Question about Technics SL-1210 Turntable
I have a SL-B30 that when turned on won't start up.
I don't have manual. hasn't been used in awhile. Table spins freely. I can't remember if it should spin freely. Any ideas?
  • 104 Answers
If your model does not say "direct drive" on the front then it sounds like your belt came off. this video will show you how to put it back on
http://www.archive.org/details/Turntable_Belt_Installation
Posted on Feb 16, 2009
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
10inch delta table saw....motor starts slow then kicks off
Assuming that this model has a belt drive from the motor to the saw arbor. Remove the belt and turn the motor on--same problem? If motor is a capacitor start unit, the capacitor may have failed. Be sure to check motor rotation by hand--it should spin freely. If ok, check the turning action of the blade itself--it should spin freely and coast for a little while. If not, check the arbor bearings for failure. Hope this helps!
Dec 22, 2010 | Garden
Saw blade seems to be seized, it is hard to turn manually.
could be a couple problems, first is the inner flange on correctly. and if so remove the blade UNPLUG SAW FIRST and see if you can turn the spindle by hand, it should spin freely, if not then you have a bearing problem or possibly the motor is burnt. did you notice any burning smell last time you used it and if so that is it. Let me know
Aug 28, 2010 | Bosch 4000 - 07 Electric Table Saws
I have not used it in a long time seems like the speed is wrong when i put it on 33/1/3 plays slow when i put on 45 it much better playing the 33
Good day. It sounds to me like the belt is worn. Under the felt of the turning section, there should be two rather large holes. Insert your thumb and forefinger and pull the table off. You should also see where the existing belt is running. Insert new belt around the motor first and replace the table section. Now, through the two holes, manouver the belt onto the table section until it spins freely
Jul 06, 2010 | Technics SL-BD20D Turntable
The belt came off on my Technics Model SL-B30 turntable, and I don't know how to put it back on. I took off the table, but was unsure of how to position the belt. Can you help? Thanks! Eddie K
there should be slots under the turntable mat big enough to get your fingers in. make sure the belt is around the table pulley set it on the middle spindle and then put the held part of the belt onto the motor spindle. then you have it. good luck..
Mar 09, 2010 | Audio Players & Recorders
Technics SL-5 Turntable will not turn.
try gently pushing the tone arm (actually the piece of plastic holding the tone arm) over to the right a little. works for me, but it still gets stuck often
Apr 06, 2009 | Audio Players & Recorders
Technics Table spins left and right in the on position
You have an issue with your drive circuits. Only a service tech can diagnose and repair this. It's not easy.
- OPTiC
The 1200s Expert
www.1200s.com
Aug 25, 2008 | Technics SL-1200MK5 Turntable
Panasonic turntable sl h205
Check the belt and the cueing mech, could have siezed.
John w
Feb 12, 2008 | Audio Players & Recorders
Technics SL-1210 Turntable Logo
255 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
