Question about Panasonic PT-61HX41 61" Rear Projection Television
Unable to adjust aspect ratio to 4:3
Lost power in the house suddenly. Television is a 2002 Panasonic PT-61HX41. With power restored the display is now 16:9. There is no high-def signal being sent to unit, just basic cable. The aspect ratio control on remote control will size to 4:3 but only in the middle of the screen, not the full screen, and with significant picture distortion. The Picture Menu no longer displays a selection for aspect ratio. How can I rest the unit to display full screen 4:3 images, please?
SOURCE: Aspect Ratio not responding/always in "Full" mode
i have a panasonic th-42pwd8bk tv i have it working through my sky box, but it only works in black & white no colour. it works in colour on my pc what am i doing wrong. i have no user manual
Posted on Apr 22, 2007
  • 3130 Answers
SOURCE: Panasonic PT-47WXD63G
If you have a problem with the convergence, believe me, going into the service menu and trying to correct it will only give you large headaches, DO NOT USE THR SERVICE MENU UNLESS YOU ARE A TRAINED TECH!!!! Doing so can result in a complete and total failure of this TV set. I service menu is not for any major changes in any adjustment. It is not the cure all. If your convergence all of a suddenly shifted, it is not a service menu issue. Your problem is the convergence amp IC's. Good Luck
Posted on Aug 12, 2007
  • 192 Answers
SOURCE: Aspect Function Not Working
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected. Some Dish Network boxes have Size buttons on their remotes and also in their main menu. It's difficult to determine the repair without knowing the types of the peripherals. Hope this helps.
Posted on Sep 10, 2007
  • 1139 Answers
SOURCE: HDMI Signal gone
The HDMI interface may have suffered a malfunction, this offten happens due to stray voltages on the ground plane. If you do not have electronics experience I would suggest taking the set to the shop and having it repaired
Posted on Sep 24, 2007
  • 275 Answers
SOURCE: TV picture aspect ratio
No. Aspect Ratio is same for UAE and India, and also the broadcast System.
Most Cable TV operators in India broadcast the signal 'slightly oversized, and so the viewer gets the Scrolling at the bottom and top of the screen cut-off.
Posted on Dec 02, 2008
How do I change the picture size back to wide screen
select the menu button then go to aspect ratio settings. choose wide or 4:3 option aspect ratio.
Jul 10, 2014 | Panasonic PT-47WX53 47" Rear Projection...
The picture images are fat and squatty, particularly people! Can the picture be adjusted?
Search the remote for a button that says "format" or "aspect ratio" or maybe "display." You're looking for 4:3 aspect ratio. This will probably give you bars on the sides of the pic and is usually only adjustable on analog.
Apr 05, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Top and bottom of screen are cut off how do we adjust to get screen to fit
Press the "Aspect" button on the remote until the picture looks appropriate. You are probably trying to display a 4:3 ratio channel on your 16:9 ratio TV. You are probably viewing it in "zoom" mode, which does not stretch the 4:3 ratio video, but enlarges it until it fits the width of the screen, which zooms part of the video off the top and bottom of the screen.
Mar 07, 2011 | Panasonic PT-53WX54 53" Rear Projection...
Need step by step instructions to set-up memory lens function for PT AE3000 projector so as to be able to switch between 16.9 and 2.35:1 formats
LENS MEMORY means that
You can save and name the adjusted ZOOM/FOCUS,
H-AREA POSITION and V-AREA POSITION there is just 4 adjustment settings in
memory excluding ASPECT RATIO the aspect ratio depend on signal but you can change manually when needed.
If VIDEO or S-VIDEO then
4:3 \ 16:9 \ 14:9 \ ZOOM1 \
\ 4:3 \ 16:9 \ JUST \ ZOOM
you can switch in between
4:3 \ 16:9
4:3 \ 16:9
VGA or SVGA signals
Not switchable with
WIDE480/600/720/768/768-2/800/900 signals
If HDMI then
4:3 \ 16:9
16:9 \ H - FIT \ V - FIT \ ZOOM
1 125 (1 080)/50i, 1 125 (1 080)/60i,
1 125 (1 080)/50p, 1 125 (1 080)/60p,
1 125 (1 080)/24p, 750 (720)/50p and
750 (720)/60p signals
525p (480p) and 625p (576p) signals
4:3 \ 16:9 \ 14:9 \ JUST \ ZOOM1
625i (576i), 625p (576p)
AUTO \ 4:3 \ 16:9 \ JUST \ ZOOM
525i (480i), 525p (480p)
1 125 (1 080)/24p, 750 (720)/50p,
these are all type of signals and there possible aspect ratios
Feb 06, 2011 | Panasonic PT-AE3000U LCD Projector
The yellow/green portion of the color spectrum is not aligned with the the other portion of the picture. Have checked the convergence adjustment and the crosshares for are wavy and off the screen. The net...
You have a "Static Convergeance" problem.
If the problem has been getting worse over the time period of say 3 months, then you have component failure. Probably electrolytic capacitors drying up.
If it went wrong all of a sudden, you possibly have dry joint, possibly contacts on plug/sockets.
Carefully check for problems and bear in mind that nothing will be very obvious.
Hope this helps.
Oct 31, 2010 | Panasonic PT-61HX41 61" Rear Projection...
Picture is wider than the screean
There is a service menu that techs can use to adjust vertical and horizontal widths. If it is not an aspect ratio problem then it is likely that it needs to be adjusted.
Apr 23, 2009 | RCA P46921 46" Rear Projection Television
I cannot change aspect ratio
If you are trying to change the aspect ratio on the television make sure you are sending an HD signal Via Component cables. I am not aware of a way to get HD cable without a PC cable card or box, it could be that your television is not receiving the proper signal (analog, or composite) to switch the aspect ratio on your particular television.
Feb 24, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-61HX41 61" Rear Projection Television Logo
244 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
