Question about Kenmore 63942 Dryer
Dryer runs but does not get hot
Kenmore Electric dryer - Model 86980100 - front loader - dryer runs but does not dry clothes. Does not get warm. Have cleaned out the lint from the lint filter and the hose on the back of the dryer is free from any lint and dirt. Now what do I check?
  • 150 Answers
It is your heating element,replacing it yourself will be a lot cheaper.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 16, 2009
I have the same dryer and I forgot what the part was called, i believe it is the heater element which you need to replace. That is what I did and it fixed the problem. very easy to install
Posted on Feb 15, 2009
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
We have a Kenmore 400 dryer. It gets warm but will not get hot--it is only one year old --what should we check for?
there are 2 thin coil wires that have current flowing threw it. it gets red hot and provides the heat to dry clothing, if one of these wires brake your dryer wont get so hot. very common its made cheaper all the time so it wont last.
Sep 24, 2010 | Kenmore 62622 Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Cleaned vents, dryer gets very hot, shuts off w/o drying clothes
Sounds like a faulty operating thermostat. Only way is to test on a electric griddle that you can set the temperature to 150 deg and measure with a ohm meter.
May 26, 2009 | Kenmore Dryers
Kenmore 64672 dryer gets hot but clothes still wet
you have a clogged wall vent or clogged dryer vent or a clogged lint trap,you are trapping all the hot wet air in the dryer and that's why it's taking so lont to dry-mike
Apr 22, 2009 | Kenmore 64672 Electric Dryer
Dryer works for few minutes then stops
clothes can open the door if door latch is weak, causing door opening and stopping the cycle, or a bad automatic sensor
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer model 110serial #86980100 will heat like it used to
The fuse mounts on the blower assembly in the back under the dust cover.3c90523.jpg
Feb 02, 2009 | Kenmore 62602 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Kenmore 86980100 dryer no heat
NO HEAT, CHECK THE FOLLOWING:
1. CHECK SETTINGS OF THE SELECTOR SWITCH. MAKE SURE A HEAT SETTING HAS BEEN SELECTED.
2. IF IT IS AN ELECTRIC DRYER, CHECK FOR 240VOLTS AT THE OUTLET.
3. CHECK THE HEATING ELEMENT FOR 240 VOLTS AT THE TERMINALS OF THE ELEMENT WHILE THE DRYER IS RUNNING. IF NO 240 VOLTS, TRACE WIRING BACK TO OTHER COMPONENTS OF THE HEAT CIRCUIT. WHEN YOU FIND 240 VOLTS ACROSS THAT COMPONENT, THAT IS THE BAD ITEM.
4. CHECK FOR BURNT WIRES IN THE HEAT CIRCUIT. (HEATER, THERMOSTAT, HIGH LIMIT THERMO, MOTOR CENTRIFUGAL SWITCH, TIMER, THERMAL FUSE).
Apr 21, 2008 | Dryers
Kenmore 63942 Dryer Logo
199 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
