the 40 min range - that's if its the transformer. But I do understand if it has some personal value, so that is something to consider. Hope this helps some. - Justin DJPROAUDIO
Posted on Sep 02, 2007
  • 4 Answers
SOURCE: I have a Califone 1620 model economy classroom phonograph in need
Probably a bad relay switch. Open up the turntable. Identify the motor that spins the table. Follow the wires of that motor to, perhaps, some type of little circuit board with a relay. I have a Backley-Cardy 322-487 classroom phonograph which uses a Califone 1620 amp and a BSR turntable. To get the table to spin, you have to move the tone arm. Mine doesn't move and I'm in the process of replacing the faulty relay that is the problem.
Posted on May 14, 2010
Grubhead
  • 5259 Answers
SOURCE: My ferguson turntable won't play 45s, just slides
Either the stylus is worn or you have not got enough weight to the stylus. As you don't state which type it is all I can say is look at the end of the arm and see if there is a weight with numbers on. Increase the pressure to the stylus by setting it a higher number. Do it in stages till the stylus stays in the grooves without causing rumble to the sound.
Posted on Mar 06, 2011
Califone 1435k This record player from the 70s runs great and came highly recommended but the 33 records we're trying to play are sounding much too fast. Any ideas on how to fix this?
This is an idler wheel drive turntable that uses a small rubber wheel, that when engaged pushes on the motor spindle and also on the rim on the underside of the platter. The spindle on the motor is stepped so as you shift speed the idler wheel moves up or down the spindle and that changes the speed of the platter. It could be the the shifting mechanism is dodgy You can try to loosen it by gently shifting the speed from 78 to 16 and back again. But the idler wheel rubber might be in trouble too.
Dec 29, 2016 | Califone International Audio Players &...
Califone 1875 turntable
Ask them what the part is they can't get and report it back here. Fixya experts like myself sometimes can track them down.
Feb 26, 2014 | Califone International Audio Players &...
I have a califone 1430k record player, and the arm is loose. It looks like the spring must have come loose. It is still attached by wires, but nothing else. If I take it apart, do you think I could fi
The arm should have a pin through it that secures it to the bracket that is attached to the arm bearing. There should be a long spring that is used to adjust the tracking force and it is underneath the arm.
The arm can be taken off by taking the player apart, unsoldering the wires from the arm and unscrewing the nut on the turntable bearing.
Because the arm mounts to a soft rubber grommet it should feel a little loose.
Hope this helps.
Jan 16, 2014 | Califone International Audio Players &...
Califone 1420 k speed fluctuation
Take the turntable off by removing the "E" clip on the top center of the turntable. You can then oil the motor, lube and check the main turntable bearing and most important, clean, lube and adjust the idler wheel. The rubber tire on the wheel can be cleaned with alcohol or rubber cleaner and this will fix most speed problems. The height of the wheel can be adjusted by changing the fiber washers and of course the wheel bearing should be greased.
Aug 09, 2013 | Califone International 1030AV Turntable
Just inherited an old califone 1010av. It turns on, but when I put the record on the turntable and bring the needle down, there is no sound and the arm slides to the center of the record very quickly. I...
SOUNDS LIKE NEELDE BROKEN.TO TELL PUT FINGER UNDER NEEDLE PULL BACK FINGER GENTLEY AND YOU SHOULD FEEL A POINT ON THE END OF THE NEEDLE.IF NOT OR UNSURE SEE IF YOU CAN SEE THE END OF THE NEEDLE THERE SOULD BE A SAFIRE OR DIOMOND IN THE END OF IT THAT SITS ON THE RECORD IF NONE IS SEEN REPLACE NEEDLE.
HOPE THIS HELPS
NORMAN
Aug 23, 2011 | Califone International 1010AV Turntable
My records that are 33 and 1/3 don't play at that speed on my turntable. they sound more like a 30 speed, what do I do
Hello Rosie,
Some turntables have a pitch adjustment feature which allows you to speed up or slow down your records. The adjustment controller is usually a slider or a wheel somewhere on the turntable and is usually labelled "Pitch" "Adjust / Adj" or "Pitch Adj".
Please check for this feature on your turntable then get back to me if you are unable to find it. Please include the brand and model number of your turntable.
Hope this helps.
Regards,
BElectric
Aug 17, 2011 | Audio Players & Recorders
Trying to fix an old record player - Califone. It seems to be making a scratchy sound even though I have replaced the needle. It almost sounds like when the two wires from a speaker touch... same...
May be the "winding" on the speaker. If it has got damp at some point(you may not notice any on the casing) the cardboard tube that the coil is wound around swells and "rubs" in the speaker. Thus producing a scratching sound. Try connecting to another speaker, just to test and if it sounds fine then that is what it is.
May 14, 2009 | Califone International 1030AV Turntable
Califone 1450k
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!1
Nov 08, 2008 | Califone International 1030AV Turntable
Califone 1450K
Aug 02, 2007 | Califone International 1030AV Turntable
Califone International 1030AV Turntable Logo
743 people viewed this question
Top Califone International Audio Players & Recorders Experts
Michael Galve
Michael Galve
Michial Gueffroy
Ben Armstrong
Are you a Califone International Audio Player and Recorder Expert? Answer questions, earn points and help others
